Old 11-22-2012, 09:42 PM   #1
MrEmitter
My Ride: 2002 330ci
Sale OBD Scanner!
Will this work on our e46? If so, I'm going to buy it. Also, is the brand any good?
http://www.amazon.com/gp/product/B00...tag=gmgamzn-20
MrEmitter is offline   Reply With Quote
Old 11-22-2012, 09:49 PM   #2
shovelit
My Ride: 03 325xi and 04 330x
It's just a code reader.
I'd opt for PAsoft.
shovelit is offline   Reply With Quote
Old 11-22-2012, 10:26 PM   #3
Nerdy46
My Ride: 328i
i got a $15 reader from amazon. works perfect
Nerdy46 is offline   Reply With Quote
Old 11-22-2012, 10:48 PM   #4
Guest021715
Account closed.
You have a lot of reading to do on PA Soft.
That scanner is junk. Plain and simple.
I wouldn't pay $10 for it.
Old 11-22-2012, 10:58 PM   #5
jfoj
My Ride: 330CiC, M5, X5
Not impressed with Actron tools.
Suggest you check out the Launch CReader VI. Although not BMW specific, it does a really good job with real time data, system readiness codes and will actually log data.
You can get one for around $80-$100 out of Asia on ebay or $180 from BAVAuto.
What you will find is you will need a number of tools to be able to really handle and manage these cars.
If I only had 2 tools to choose from for BMW testing, I would have the Launch CReader VI and the BMW Scanner 1.4.0 (PA Soft), these tools are less than a Peake tool by itself, and you can do a LOT more with them!
Old 11-22-2012, 11:30 PM   #6
MrEmitter
My Ride: 2002 330ci
thanks guys! I won't be buying this acron, but now I plan on buying the CReader VI sometime in the future.
Old 11-23-2012, 02:39 AM   #7
evo7
My Ride: 330i
Buy a bluetooth OBD2 adapter($15) and Torque Pro($5) app on iPhone or Android device. You won't regret it. If you're just looking to read and clear code, there's a free version of Torque.
evo7 is offline   Reply With Quote
Old 11-23-2012, 07:05 AM   #8
jfoj
Last I was aware, the Torque app is only for Driod devices.
I have the Toque Pro app and the ELM327 and I do use it, but the CReader is far easier and more reliable in my opinion.
Torque Pro with the ELM327 Bluetooth adapter is probably the cheapest solution going, but does have a steep learning curve.
I have about 8 different scan tools and software packages and I can assure you my CReader is the first tool grabbed and used on any car, the I move on as needed to other tools.
Old 11-23-2012, 07:39 AM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Get pa soft (bmw scanner) that can do A LOT more.
Old 11-23-2012, 07:52 AM   #10
jfoj
Although PA Soft/BMW Scanner is a good tool, I advise people from getting the PA Soft/BMW Scanner 1.4.0 as the first and only tool for a number of reasons.
1. You need a computer to use PA Soft.
2. It does not provide much real time engine management data from what I have been able to gather.
3. Cannot monitor fuel trims.
4. Cannot perform data logging or graphing.
5. It does not provide Emission Readiness Code status.
6. It does not work on other make & model cars.
And I am sure there are things as well that I did not cover.
The issue is with these cars you really need a decent scan tool, and software like PA Soft and INPA to get a full view of what is going on.
The other problem with PA Soft/BMW Scanner 1.4.0 is many novices get their software up and running and then "see" their car has dozens of codes and then they start to worry and get excited about the codes and errors they are seeing. This tool at times can provide too much information and you have to understand what is critical and what may be bad/old data from a simple problem like a low battery.
But the tried and true handheld scan tool is something you can easily keep in your car and have ready at a moments notice, where the software based tools require you to keep a computer with the interface in the car when you travel.
Again, you really need more than 1 tool to get a full view and access to data on these cars. PA Soft/BMW Scanner 1.4.0 is a good tool to have, but may not be the first tool I recommend purchasing.
check, dash, engine, light, scanner
