Old 04-29-2010, 01:58 PM   #21
Many330i
My Ride: e90 M3
Originally Posted by ZZen330 View Post
The offset of the OEM rear ZHP wheel is +51, so a 15mm spacer would make it like a +36. Front OEM ZHP is +47 offset.
zhp rear offset is +50mm, not +51!
Many330i is offline   Reply With Quote
Old 04-29-2010, 02:16 PM   #22
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Just a different approach:
I took my 8.5x18 + 255/35's from the rear and installed on the front with no clearance issues at all (stock height) then bought another pair of 8.5's and mounted 275/35's on the rear. I did have to roll my fender lips and beat in the inner fenders for clearance (used the pound and spray paint method multiple times) after I installed front and rear braces so that the rear suspension did not move.
This gave me much more grip AND more aggressive stance.
Hope that this helps.
Jim
Jim Murphy is offline   Reply With Quote
Old 04-29-2010, 02:49 PM   #23
zhp pilot
Falling from 14k ft.
zhp pilot's Avatar
My Ride: is totaled :(
Originally Posted by starlights View Post
Looks good - why did you change though? So were you able to remove your -2 camber at the back by swapping spacers?
Can one run 15front and 15 rear?
I needed more clearance in the rear for the drop. Check the sig for my current ride height. I don't have my fenders rolled. I was able to remove some of the camber; however, I don't remember exactly what it's at now. I can check the printout when I get home today.
'04 Silbergrau Metallic ZHP 6MT
zhp pilot is offline   Reply With Quote
Old 04-29-2010, 04:12 PM   #24
Lestat_
My Ride: E46 318ci M-Sport
mine is slightly lower than stock sport and after trying a few different sizes I went for 12/12. It's not just about filling the top of the fender, you have to keep the bottom half happy too and I don't think it looks good if too much rubber is protruding there.
Lestat_ is offline   Reply With Quote
Old 03-21-2011, 11:25 PM   #25
Cadeez
My Ride: 2004 BMW 330i ZHP
Originally Posted by zhp pilot View Post
The most common set up on the ZHP is 12mm front and 15mm rear. This is what I have.
I gotta know where you got that black 330 emblem from! I want one, looks freakin sweet... Very nice ride too btw.
Cadeez is offline   Reply With Quote
Old 11-30-2012, 12:06 PM   #26
35mphgolf
My Ride: 2004 Imola Red ZHP
Sorry to rez an old thread - but I've searched for a while and can't quite find the answer. I can see that for a stock wheel/suspension ZHP COUPE, the best fitment will be 12mm front 15mm rear. What about a sedan? I'm not quite understanding the whole fitment and ET offset measurements and how it plays into spacers. I've read the threads but it's just not sinking in...
I've got a stock wheel/suspension '04 ZHP sedan and would like to run spacers just to make it look more flush. I've also read that 10mm isn't necessarily a good setup because it's not a "natural"/typical setup or stance...
Thanks!
35mphgolf is offline   Reply With Quote
Old 11-30-2012, 12:14 PM   #27
My Ride: Lexus
I run 15mm rear and 12.5mm on front on my non-ZHP sedan. Just to give you an idea.
Old 11-30-2012, 02:03 PM   #28
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Thanks!
What's going to be perfect is really going to be up to you. You can take a few measurements which help find the sweet spot for spacers on your car. We made a video showing how to take these measurements, I've embedded it below, it should help you figure out exactly what is best for you and your car. Once you figure out how far you'd like to move the wheels out I have a full range of spacers HERE for your car. One more thing to think about when putting spacers on any vehicle is lug bolt length, you'll need extended lugs to allow the lugs to properly secure the wheel to the hub of the car. If you go to the previously mentioned link (or just click HERE) and scroll about half way down the page you'll see spacer kits with extended bolts, on those kits we've already selected the right bolts for that size spacer on your car.
Old 11-30-2012, 02:07 PM   #29
EverydayGetaway
My Ride: 2003 330i ZHP
Man, I really need to get some spacers! Looking awesome guys!
Sent from a phone
EverydayGetaway is offline   Reply With Quote
Old 11-30-2012, 04:20 PM   #30
iya_ke35
My Ride: AW46 ZHP
15mm rears / 18mm fronts
iya_ke35 is offline   Reply With Quote
Old 12-01-2012, 08:03 AM   #31
35mphgolf
ECS - thanks for the video, that's a good help.
But how do the wheel ETs (offsets) play into the measurements?
Old 12-01-2012, 08:33 AM   #32
WDE46
My Ride: '13 128i, '04 330Ci
Do you have a picture that's at a better angle to show the fit of your wheels? You think my coupe would use the same spacers?
For everyone asking about measurements:
Old 12-01-2012, 09:07 AM   #33
cak323i
My Ride: ///M3 & 330i ZHP
Here are a few pics of my ZHP with 10mm front and 12mm rear. I used Turner Motorsport spacers.
Closer shot of the rears
Closer shot of the front
@WDE46 the coupe should have absolutely no issues running with 10mm front/12mm rears.....I will say that you could get away with 15mm rears on a coupe easily....not on sedan.
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 12-02-2012, 08:00 AM   #34
35mphgolf
Cak323: stock suspension and wheels? Looks perfect, literally perfect.
edit: I went to the TM store and see they only have 12.5mm spacers, not 12s.. I assume that's what you're runnin?
Old 06-24-2013, 02:49 PM   #35
halo0
My Ride: '02 330i 5mt
I'm currently running 12.5 front and 15mm rear. I had to do a lot of work on the rear though to get it to fit with how low I am. (I am running 235 tires all around on the staggered zhp wheels).
^Click, stop by and say hi.^ ------ 5% off Redline leather
halo0 is offline   Reply With Quote
Old 06-24-2013, 07:29 PM   #36
zander271
My Ride: 6spd ZHP/5sp XI
I love my 135's but wish they weighted about 10 pounds less each. I'll have to look into doing this to my car to make it look a little more aggressive.
So it sounds like 12/12 is the way to go I don't want to have to roll my fenders at all.
Old 06-24-2013, 07:43 PM   #37
halo0
It really depends how high/low you are. I just cut out some more liner and I'm still rubbing in the rear. I think it might actually be rubbing way up high inside the actual fender itself. I don't think this is going to be solvable unless I raise it up or dial in more negative camber.
Old 06-24-2013, 08:04 PM   #38
zander271
How low are you? I'm going to be doing a full suspension refresh next month. Most likely will be going lower...been thinking about the FSD Koni/Eibach Kit.
Old 06-24-2013, 08:07 PM   #39
halo0
Check out my thread, I just posted pics.
Old 07-22-2013, 03:12 AM   #40
Arpee
My Ride: E30 M3/ 323ci
What is the length of the bolt you used for the rear with 15mm spacer.
I installed a 15 mm o the rear with 1.5 bolt. I thing it messed up the spring inside the rear disk. Its noe making some clicking noise.
Arpee is offline   Reply With Quote
