Old 11-26-2012, 04:22 PM   #1
JakeR
My Ride: 2006 M3
Need More Tire!!
I have maxed out what I can fit with stock configuration for wheeel/tire in the rear. Currently running 18' 305. I need more tire!!! I'm not really a fan of full body kits. Rather, really just looking for a way to just increase rear fender space so that can run 345's. -yes I know I'm not alone - Attached are pics of a car that is very much what I'm looking for. It reportedly took 100 shop hrs and gained 50mm. Looks like they tucked the rear bumper under, so no wide body rear bumper was requred. In my area there are very few body shops that will even roll the fenders, much less do the type of custom work that is likely required. Need to gain about 1.5". Willing to ship car to a shop if necessary. Looking for suggestions......Anyone.....???
ID:	479732   Click image for larger version
JakeR is offline   Reply With Quote
Old 11-26-2012, 04:49 PM   #2
MaverickM3
My Ride: gets badge
The shop that did my Widebody.
http://dtmautobody.com/
TazaM3(Vic) - his shop.
http://teamspeed.com/forums/southwes...ted-price.html
:Edit: You might want to think about have them clear bra the under side of your rear bumper. You Will spit rocks and mess up your paint if your fender doesn't completely cover the tire.
Back there.
MaverickM3 is offline   Reply With Quote
Old 11-26-2012, 05:05 PM   #3
Twin_Turbo_S54
My Ride: M3
305 is more than enough to go 4.xx second 60-130.
I ve tested various tire sizes and 305 is ENOUGH.
All you need to do is set the COMPLETE VEHICLE AS PERFECT AS POSSIBLE SO THAT IT HOOKS.
I would not spend any money for widening the rear arches.
My sub 4.xx second 60-130 will be made with smaller than 305 tires as well.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 11-26-2012, 05:30 PM   #4
JakeR
My Ride: 2006 M3
Thanks Mert. But this is not to improve 60-130. I want to improve traction in 2nd gear. As for my 60-130, since I did not spin on my 5.4 sec. pull, I'm confident there is little if any need to improve traction for that.
Old 11-26-2012, 05:31 PM   #5
JakeR
My Ride: 2006 M3
Back there.
Thanks, really appreciated!
Old 11-26-2012, 05:32 PM   #6
JakeR
My Ride: 2006 M3
Do you have a pic of yours?
Old 11-26-2012, 05:40 PM   #7
MaverickM3
My Ride: gets badge
I will take some pics later today.
Old 11-26-2012, 09:26 PM   #8
95silverM
My Ride: 05' IB M3
305 in a r888 or nt05-r should suffice on an 18" wheel; what tires are you running at the moment? Any pics of your current set-up?
05 IB/Blk M cloth 6spd Non-Sunroof
Sold & Missed..
Eurotechniks
EliteEuroCars LLC.
E46 M3 Rolling Chassis
2JZ-GTE:Forged Pistons & Rods,GSC Billet Cams,GSC Springs & Retainers,Ferrea Valves,Custom Turbo manifold w/ PTE 66mm WG,AEM Infiniti,Custom Dash,CAE Shifter,ABC-Clutch Tilton Triple Disk, E46 M3 6-Speed,18x9 & 18x10 EC-7's,Half Cage
B5 S4 blk/blk 6spd Single Turbo shop-car In progress...
95silverM is offline   Reply With Quote
Old 11-26-2012, 09:41 PM   #9
JakeR
My Ride: 2006 M3
I am running nitto555, and have run MT DR. Trust me with the new 6766 and 750whp, there's very little traction in second.
Old 11-26-2012, 09:47 PM   #10
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
My next move is to the 295/45/17 MT's. Under the stock arches, that is going to be the most tire and it should give pretty good traction...
MSpired is offline   Reply With Quote
Old 11-26-2012, 09:51 PM   #11
JakeR
My Ride: 2006 M3
Agreed but are u running my turbo or 6776?
Old 11-26-2012, 09:56 PM   #12
MSpired
Not yet, still on the 6776 for now.
I think the 295 MT will give you more traction than a 345 Nitto due it being both taller and have MUCH more sidewall.
Old 11-26-2012, 10:01 PM   #13
JakeR
My Ride: 2006 M3
Was going to go 345 Mt which I think is a 35 side as opposed to 30 in nitto 345 Trying not go 17s....
Old 11-26-2012, 10:07 PM   #14
MSpired
Well, in that case! Damn! Interested in this!
Old 11-26-2012, 10:16 PM   #15
AirFrcd
My Ride: Mfizzle, and GT-R
Mike:
The tall MTs are very unstable at high speed; I would not feel comfortable running a MT at the Shift S3ctor events, where we hit 170+; perhaps, short bursts of 60-130, but nothing greater.
I can do everything through Christ who gives me strength.
Philippians 4:13
AirFrcd is offline   Reply With Quote
Old 11-26-2012, 10:39 PM   #16
MSpired
Originally Posted by AirFrcd View Post
Mike:
I think they are unstable only when you lower the pressure in them. I was running over 30psi in them and they felt perfectly stable.
Old 11-27-2012, 12:32 AM   #17
InDiGlOM3
My Ride: HPF M3 stg 2.5
Yeah i run 33psi is mine on the street. And ive bounced off limiter in sixth with them. This wasnt the 295/45 thou but the 305/35, not as tall.
Sent from my PG86100 using Bimmer App
Old 11-27-2012, 01:14 AM   #18
MaverickM3
My Ride: gets badge
0 Camber..
Photobucket Pictures, Images and Photos
Old 11-27-2012, 03:28 AM   #19
Twin_Turbo_S54
My Ride: M3
With those you will see 1,1g - 1,2 g in 2nd gear.
Jake, I think 1,2 g in 2nd gear will be satisfactory.
Thats why I think 345 is not needed.
Old 11-27-2012, 01:08 PM   #20
str8dum1
My Ride: VQ38DETT
like others have said, you need a taller tire not wider.
VQ38DETT on twin 6262 with ProEFI128
str8dum1 is offline   Reply With Quote
