Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
How to upgrade auto tranny?
hello guys,
i´m curious about all those forced induction guys running auto trannys and sometimes even run shorter diffs. how to those guys prevent their transmission from going into limp mode at high speeds? i dynoed my car (2002 330iCA with 3.91 diff) yesterday at 236hp in fourth gear were torque isn´t limited and when measured in fifth gear the transmission ecu lowers the power to 204hp. thats exactly why the car feels awefull in fifth gear at speeds over 200km/h. It accelerates easily to 200km/h in fourth gear just to flatten out at 220 in fifth gear. is there some tuner able to unlock this limiter? i really want to get rid of it Last edited by daniel_f.; 11-24-2012 at 03:39 AM. |
#2 |
swap it for a manual? i sold my complete swap for $1000. im sure the guy who bought it was very happy with it
CHECK OUT MY M3 SEDAN SWAP!!
http://forum.e46fanatics.com/showthr...978&highlight= AND MY 328I PARTS FOR SALE http://forum.e46fanatics.com/showthr...057&highlight= ![]() SPONSORS: |Good 'N Plenty Restaurant, 150 Eastbrook Road Smoketown, PA| |TheBMWpartStore.com| Last edited by BDUB328I; 11-24-2012 at 08:38 AM. |
#3 |
Nope, will stick with auto as i´m driving in traffic jam to often.
#4 |
My Ride: ZHP Custom Stage 3.5
any tranny mods?
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
#5 |
the tranny itself is stock, overhauled at 99.000km with now 24.000km used. i´m running Z4 Software and the egs was upgraded with the economy mod from eduard aka megawatt. the diff was changed from 3.38 to 3.91 which gives much better response.
just to be precise: i don´t want to go FI, i´m just curious if the FI guys have the same problem like i have right now. 5600rpm in fifth gear, everything is well. 5700rpm in fifth gear and the tranny goes into limp mode. I just want to get rid of that secondary speed limiter in the tranny ecu |
#6 |
Im new to the Force induction myself but I am doing a complete ZHP manual tranny conversion swap, including drive shaft and differential and with UUC lightweight flywheel and clutch setups. I pretty much have everything now. Yesterday was my go crazy and purchase and pick it all up day.
#7 |
I was having trouble finding everything to upgrade my steptronic so manual was the next best thing.
#8 |
I have hit 155 on my step with no issues. But that before the eco mod.
#9 |
Well, ZHP uses GM tranny, maybe the limits are different to my ZF.
It seems to depend on the rpm´s rather then the speed itself. the car made 240km/h with the long diff, and now it goes 220-225km/h with the short diff, as the tranny ecu lowers the power to around 200hp |
#10 | |
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected Last edited by TrippinBimmer; 11-25-2012 at 05:25 AM. |
#11 |
well, 155mph is pretty much 250km/h which is reached at 5700rpm. i guess the zhp egs is limited to higher rpms due to the shorter diff.
#12 |
My Ride: 2006 E46 330Ci ZHP
My ZF tranny out of my ZHP is sitting up at IPT getting the complete upgrade overhaul as it started slipping in 2/3 and 3/4 shifts. The OS Giken also set off the codes about "wrong wheel speeds". I should have it back end of next week. We will see.
Jim My garage tells you what has been done to this ZHP |
#13 |
about how much is the cost of having one of these auto tranny's built? and what is included
http://forum.e46fanatics.com/showthr...978&highlight= AND MY 328I PARTS FOR SALE http://forum.e46fanatics.com/showthr...057&highlight= ![]() SPONSORS: |Good 'N Plenty Restaurant, 150 Eastbrook Road Smoketown, PA| |TheBMWpartStore.com| Last edited by BDUB328I; 11-28-2012 at 04:53 PM. |
#14 |
5 Grand
#15 | |
58mm of Bliss
I was getting tired of fielding questions when all I have is a lump in the corner of my shop for 2 years without any use. |
#16 |
If you can find it at dealer cost it is around 1500-1800 to rebuild. Mine was $1550 on my 323ci.
Sent from my NexusHD2 using Bimmer App |
#17 |
58mm of Bliss
#18 |
#19 |
Level 10 can build the auto's for up to 750tq
http://www.levelten.com/SearchResults.asp?Cat=29 -Shawn-
#20 |
I am just getting started with a build using a Level 10 tranny, upgraded with every option they have. You can follow the results in the thread here ... http://forum.e46fanatics.com/showthread.php?t=958415
