Drain plug turned too tight, now loose - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-17-2012, 04:49 PM   #61
Trashcan
My Ride: 2002 330ci
Originally Posted by bluejayranger View Post
Check, I got a quote for approx 200-240 for the entire job, what do you think? (On base, Army operated shop)
Is that including parts or just labor?
Trashcan is offline   Reply With Quote
Old 11-17-2012, 04:58 PM   #62
bluejayranger
My Ride: ...
ccc
bluejayranger is offline   Reply With Quote
Old 11-17-2012, 09:43 PM   #63
jared_wiesner
My Ride: 1999 328i (M54b30)
As a labour price, that's more than fair, I say go for it if you aren't up to the job yourself.
jared_wiesner is offline   Reply With Quote
Old 11-17-2012, 10:20 PM   #64
Trashcan
My Ride: 2002 330ci
If you trust the mechanics to work on your car i would say that sounds really reasonable.
Old 11-19-2012, 05:36 PM   #65
325xittt
My Ride: 2003, 325 XIT
How to remove a spinning bolt if you are lucky
Spinning bolts anywhere stink. This may get the bolt out if you are lucky, especially if Flash is correct and the bolt head is indeed broken and held by a few maybe damaged threads. Take a really small thin flat screw driver, and jam the blade under the head of the bolt and the washer. This cause the outward force required to back the bolt out. Use a small hammer and really wedge the blade between the head of the bolt and the washer. Then gently/slowly (counter clockwise) try to unscrew the bolt using a box wrench. If you are lucky the bolt will catch and back out. Or it may only move out slightly. Re-wedge and keep trying. Move up to a thicker blade eventually it may back out for you. Once you get it out you may have some options. Heli-coils, tap and die new treads etc, as suggested in some of the other responses.
Good luck
325xittt is offline   Reply With Quote
Old 11-20-2012, 03:17 PM   #66
BartenderPlease
My Ride: '03 540i/6 M-Sport
Originally Posted by flashtwosix View Post
don't get taken advantage like this bmw owner
http://www.auto-facts.org/broken-oil-drain-plug.html
one shopped quote him $400 to extract the broken bolt. another shop wanted $1700 to replace the drain pan.
plug is hollow and is design to fracture/break when is over torque. the reason why your drain plug is SPINNING FREELY is because it is broken/fracture and NOT because it or the hole is stripped.
Think outside the box and don't assume like everyone else on this thread.
you can thank me later by simply telling everyone that I am right.
I hope this helps
Uploaded with ImageShack.us
instructions:
Remove the plug. The hex head piece will come off. This will leave the hollow thread.
Use an L shape Allen key. Hammer in the Allen key into the hollow drain plug. Use the other end of the Allen key to twist and remove the broken plug.
This will take u less than 5 mins.
U sound like a bit of an a$$. Talking ab us assuming and having no experience. I have experience in the issue and you are wrong for me. my drain hole was stripped. plug was fine.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 11-20-2012, 07:02 PM   #67
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
Yes and after the OP waste his money on a new oil pan and extraction then I will post a video of how it is virtually impossible to strip an e46 engine oil pan with an oe oil drain plug.
U might not like me but u can't argue with the engineering design of the hollow bolt
sent from my dahc-6900 using Bimmer App
Old 11-20-2012, 08:10 PM   #68
bluejayranger
My Ride: ...
ccc
Old 11-21-2012, 06:07 AM   #69
jared_wiesner
Thanks for letting us know in the end.
Old 11-21-2012, 12:17 PM   #70
bluejayranger
My Ride: ...
ccc
ID:	479003   Click image for larger version
Old 11-21-2012, 01:25 PM   #71
flashmeow
Banned User
First pix looks.very strange. Is that an inside shot of the pan? If so, something looks very different. It looks like a big chunk of the oil pan drain hole housing is missing.
Old 11-21-2012, 01:46 PM   #72
flashmeow
Banned User
here is what a normal engine pan should look like. I have highlight the oil drain plug housing
Old 11-21-2012, 02:07 PM   #73
xixixi
Banned User
My Ride: 01 330x-xi
Yes cuz u obviously have no experience in this issue.
The reason why is oil pan is dripping is not because the thread on his pain is stripped but because he broke his oil pan nut. This is always 99.9% of the problem. Rarely do the pan thread strip because the force that is require to strip the tread will cause the bolt to break first.
The nut is hollow and when it breaks oil will drip out of it.
All he has to do is remove or completely break his oil drain nut and remove it with an Allen key.
People like u and most mechanics will always assume the worst and end up fixing the problem the hard and expensive way.
Thanks Flash
Old 11-21-2012, 02:17 PM   #74
flashmeow
Banned User
Originally Posted by xixixi View Post
Thanks Flash
you are welcome. Based on his pix (I still need clarification of the pix) I think a stripped thread or BOLT are THE LEAST OF HIS CONCERN. something is up with his oil pan
Old 11-21-2012, 05:10 PM   #75
bluejayranger
My Ride: ...
ccc
Old 11-21-2012, 05:19 PM   #76
xixixi
Banned User
My Ride: 01 330x-xi
Grats man!
Old 11-21-2012, 05:25 PM   #77
flashmeow
Banned User
Bottom line, oil pan replaced=happy E46+ happy owner =)
Good for u.
Old 11-21-2012, 06:20 PM   #78
xixixi
Banned User
My Ride: 01 330x-xi
spare pan
ID:	479060   Click image for larger version
Old 11-21-2012, 09:10 PM   #79
jared_wiesner
Ya, If your pic is indeed correct for all oil pans on e46's then it looks like half of the casting of the threads for his drain plug has broken off. In other words the ultimate stripped thread :p there's no way busting his bolt head off would have helped the situation.
Old 11-23-2012, 03:27 PM   #80
BartenderPlease
I didn't say I didn't like you. U just sound like a know it all. And I won't argue with that design bc I know nothing about it. I'm saying that my oil pan was stripped, and the tech showed me so I know that was the case.
By the way, looks like he didn't waste his money huh?
