Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 11-29-2012, 08:20 PM   #1
Nerdy46
My Ride: 328i
Caliper Disassembly?
Anyone have any pics of the calipers dissembled for rebuild???
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 11-29-2012, 09:27 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
It's just an 0-ring and seal inside.
Some say that if the piston is shot, don't bother trying to sand it clean...others say that's fine(ish).
You need to blow the piston out somehow...with compressed air, or before you remove it from car...remove pads, put some wood in caliper and press the pedal.
Remanned caliper is not expensive, and if piston is rusted, might be the way to go (pistons are expensive(ish))
No pics from me...sorry.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 11-29-2012, 10:41 PM   #3
Nerdy46
My Ride: 328i
Dmax,
Thanks for your input. My calipers are fine. I was going to disassemble them sometime soon to powder coat them. Maybe ill just pick up a cheap set to coat instead of trying to bang it out in an afternoon.
Thanks again.
Old 11-30-2012, 02:07 AM   #4
My Ride: Lexus
definitely just buy remans. so cheap and fully rebuilt and ready to paint (if desired)
Old 11-30-2012, 02:10 AM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Yeah I'd recommend buying reman calipers if your mileage is near or above 100k miles. At that point the seals in them will probably need replaces soonish and they will be much easier to prep than old used one that are on your car.
Old 11-30-2012, 02:22 AM   #6
paraklas
My Ride: ESS TS2 320ci
http://forum.e46fanatics.com/showthr...ilt+suspension
Old 11-30-2012, 08:14 AM   #7
Nerdy46
My Ride: 328i
Mango, in order to powder coat the calipers i need to pull the seals to do it correctly. So they will need to be disassembled anyway.
Old 11-30-2012, 08:15 AM   #8
Nerdy46
My Ride: 328i
Originally Posted by paraklas View Post
Thanks!
Old 11-30-2012, 08:34 AM   #9
WDE46
My Ride: '13 128i, '04 330Ci
Just use high temperature grill paint. It will look fine and that way all you have to do is masking tape some parts.
Old 11-30-2012, 08:58 AM   #10
RayPooley
My Ride: 320i SE Coupe
I have no pics but I have broken down and repaired calipers in the past without much issue. The rubber boot around the piston tends to fracture, water gets in and can cause rust to form on the exposed piston. If you look at the exploded view for my car the expensive component is the housing. Item 10, REPAIR SET BRAKE CALIPER kit, appears to contain piston, seal and rubber boot for $25, although I would clarify the presence of the piston. The fact that the kit exists is a reasonable indicator that repair is an option to resolving issues. In my case, some years ago, I purchased the seal and the rubber boot. The existing piston was still servicable once the rust on the exposed surface was removed. There was no scoring or pitting on the significant faces. You need to be scrupulously clean when reassembling of course. So I would give the repair a go. Its not that difficult.
http://realoem.com/bmw/showparts.do?...57&hg=34&fg=05
Old 11-30-2012, 09:23 AM   #11
Zell
Zell's Avatar
My Ride: so turbo wow
The labor-to-dollar ratio of remans is ridic.
If you do it yourself, it takes a pretty good amount of time and work, and you may even need additional parts.
Remans cost $50, sometimes have new pistons (if needed), and they clean them all up for you. Totally worth the extra $20-30, IMO.
Old 11-30-2012, 09:30 AM   #12
Wolrab
My Ride: 330Ci MT, 545i SMG
Originally Posted by RayPooley View Post
.... Item 10, REPAIR SET BRAKE CALIPER kit, appears to contain piston, seal and rubber boot for $25, although I would clarify the presence of the piston.
No piston, according to a picture in BavAuto's Web site. It's a seal and a boot.
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-30-2012, 09:37 AM   #13
WDE46
Yeah, that repair kit is just this:
If your piston is bad, you just have to buy remanufactured calipers. That's the most expensive part anyway. Only a few surfaces have to be machined on calipers and the piston/sleeve is by far the largest.
Old 11-30-2012, 09:50 AM   #14
My Ride: Lexus
Well 1, I don't recommend painting them. It looks cheap. However, if that's what you want, then I'd still rather pull apart a reman caliper than an old 100k crusty one. your choice!
Old 11-30-2012, 09:55 AM   #15
RayPooley
I had my doubts because that's what I bought. The seal and the boot. It was on an E36 316i about 15 years ago.
Old 11-30-2012, 11:08 AM   #16
Nerdy46
My Ride: 328i
Powder coating is the correct way to achieve a nice finish. I prefer to powdercoat what I can.
Old 11-30-2012, 11:43 AM   #17
WDE46
It looks less cheap than rusty/dirty calipers. Black painted calipers won't show the dirt either.
Old 11-30-2012, 11:58 AM   #18
paraklas
The OEM rebuilt kit is the cover boot and the o-ring seal. The boot is really thin and can easily get damaged if not inserted properly. Additional rebuilt items for the calipers are the guide pins along with their plastic covers and cap.
The only difficult thing in re-building a caliper is to properly seat the cover boot. Best way is to utilize a tube at the exact diameter with not sharp ends and gently tap it in place.
Old 11-30-2012, 12:03 PM   #19
My Ride: Lexus
no no no. i'm talking about remans.
Old 11-30-2012, 12:52 PM   #20
WDE46
Oh.
I was thinking about cleaning the caliper carrier up real nice and just painting the piston side for a two tone brake look. Think it'll be kinda cool?
