Old 11-28-2012, 05:58 AM   #21
Blocked Out
My Ride: Imola 330i M-Sport
Plenty of people here run conventional oil in their cars and have well over 200,000 miles. Sure properly spec'd synthetic oil is better than conventional oil in demanding conditions and you and most of us are willing to spend more money for it.
Why aren't you willing to spend a few more bucks for the proper coolant w/ distilled water?
Wrong car for you, my friend if you continue to keep taking shortcuts like that.
I take shortcuts? Funny u...
Im gonna be an asshole and answer a question with a question.
Why arent you spending a few more bucks on properly specd suspension parts?why are you taking chances with china parts?
Sent from my X10a using Bimmer App
Original BMW Teile ///
IMG_1725
Old 11-28-2012, 08:17 AM   #22
madunix
My Ride: Silver 01' BMW 325ci
I recently ran a water hose in my 325ci till only water drained out from underneath the et. I then added bmw coolant in there. The dealership told me 2 gallons would be fine. The idiot didnt have a clue, but 1 gallon was perfectly fine, i had to mix it with a gallon of distilled water. I had to reflush my car. Im lucky i didnt break anything. But for a while i thought i did because i was no longer getting heat. I just kept turning off the car, refilling with coolant until i got heat. I was so relieved. I hope your problem may be fixed as easily as mine, because thats all it took for me.
Sent from my SGH-T999 using Bimmer App
madunix is offline   Reply With Quote
Old 11-28-2012, 10:33 AM   #23
Stinger9
My Ride: '04 330Ci
Where is the surprise here. Our coolant capacity is just over two gallons. If you are using your dealer for your source of tech information, that means you're not spending the time here to learn from all this DIY information that so many have carefully memorialized here. Your anxiety regarding no heat could have also been avoided.
When you flushed, did you have the block and radiator drains both open?
Old 11-28-2012, 11:01 AM   #24
My Ride: Lexus
You recommend using prestone and tap water, you run (self-admittedly) the wrong expansion tank cap on your cooling system, and that's just off the top of my head. what other things do you do? oh yeah you talked sh!t about fuel pump PM then it ended up stranding you the morning of your job interview.
want to talk about shortcuts?
Old 11-28-2012, 08:06 PM   #25
Blocked Out
Yes I recommend using Prestone, there is absolutely nothing wrong with it. Its a good coolant and does its job very well.Who do you think makes BMW labeled coolant?
Again, you obviously know nothing about cars and whats what, Im not even going to argue the tap water statement . Tap water is no just fine its absolutely great, go ask anyone whos ever worked on cars and has some experience .Not someone who spends all his life on an internet forum listening to self proclaimed mechanics . Sure you can use distilled water, but tap water is just as good and in some cases even better depending on where you live.
I dont have the worng cap. I have a Genuine BMW ET 1.4 bar cap. It suits my needs perfectly based on my car.And whenever I recommend it to anyone I warn them of the side effects and the benefits of it. You got no point here.
I never said anything bad about a fuel pump,its the heart of the car) I kept on putting the replacement off and I paid a price for it. You got your things messed up here. Other things that I do are illegal and BMW would torture me to death if they found out...
Let me tell you this, you keep learning by the book and Ill keep living the real life. When you finish reading all your books and get off to the real world, you'll find out how different it is.
IMG_1725
Old 11-28-2012, 08:48 PM   #26
Stinger9
My Ride: '04 330Ci
Lots of effort invested in someone who doesn't want to listen to a word written.
Old 11-28-2012, 09:23 PM   #27
wildirish317
My Ride: 2004 325Ci vert
OMG!! Engineers spend countless hours figuring out how to make things work, and last longer, and some idjit comes along and says shite like this!
I used to work in a power plant, and putting tap water (I don't care where you live) into a boiler serving a 100 megawatt turbine would result in shutting down that turbine within a matter of hours.
