Sponsored by The Tire Rack
Old 11-17-2012, 03:45 PM   #1
k20z1 L
My Ride: 04 330ci
04 330Ci Tire Fitment Question
Hey guys,
I'm currently running 225-40-18 in the front and 255-35-18 in the rear. I wanted to get a set of winter tires but I'm not finding any that are as wide as my rears. I'm the 225-40-18's are easy to find but I'm not getting any luck with the rears.
I was wondering if any of you had insight on my possible solution: I was thinking of getting 245-40-18 for the rear instead. My rear wheels are roughly 9.5 inches wide (if my facts are correct) which would mean that a width of 245 mm's would still fit. Now, the other concern is that this tire would have more rubber (40% of 245 is 98). That is a total of 16 mm's (.63 inches) more than my current tires.
I'm pretty much an amateur at my stuff so I'm hoping if I did a calculation wrong that you guys will point it out. Overall, I'm worried about the rear tire fitment even though it looks to me that I have about an inch of wheel gap.. Please just let me know what you guys think.
Thanks a lot I really appreciate it!
k20z1 L is offline   Reply With Quote
Old 11-17-2012, 06:12 PM   #2
Connar92
My Ride: 330 vert
Check out willitfit.com tells you all the specs and how there different when you put the details in
Connar92 is offline   Reply With Quote
Old 11-17-2012, 07:10 PM   #3
k20z1 L
My Ride: 04 330ci
Dick
Old 11-17-2012, 09:04 PM   #4
j_block
My Ride: 2003 325i
Originally Posted by k20z1 L View Post
Dick
I just went to that site. Haha wtf
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 11-17-2012, 11:10 PM   #5
k20z1 L
My Ride: 04 330ci
Me too.. Knew it was gonna be porn but did it anyways
Old 11-17-2012, 11:16 PM   #6
Trashcan
My Ride: 2002 330ci
I'm running 245/40/18's all around on 18x7.5 all around so you should not have problems with them being to wide for 9.5's
Trashcan is offline   Reply With Quote
Old 11-17-2012, 11:21 PM   #7
k20z1 L
My Ride: 04 330ci
Finally someone with valuable input.. Thanks man, I'm worried about the height though bc I'd be cutting it close. Probably gonna scratch the winter tires and just get all-seasons for the winter and such (much easier to find wider sizes). I have Potenza summer tires on now and I'm scared of what the winter will do to them.. Thanks again!
Old 11-18-2012, 01:15 AM   #8
Trashcan
My Ride: 2002 330ci
I would be less worried what winter will do to your current tires and more worried if you make it out of your driveway, and if you do manage getting that far, staying on the road.
By height do you mean sidewall size? If your car is crazy slammed it could be an issue, but stock height or even a mild drop should be fine.
i know you probably hate the wheels (came on the car and i will probably replace this coming summer), but that point aside you can get an idea of how the sidewall fills the wheel wells
Old 11-18-2012, 01:24 AM   #9
Trashcan
My Ride: 2002 330ci
Old 11-18-2012, 08:22 AM   #10
Connar92
My Ride: 330 vert
Haha sorry.... Try will they fit.com that should help :/ my bad lol
