Old 10-30-2012, 12:53 AM   #1
demoultrie
My Ride: E46 2001 325xi
Can you use a used Transmission control module
I was told that my transmission control module is gone and my car is in limp mode. The indy told me that i have to get a new one and have it coded to my car because a used one will not work because the VIN is associated to each car, The dealer states the same and the cost of the module is $1500 new?
Is it possible to get a used one recoded and if so who does it?
Thanks,
demoultrie is offline   Reply With Quote
Old 10-30-2012, 01:05 AM   #2
SteadyMobbin
My Ride: ImolaZHP 6spd M/T
What codes were pulled?
SteadyMobbin is offline   Reply With Quote
Old 10-30-2012, 01:34 AM   #3
demoultrie
They didn't tell me it was pulling any codes. He said the put a tester on it and the dash lights went off. I took it to another tranny place and he told me they could not connect to the transmission. I'll check to see if it was pulling codes from this place.
Old 10-30-2012, 01:54 AM   #4
SteadyMobbin
Are there any lights on the dash board...? You should definitely figure out what codes were pulled before doing anything...
Old 10-30-2012, 02:24 AM   #5
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Not sure about the xi's but that doesn't sound right at all. When I was recoding modules during my tranny swap I dont' recall there being any programming menus in the EGS (transmission control module). To be honest, this is all conjecture at this point.
/// MODS
Old 10-30-2012, 08:26 AM   #6
WALKD U
My Ride: Just Fast!
Can Use any egs. I'm using one off a diesal 330d
There is a spot on the egs for vin And other info.
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 10-31-2012, 06:48 PM   #7
demoultrie
Sorry about that, I no longer have the 325XI I moved across country and two weeks after moving someone crashed into me and it was destroyed. I forgot to update my profile. I have a 2001 325I automatic now.
They said they could not pull any codes because the TCM would not connect. They only work on BMW's and Mini so I'm assuming they are using the correct scanners.
The dash has the (!) nest to each gear and will not shift out of 4th I believe and also has check engine light on. I took it to autozone when it first happened and with the OBDII scanner they could not pull any codes either.
Old 10-31-2012, 07:26 PM   #8
SteadyMobbin
Go to the dealer and get the codes read before You start throwing money away into irrelevant parts. Try cleaning your maf and see if that helps.
Old 10-31-2012, 11:40 PM   #9
TitaniumCranium
/// Limitless
So the long and short of it is that you can buy a used EGS on ebay. The only thing you need to be aware of is the type of transmission that was connected to the EGS. I think your indy was either clueless or was looking to make a butt raping.
/// MODS
Old 11-08-2012, 08:23 PM   #10
bernzpeed
My Ride: 2001 325i
i have the same problem. My OBD II cannot be read by any of my shops scantools. Dealerships says it's EGS module and it's specific to the car when programmed. I wanted to find out more info about this and if I could reprogram a used one. Is there a possibility to reprogramming used EGS?
bernzpeed is offline   Reply With Quote
Old 11-19-2012, 10:49 PM   #11
bernzpeed
My Ride: 2001 325i
Okay, an update. I replaced my EGS with a used one and the OBD reader read the DME but it failed smog still because I haven't driven the car for very long. I'm keeping my fingers crossed that I don't need to reprogram the EGS.
Sent from my Nexus 7 using Bimmer App
Old 11-20-2012, 12:21 AM   #12
TitaniumCranium
/// Limitless
Pull the codes with a obd2 reader and figure out why it's throwing the code. EGS may have programming for VIN, but unless you have some specialized equipment you're not doing much to the EGS module with BMW standard tools.
/// MODS
Old 01-07-2013, 04:40 PM   #13
demoultrie
So I did get a used TCM and it was programmed with my VIN and worked for a couple months though is still didn't shift completely right. So I was driving the other day and all of a sudden the car jumps back into limp mode but that time much differently. If I turn the car on and off it comes out of limp mode but after a few minutes it's right back in and shifts very slippery. Fluid is good, new filter, it threw p0735 5th gear ratio and they say the fix is the speed sensor. well it's not, after replacing the speed sensor it I had the same limp mode slippy transmission. From what I have found it seem like the valve body has gone bad and it needs to be rebuild or a new/used tranny. I was hoping it was something electrical because it's kind of weird that turning the car on and off with take it out of limp mode.
Old 01-07-2013, 04:41 PM   #14
demoultrie
where did you find the tranny? I shopping for one now.
Old 01-08-2013, 01:20 PM   #15
bernzpeed
My Ride: 2001 325i
my brother bought a 330ci and had the same problem and he ended up having the tranny rebuilt.
update on my EGS. I popped in a used one and worked perfectly and finally passed smog after about 300 miles. car is finally registered to me.
Old 02-02-2013, 08:24 PM   #16
Maxiest
My Ride: 2001 330ci
Did you have to have that EGS programmed? Because I am about to attempt the same thing to clear up my car being in LIMP Mode.
Maxiest is offline   Reply With Quote
Old 02-03-2013, 12:50 AM   #17
bernzpeed
My Ride: 2001 325i
no i didn't at all. it came from a 330ci and i just drove the car about 500 miles before i got it smogged.
Old 02-03-2013, 11:18 AM   #18
Maxiest
My Ride: 2001 330ci
I also have a 330ci, trying to find one that was on my model also. But that's good news. As of now my car won't even shift because of the "limp mode." There is tons of people saying it needs programmed with VIN and what not. I think they are getting the main ECU/DME mixed up with the EGS. I am hoping I don't. Thanks for answering.
Old 02-03-2013, 12:32 PM   #19
WALKD U
My Ride: Just Fast!
I need to repeat myself?
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 02-03-2013, 12:36 PM   #20
Maxiest
My Ride: 2001 330ci
No..... Goodness.
But all you have to do is a simple search and there are other posters that say you have to reprogram it, and I figured they were wrong. I was basically double checking with the bernzpeed because of I knew he just installed one.
As I said, I think in other threads people get DME, ECU, EGS, all mixed up. Saying they couldn't start after installing the ECU and had to have it programmed for their keys and VIN. But I figure they were talking about the main computer (DME).
Thanks!