Granted, these boilers produce 1000F steam, which is much higher (hopefully) than your BMW engine will see, but you still don't want to put tap water in it.
I guess these forums serve a purpose in exposing the "backyard" mechanics' techniques for what they are. Might as well save water and use urine with your Prestone.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 11-28-2012, 09:59 PM   #28
Alex323Ci
My Ride: M3 & 323Ci (sold)
Yes I recommend using Prestone, there is absolutely nothing wrong with it. Its a good coolant and does its job very well. Who do you think makes BMW labeled coolant?
Again, you obviously know nothing about cars and whats what, Im not even going to argue the tap water statement . Tap water is no just fine its absolutely great, go ask anyone whos ever worked on cars and has some experience .Not someone who spends all his life on an internet forum listening to self proclaimed mechanics. Sure you can use distilled water, but tap water is just as good and in some cases even better depending on where you live.
I don't know of anyone who will agree with this post. I'm afraid you're all alone on this one. You want to use "distilled" or "ionized" water as it's 100% H20, and does not contain any minerals, additives, or impurities that will adversely affect the cooling system and engine cooling passages.
Old 11-28-2012, 10:14 PM   #29
madunix
this sh!t cracks me up..
Old 11-28-2012, 10:47 PM   #30
My Ride: Lexus
uh. lol wut
Old 11-28-2012, 10:49 PM   #31
My Ride: Lexus
You said it best, my friend. I call these "backyard mechanics" barnyard boys. You say potato, I say tomato
Old 11-28-2012, 11:01 PM   #32
lcoleman
My Ride: '79 Massey Ferguson
I have a challenge for the distilled water faithful--find me one, just one, single repair shop or dealership who uses distilled water. It's much more "professional mechanic" than backyard.
Modern coolant is good enough that it doesn't make much difference. Now...distilled is better, and the notion that tap water is better is absurd. As is the idea that a 1.4 bar rad cap is an upgrade in any way, but hopefully we won't go there again.
Old 11-28-2012, 11:04 PM   #33
Stinger9
My Ride: '04 330Ci
Yeah, we won't go there again for sure.
And I'm going to put my tooth under my pillow tonight and get a brand new shiny quarter under there in the morning!
Old 11-28-2012, 11:07 PM   #34
Zell
Zell's Avatar
My Ride: so turbo wow
It's not "better," that's incorrect, but it won't harm your system if you flush it every two years. The coolant is designed to take high mineral tap water. Distilled is ideal, but you can use tap water. Dunno why you would seeing how cheap distilled is, but you can.
Old 11-28-2012, 11:12 PM   #35
Stinger9
My Ride: '04 330Ci
They're not exactly my standard for excellence! Weak defense to quote their example. That's why I take pains to DIY as much as possible.
How about instead I find you twenty pro shops that have left loose bolts, cables out of their brackets, washers missing under bolts, etc.
50% of the time when I get my car back, I have to check and redo things that they've overlooked. Oh me of little faith!
Happens everywhere. Guy who cleaned my 125hp boiler last week didn't tighten all the bolts around the breech gasket when he bolted things back together.
Had to go around with my socket wrench after he left.
Old 11-28-2012, 11:16 PM   #36
///MPR77
My Ride: 02 ///M3 Tri-Ped
This....100%
Old 11-28-2012, 11:41 PM   #37
lcoleman
I am inclined to agree, but every shop does it, not just the bad ones. DIYers make mistakes too, distilled or otherwise. Professionals have the experience to know it doesn't actually make much difference.
Old 11-28-2012, 11:42 PM   #38
My Ride: Lexus
As others said, bad example. It's not in a shop's best interest to do things with a passion or to ensure your car doesn't have deposit build up internally. What owner is going to go "HAY U USED TAP WATER IN MY ENGINE! UR FAULT MY RADIATOR CLOG!"
None.
Distilled water is $1. Too much to ask?
Apparently
coolant, water, water wetter
