Help me figure out multiplicative adaptation issue - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-29-2012, 01:39 PM   #1
fernando629
My Ride: 325Xi 2001
Hi guys, first car is 2001 325xi, with 77K miles.
I've changed:
Fuel filter
All vacuum hoses
Both intake boots
Air Filter
CCV
Air filter box oring
CAM position sensor exhaust side
Cleaned:
ICV
Throttle body
Valve at SAP, replaced gasket
Resealed DISA
I've been battling codes P0171 and P0174, that seem to have gone away since I replaced my fuel filter. Before I replaced the fuel filter, I would reset my adaptations and the multiplicative adaptations would max out at 12% (both banks) within a day or two, SES would follow.
After replacing my fuel filter, the multiplicative adaptations take more than two weeks to max out at 12% (both banks). I ran with those values for about 2 days, but no longer get codes P0171 or P0174. SES no loger comes one either.
So, I'm not sure if what I looking at is still a vacuum leak, bad MAF, bad O2 sensors or if my pump is failing. I tested preassure at the rail about 2 months ago and it was above 50psi (don't remember the exact number).
Also, I'm getting codes: (from INPA)
65 Cam shaft position sensor (intake side)
Car has shut off about 3 times and this code has shown, error not present when pulled
18 Air mass sensor (is this code for the MAF or also for the CPS sensor?)
Error not present when pulled
What do you guys think?
fernando629 is offline   Reply With Quote
Old 11-29-2012, 05:23 PM   #2
fernando629
My Ride: 325Xi 2001
No ideas
Old 11-29-2012, 05:44 PM   #3
E30Gelardi
My Ride: E30
Could it be a Vanos issue causing your timing to be off?
Did you smoke test the intake system for leaks to ensure no vacuum leak.
What about a slight exhaust leak tricking the o2 sensors?
E30Gelardi is offline   Reply With Quote
Old 11-29-2012, 05:46 PM   #4
Caden
My Ride: 2012 Genesis 5.0
It is possible that your pump is on the way out. That's how it was for my car and then a couple weeks later bam, my pump is dead. When and if you decide to order it, the best place would be bmaparts.com coupon code specE30. I think it's 5 percent off or something. Anyways, good luck man.
Caden is offline   Reply With Quote
Old 11-29-2012, 05:47 PM   #5
fernando629
My Ride: 325Xi 2001
I did a smoke test and found no leaks....makes me think faulty MAF, values at idle are always at around 8
Not sure about the vanos, but don't feel any lack in power
Old 11-29-2012, 05:49 PM   #6
fernando629
My Ride: 325Xi 2001
Thanks will order the pump as PM, just want to make sure if it's something else I order all at once.
Old 11-29-2012, 07:06 PM   #7
fernando629
My Ride: 325Xi 2001
Just got home and hooked up INPA again, I cleared these codes last night and they are back on today.
DIS shows these codes:
65= 41 DME: Signal, camshaft sensor, inlet
No signal (P0344 or P0340)
Fault currently not present
18= 08 DME: Signal, air-mass flow sensor
Short circuit to negative or open circuit (P0102)
these aren't related are they?
Old 11-29-2012, 07:17 PM   #8
jfoj
My Ride: 330CiC, M5, X5, E93
Codes not related.
Cam sensors do go bad.
Suggest you try to check your MAF connection terminals to make sure they are tight. Have heard about loose MAF terminals on the E46 from time to time.
You may need to remove the terminals from the connector to slightly tighten them with pliers, but be VERY careful and do not mix up terminals in the connector.
Old 11-29-2012, 07:35 PM   #9
fernando629
My Ride: 325Xi 2001
Codes not related.
Thanks jfoj, will try as you suggested. I will also order the CPS intake side, wierd how it started giving me issues after I replaced the CPS exhaust side (due to codes as well). Guess people are right when they say change them in pairs
