Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#1 |
Help picking a sub
Hello all,
I've been in the process of upgrade the sound system in my 330ci cabrio. So far I've replaced all the speakers with the BSW stage 1 kit and am pretty satisfied. Next up is the Sub. I've looked at the following options. BSW Stealth Sub Kicker Solo Barric 8" using this enclosure http://fgseonline.com/shop/bmw-coupe...sub-enclosure/ Or a 12" down firing sealed box with a 300 watt JL12" I'm looking for something clean, punchy and very tight. The Solo Barric is probably the most punchy, but its only 8". Will that be enough for thick low reaching bass? Or will the sealer 12" deliver a deeper sound since its significantly larger? The downside of course is that I'll lose a good chunk of trunk space, which I would like to avoid. Finally, can anyone say anything good about the BSW kit? Is it worth the $700? It only comes with a 230 watt amp, so its gotta be the least punch of the three right? Can anyone share some insight on this? Thanks! |
#2 |
I'll sell you a pair of 12" solo-barics if you're interested.
-Mike
** Removed ** Ask an Insurance Adjuster Anything Cup of Joe for a Joe! http://www.greenbeanscoffee.com/coj/ buy my O.Z. Ultraleggeras! |
#3 |
Nah, they're too big. I'm looking at the 8" since it'll fit in the ski hole with that enclosure.
#4 |
I figured as much. They are definitely big. I know the s/b's are great speakers, but I'm not sure I'd ever go with a single 8 inch sub. I just don't think any single 8 has packed enough punch for my tastes from a subwoofer.
-Mike
#5 |
So you think a 12" JL would be a better choice? I'd really hate to give up any more trunk space though, its super tight at is.
#6 |
Yeah, you might be alright with that. Honestly it's been a long time since I messed with any car audio stuff.
-Mike
#7 |
Thanks, this car has been a real PITA to figure out.
#8 |
Best 8" is a Sundown sa8 v2. Those suckas hit soo hard.
Sent from my SPH-L710 using Bimmer App |
#9 |
The enclosure that I found only fits the Solo Baric since its square.
#10 |
Can't go wrong with the sweet onion chicken teriyaki sub from subway
#11 | |
My local installer recommended this ExCelon sub: http://www.kenwoodusa.com/Car_Entert...rs/KFC-XW1000F We installed it in the coupe version of this enclosure: http://www.wickedcas.com/product.php...&cat=10&page=1 I'm driving it with 350W RMS from the fifth channel of a Kenwood Excelon 5CH AMP mounted neatly and hidden in the factory amp location. It pounds if I want it to but mostly I set it for clean tight complementary bass. I still have most of my trunk space too. Could not be happier with it. With an amp it should come out around the same as the BSW setup, but I'm sure this offers more and takes up less space.
#12 |
I have 2 "12 inch L7 solos" in my car.
I set it up a little different because I need my trunk. check it out. http://forum.e46fanatics.com/showthr...434&highlight= |
#13 | |
(I bet that absolutely pounds. )
![]() Last edited by RJDaly28; 11-18-2012 at 11:14 PM. |
#14 |
Pounds hard. The point I was trying to make is you can really get a lot in the truck if you can get creative enough. Although I also do not know what the trunk in a very looks like.
#15 | |
The OP could probably keep a little more space available with one of the newer digital class D 5 channel amps to run the whole thing - like one of the newer tiny Fosgates or the exCelon 5-ch I'm using since it will fit (with a little work) into the factory location. I haven't tried the Fosgates, but the Kenwood D-class 5 channel is awesome.
#16 |
To the OP:
I just installed the BSW sub and amp in my 2006 330Cic. Several nice things about this package. - The BSW Bass Speaker has lots of punch. So much it will "reveal" loose parts in your car......With the top down, I get a lot of "nasty" looks. Only once did a person roll their windows down to listen. With the top up, nobody can tell the source of the Bass...... - The BSW AMP allows for ample "tuning". I have mine at only 1/3 of Max Gain. (all three potentiometers). The Bass setting on my radio is set to the lowest setting. This allows for the most dynamic adjustment of the Bass for different music genre and media (CD versus Radio versus Line-in). - The BSW AMP is small. Small enough to "hide" behind the right rear arm rest panel - easy access and there is room behind the armrest mount for your amp. (btw, the BMW radio amp is mounted behind the left rear arm rest panel. (see install instructions at BSW). The signal lines can run from the left to right with the wire loom already running left-to-right under the edge of the rear carpet. The take-away -> no additional room was taken up with this install - anywhere that's visible or readily accessible. The goal was clean Bass, quick install (4 bolts for sub enclosure install), hidden installed components (being a 'vert, I need all of the trunk space I can get. This system is worth it........ I've still got a few sources of "loose" parts that I've got to attend to....in areas that have never been accessed since I've owned the car.....So, until I address those problem areas, I've turned the Amp down to 1/4 of Max Gain. With the windows and top up, this plenty of Bass. If you plan to do the Bass Speakers, I'd recommend that you do all of your speakers from BSW. Yes, they too are worth the $$$, but for other reasons. |
#17 |
A Digital Design sub will blow anything outta the water...thats all me and my friends have ever used. It will definitely give you tight and punchy bass. I have a newly reconed DD 2512 for sale if you're interested.
#18 |
DD's are definitely the best subs but they are expensive. So worth the money unlike that JL crap
