***The Official M56 SULEV Warranty Documents, Check-in, and Questions Thread*** - Page 7 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 49 votes, 5.00 average. Display Modes
Old 11-10-2012, 10:28 AM   #121
gselsidi
My Ride: 2005 325i M56
Anyone have experience or know if the vanos is covered under warranty? As I saw it mentioned in one of the documents.
gselsidi is offline   Reply With Quote
Old 11-10-2012, 12:37 PM   #122
briangl92
My Ride: VQ37VHR
We get the same VANOS as the M54s, just with different programming. I'm honestly not sure if its covered or not. I never thought about that one.
briangl92 is offline   Reply With Quote
Old 11-10-2012, 12:38 PM   #123
briangl92
My Ride: VQ37VHR
Yeah I will find out soon enough lol. And hopefully when the car goes another 49k the pump will start to fail and get it replaced lol, maybe drive extra hard to give it some help lol. I just messaged the guy on another thread to see if he went through with it.
How are dealers with warranting things? I would assume they would love to do it as I'm again assuming BMW pays them for labor correct?
Not necessarily. I was hassled over it and they said it only had a 7/70k warranty. I argued and they eventually warrantied it.
Old 11-10-2012, 12:41 PM   #124
gselsidi
Anyone have a contact number for someone at bmwna? Who deals with the m56 and warranty issues? It seems like the VANOS is too broadly vague in the documentation but it does mention it. Want to confirm these things before I even go to the dealer, who have no idea.
Old 11-10-2012, 12:43 PM   #125
gselsidi
They even mentioned new pistons that add to the emissions efficiency so technically that seems like it should be covered also.
Old 11-10-2012, 12:51 PM   #126
briangl92
My Ride: VQ37VHR
I think anyone should be able to help you as long as you have your VIN (not 100% sure, just guessing). The only time I've ever called them was to file a complaint.
Old 11-10-2012, 12:54 PM   #127
briangl92
My Ride: VQ37VHR
Hmmmm I know the piston diameter is the same - our VANOS uses the same seals as the M54. As far as being a different part, I thought they were the same I'll check again
I know the actual engine pistons are different - they have a different design on the combustion face.
Old 11-10-2012, 02:33 PM   #128
gselsidi
Yes I meant engine pistons not vanos, I called the dealership gave them my vin they still seemed clueless going to call bmwna first to confirm everything with them before I start dealing with annoying dealers
Old 11-12-2012, 12:23 PM   #129
gselsidi
BMWNA is pretty useless also i keep getting the same women telling me to go to the dealer haha. I saw someone get their camshaft sensor replaced.
In documentation it mentions, "free from defects in materials and workmanship which cause any part that can affect emissions to fail to conform with applicable requirements or to fail a camlifornia smog check test or EPA approved short test for a period of 3 years or 50,000 miles or 15 years or 150,000 miles for the SULEV"
It seems from that statement that if any failed component is causing you to fail your emissions inspection it has to be replaced and is covered under 150K. Such as MAF sensors, Oxygen sensors, im going as far as if you have a cracked cylinder causing your car to fail emissions by leaking oil ect. it would be covered.
This is what I am getting reading this will try to keep contacting dealers and BMWNA and hopeflly get an answer. I know someone replaced their camshaft sensor under warranty anybody else replace something other than the fuel tank/pump or things mentioned on the emissions list?
Old 11-12-2012, 12:29 PM   #130
Amoeba
Amoeba's Avatar
My Ride: his: zhp hers: 325ci
Send a message via Yahoo to Amoeba
For what it's worth in California a check engine light automatically fails a smog test. So basically anything that causes a CEL should be covered.
Amoeba is offline   Reply With Quote
Old 11-12-2012, 12:30 PM   #131
gselsidi
Same in NJ
Old 11-12-2012, 01:11 PM   #132
gselsidi
I figured I'm going to use the simple and dumb way of dealing with this. It seems every time you try to talk to people normally they fail to help or comprehend. Will take it to DMV inspection get the failed inspection smog test, take it to the dealer and point at the paragraph. Instead of trying to convince them camshaft sensor/vanos/maf sensor affects emissions. Let them figure everything out.
Old 11-16-2012, 01:01 PM   #133
briangl92
My Ride: VQ37VHR
that's not a half bad idea.
Old 11-16-2012, 03:33 PM   #134
eneka
My Ride: 2003 325i
so a year ago i had my secondary air pump replaced..now the check engine light is on again with the same p1411 code the pump still runs if I reset the code so I'm guessing it's either the valve or on of the tubes are leaking..
eneka is offline   Reply With Quote
Old 11-18-2012, 10:35 PM   #135
Snapasaurus
My Ride: 2005 325i SULEV
I read somewhere that the m56 has the 330 air intake system. is this true? I've been looking for a CAI and I dont want to order the wrong one.
Also, has anyone done a muffler delete for the m56? comparisons to a regular 325i?
Snapasaurus is offline   Reply With Quote
Old 11-18-2012, 10:39 PM   #136
gselsidi
That's what I remember reading also. On another topic I noticed that our rear bumpers are different also or maybe just mine? mine has the bottom part cut out kinda like the zhp one. Anyone Know anything about this? I'm asking because I was interested in a carbon fiber diffuser later on and it seemed like it might fit.
Old 11-18-2012, 10:43 PM   #137
Snapasaurus
The cut out by the exhaust?
Old 11-18-2012, 10:58 PM   #138
gselsidi
Yes not just the exhaust though, a lot of the bottom part is cut out. Kinda makes a elongated arch from one side to the other. I will try to take a picture tomorrow and post.
Old 11-18-2012, 10:59 PM   #139
Snapasaurus
Okay, I think I have an idea of what you're talking about though.
Old 11-18-2012, 11:02 PM   #140
gselsidi
It looks very much like this mine just seems to be missing the black piece.
http://www.reveuro.com/inventory/bmw...ancepkg_17.jpg
m56, sulev
