Old 11-20-2012, 04:59 PM   #21
Twin_Turbo_S54
My Ride: M3
love this manifold. Welds seem to be beautiful.
man, dont sell these, they look like peace of art.
Twin_Turbo_S54 is offline   Reply With Quote
Old 11-20-2012, 09:39 PM   #22
pimpn04coupe
pimpn04coupe's Avatar
My Ride: some hooptie
deleted posts ftw
pimpn04coupe is offline   Reply With Quote
Old 11-26-2012, 11:02 AM   #23
HPF Kris
Past Site Sponsor
My Ride: My Dreams
Turbo Manifold has been added to our website. It'll be an additional $1,400 to upgrade to the DOC Race manifold. Come snag yours today while our end of the year turbo kit sale is still going on!!
http://www.horsepowerfreaks.com/part...s/E46_M3/11037
HPF Kris is offline   Reply With Quote
Old 11-26-2012, 11:10 AM   #24
TrippinBimmer
My Ride: Just Fast!
Originally Posted by DOC_Race View Post
Heatwrap is nice to use as-well commanderwiggins!
We have used ceramic coating on the manifolds for quite a few years and really like the results we've gotten this way as far as exhaust temperature is concerned. The coating decreases that transfer quite a bit, the wrap tends to "trap" the heat in the metal from our experience.
I have notice this as well but there is one down fall using ceramic coating on a turbo applications. Most Common Ceramic Coating can handle up to 1300F until it start to burn off, and start loosing performance. There is also different type of Ceramics can be used as well that will handle up to 2500F
Doc Race - Could you tell us who do yall coating? What the Specs?
-Trip
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 11-26-2012, 11:23 AM   #25
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
-Trip
We coated this turbo manifold. Over the years we tried several coatings from several companies and all of them except for this one have deteriorated. We finally found a coating that withstands all of the abuse our customers put them through and it's been on all of our HPF turbo kits for the past 4 years. Underhood temps are extremely cool with the HPF turbo kits and this is one of the reasons why. Go to a track day and check out the underhood temps after an HPF M3 does a 30 minute session. Quite amazing.
Chris.
HPF Chris is offline   Reply With Quote
Old 11-26-2012, 12:17 PM   #26
Providence
My Ride: HPF Stage 3 m3
Send a message via MSN to Providence
We r all waitin for the dyno pulls I guess
Providence is offline   Reply With Quote
Old 11-26-2012, 12:38 PM   #27
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Chris.
What's the temp difference between coated and non-coated?
My understanding is the issue with ceramic coating is that the metal will fail a lot quicker since all of the heat is trapped inside of the pipes. Any idea on the decrease in lifespan?
I'm asking because you guys probably have more experience with this. Just wanted to put that disclaimer out there so there are no mo' deleted posts.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-06-2012, 02:15 PM   #28
E85head
My Ride: E46 M3
Something holding up?
E85head is offline   Reply With Quote
Old 12-18-2012, 12:59 PM   #29
DOC_Race
My Ride: 03 M3
bigjae1976: With our ceramic coating experiences, we've tested surface temps of manifold tubing while loading the vehicle on the dyno and have seen temperature differences of over 500 degrees. That data is used to reference radiant heat in the engine bay.
As far as the metal failing; ceramic coating is applied to the inside of the manifold as-well as the outside. Doing this reduces the heat transfer into the tubing, which increases the life-span for heat cycles. How far or long, we haven't had a controlled test to gauge these specific results/comparisons.
E85head: We have a few different vehicle setups that are getting fitted with our Tubular Manifolds. We will be quick to share results as the cars come back together and get re-tunes!
DOC_Race is offline   Reply With Quote
Old 12-19-2012, 03:43 AM   #30
E85head
My Ride: E46 M3
The manifold looks great! Looking forward to see the results!
Old 12-25-2012, 10:22 AM   #31
dragosid
My Ride: HPF 2.5 M3
Any updates on this? Dyno sheets etc?
Pulled the trigger! Built engine + 6766 Dual BB + Open Dump + 15/23 PSI - Holy F#@$ this build is insane!
HPF Stage 2.5 - 739rwhp & 581ft-lbs SAE
best 1/4 mile (ST2) 11.77'@123mph 1.9' R/T on Toyo R888 295/30/19
Porsche Cayenne Turbo S - stock
dragosid is offline   Reply With Quote
Old 02-14-2013, 01:27 PM   #32
E85head
My Ride: E46 M3
What happened to this?
Old 02-19-2013, 01:25 PM   #33
DOC_Race
My Ride: 03 M3
E85head: There's a few cars that are awaiting built engine installs along with the tubular manifold. Also another customer that hasn't pulled the trigger on the install of the manifold as-well; all I can do is tap my foot at this point!
I am currently moving and don't have any intention of installing the turbo system on my SMG (stock engine reference) until i'm settled in about April.
I will be sure to update ANYTHING regarding results on this.
