Old 11-20-2012, 05:47 PM   #61
Providence
My Ride: HPF Stage 3 m3
Send a message via MSN to Providence
Originally Posted by Twin_Turbo_S54 View Post
I cold start, sometimed the cold start ends up with ERROR message.
Sometimed it completes COLD START.
Thursday, lets meet for lunch.
that sounds wise.
A compound set up maybe? Compound charging....
Thursday it is , I will bring my laptop , lets see if we can flash it again to fix this issue or mine will be also joining your pboxes in UK
Providence is offline   Reply With Quote
Old 11-20-2012, 07:53 PM   #62
BDUB328I
My Ride: bmw 328i S54 sedan (
epic thread. great to see mert back on here, please dont ban him and please dont buy anything from him. lol
BDUB328I is offline   Reply With Quote
Old 11-20-2012, 08:39 PM   #63
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Those are some fancy chicken hawk tire warmers you have there, would you say they provided any benefit? I know they're expensive ($1500-$2000)
Old 11-21-2012, 12:40 AM   #64
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
Would love to know the solution for traction!
MSpired is offline   Reply With Quote
Old 11-21-2012, 09:23 AM   #65
Twin_Turbo_S54
My Ride: M3
They are custom made, you tell the tire size and they build the blanket.
They are good and not good.
What I mean: warm the tires to the desired temp.
Make one full 60-130 run.
After 130 mph coast down, and here is the problem, the tires get colder as the wind @ 130 mph cools tires.
It is like pi...ng against the wind, the wind cools the tires.
I was not able to make the best out of the blankets. I dont use them. They are almost new.
A separate thread regarding traction should be started and put as "sticky".
Regarding traction, there are many variables. So many.
By altering one variable, the overall traction may suffer or improve.
Each M3 is different in terms of power graph, where the power comes on and this has a big effect on the times.
I ve been testing different combinations and was able to cut a 4,23 s, september 2011.
After that I was able to improve traction further, although could not complete a full 60-130 run.
due to my newborn and it was snowing, winter.
In 3rd gear I was able to dead hook, saw 1 g, right before it started snowing.
That was january 5th, 2012. We saw 1 g in 3rd gear, road was very cold and we aborted tests due to snow. It started snowing while I was on the the highway.
On a warmer road surface traction will get better, time will tell
I pray to improve traction to cut a sub 3,5 s 60-130 time.
If I can come up with a sub 3,5 s 60-130 run Ill tell the tricks
Want to engrave the M3 name on the top of the 60-130 list.
Twin_Turbo_S54 is offline   Reply With Quote
Old 11-21-2012, 09:37 AM   #66
SexiPYm3
My Ride: 03 M3
You're out to prove a point I see. Good luck with the sub 3.5 time. Hopefully it comes soon so you can share your secrets!
SexiPYm3 is offline   Reply With Quote
Old 11-21-2012, 11:37 AM   #67
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 11-21-2012, 11:42 AM   #68
E85head
My Ride: E46 M3
Thanks for sharing the photos!
I can see that your intake mani has a special design between the intake pipe and cylinder 1. In difference to for example the hpf mani, where the air has a straight passage. Any particular reason it was designed like this?
E85head is offline   Reply With Quote
Old 11-21-2012, 11:44 AM   #69
Twin_Turbo_S54
My Ride: M3
Would you please explain what you mean?
Old 11-21-2012, 12:08 PM   #70
E85head
My Ride: E46 M3
In a hpf or fsr manifold, the air basicly comes in from the front left hand "corner" of the plenum. On that type of design the air doesnt' have to change direction as much on its way into thecylinders. However. On your design the air enters the plenum in a direction not headed towards the cylinders at the front of the car, but still you seem to be the one making the most power.
I don't know if this was a good explanation as i don't have a wide vocabulary.
Old 11-21-2012, 02:39 PM   #71
Twin_Turbo_S54
My Ride: M3
Well, I see what you ask.
To be sure about the flow of this intake manifold, we installed lambda sensors into the exhaust manifold runners and tested individually.
Pectel allows the use of 4 pieces of 02 sensors.
I am about to put 6 x 02 sensors and 6 x EGT probes at the same time.
We also read plugs after big power runs, on boost only runs.
We also tend to read plugs after spraying nitrous.
The wide band sensor tests and spark plug readings showed that the air flow was OK.
Pectel allows to fine-tune individual cylinders. Assuming that you have a less flowing cylinder you decrease its fuel.
I do use individual cylinder trimming for safety only. Not all cylinders are created equal
Old 11-21-2012, 03:56 PM   #72
basar13
My Ride: Z4M, R8, 525xd, STI
If i can hopefully get my Z4 working i believe i can make a meeting with HPF stage 3 M3, Twinturbo M3 and my Z4M...
A rolling race between this 3 cars Just for fun.
basar13 is offline   Reply With Quote
Old 11-21-2012, 04:06 PM   #73
basar13
I believe the weakest link in twinturbo m3 is the intake manifold. If i was HPF i would donate one to Mert. i believe it would help alot.
Old 11-21-2012, 05:32 PM   #74
Twin_Turbo_S54
My Ride: M3
sounds nice.
Basar, tested at least 10 int manifolds before we chose this last one........
Old 11-21-2012, 06:05 PM   #75
Twin_Turbo_S54
My Ride: M3
What about opening a sticky 60-130 mph & 1/4 mile thread?
GTR and Porsche forums got sticky 60-130 & 1/4 mile threads.
La ilahe illallah = God is one and only
Old 11-21-2012, 06:36 PM   #76
xixixi
Banned User
My Ride: 01 330x-xi
This is interesting
Old 11-21-2012, 08:12 PM   #77
Divexxtreme
My Ride: GT-R
Jake - verified 5.47 on a 0.08% incline with 1-shift. Nice job. FWIW, I've always ran my fastest times on very slight inclines, rather than declines. Helps build boost better, who knows? Works for me.
Mert - Nice thread jack. Way to make Jake's accomplishment all about you.
Name:	Jake, 5.47, 1-shift.jpg
'13 Switzer P700 GT-R, 675 awhp, 60-130 in 5.99, 10.3 @ 135
'07 997TT, Switzer Ultimate *Under Construction*
Past:
'10 Switzer R1K-X GT-R - 1248 awhp, 9.0 @ 164, 60-130 in 3.33
'12 Switzer Ultimate GT-R (Black Edition), 927 awhp on 93 octane - 9.9 @ 146 and 60-130 in 4.3 on pump gas.
'10 Switzer P600 GT-R - 520 awhp
'03 GT2 - 712 rwhp
'01 996TT - 889 rwhp
'06 Z06 - 722 rwhp
'98 Supra - 711 rwhp
'03 M3 - 416 rwhp
Many more...
Divexxtreme is offline   Reply With Quote
Old 11-21-2012, 08:17 PM   #78
Twin_Turbo_S54
My Ride: M3
Scott,
I did not intend to thread jack. I dont need to.
Old 11-21-2012, 09:16 PM   #79
dan avoN7
My Ride: A car
Mert and bdave.. brothers separated at birth?
dan avoN7 is offline   Reply With Quote
Old 11-21-2012, 09:26 PM   #80
STORMER
My Ride: AA SC 98 M3
Yes this thread is all about Jakes run and it is awesome!!! Good job Jake!
Although on a side note that e36 m
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
