Australia
Check out other E46Fanatics members rides in the Enthusist Directory! If you don't have your garage setup, sign up today HERE |
#1 |
Aircon re-gas/service
My aircon is blowing hot air on the drivers side.
I suspect this means I need to re-gas, and probably replace one of the hoses to kill an (as yet) undiagnosed leak, I've tried to call Worx but I'm not getting an answer, any one recommend a good Air con place? I've had enough of Melbourne BMW on kings way. |
#2 |
Is it cooling as it should on the passenger vent ?
#3 |
#4 |
if it needs re-gassing then that should mean there is a leak as its a closed system. So you might need to get them to find the leak and fix it.
#5 |
You may need to regas (gas can include a dye visible under ultra violet light) in order for them to find the leak. They will gas and then check it again in a couple of weeks to try and see where the leak is. They can then repair the problem and may need to regas again.
![]() I am never wrong. I thought I was wrong once, but I was mistaken. Three people can keep a secret...but only if two of them are dead. |
#6 | ||
Heaps of threads in the General section about this issue - sometimes it is a simple re-gas and fix the leak, other times it can be more than that (bad valves and other hardware). As fgin said, it's a closed system and therefore definitely a leak somewhere. Good luck!
![]() I can help with * Reading Codes / Coding your car * R&R FCAs, Tie Rods, Sway links.... * RTABs Need an RTAB tool? Or clutch fan and water pump tools? PM me. |
#7 | |
I'm not going to fix a problem that is "normal" operation, that said I'm also not going to leave a problem unattended. |
