Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Braking and Speed Vibration
Hi,
I have a 2002 330 Sport and It vibrates badly when I brake. This gets worse as I get faster. There is no vibration when driving under about 60 but by 80 it is bad, but not through the steering until I brake, then the whole car vibrates. I have replaced the front and back disks (rotors) and the pads, the front lower suspension arms ( with Meyle ones) and the front arm bushes and anti roll bar bushes (sway bar) The latter are both Powerflex. I have also had the wheels balanced. Currently I dont know whether to start on the rear bushes, wheels or sell the car! Even though it still runs great and has never let me down in the 6 years i have owned it. It has done about 107,000 miles.I am tearing what little hair I have left out with this, so any suggestions welcomed, Thanks. |
#2 |
What's about the wheel bearings? Have you check them?
#3 |
My Ride: 04 M56,LC 100,RX300
I had a similar problem, replacing the rotors and pads solved it.
Sent from my ADR6400L using Bimmer App
#4 |
I have replaced one of the front wheel bearings and sont hear any noise from the others when I jack up the car and turn the wheels, which I would expect if it was them, but it is possible. The rotors and pads was my first thought as well, unfortunately didn't make a difference. I am using EBC green stuff pads, so I suppose they could be the cause.
Thanks |
#5 |
My Ride: 99 M3
check wheel bearings
check tie rod ends and inner tie rods
