Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Suspension for non-m e46 with m3 rear end?
Thread title says it all. Non-m e46 with m3 rear end. Do I get fronts for non-m e46 and rears for m3 e46?
#2 |
It depends how much of an M3 rear end you have.
#3 |
#4 |
Bump. Deal goes off by end of sunday and have no idea what to order.
#5 |
My Ride: M3 & 323Ci (sold)
what exactly do you mean by "suspension"?
if you're just talking about shocks and springs I don't recall any reason the non-M parts shouldn't work/fit in the rear too. You will want matching frt/rr components
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF |
#6 |
Shocks, springs and lower sway bars. The retailer has what seems like different sets (shocks&springs)for m3 and non-m3.
#7 |
I'm pretty sure if you have a non-m and only the rear M3 swapped over you'll want the non-m parts. M3 shocks and springs are tuned/valved for the M3 and actually tall. So some aftermarket Sport version of the non-M shocks/springs will be best.
Swaybars, I forget if the M fronts even fit correctly by the endlinks on non-m. and I don't recall if the rear M3 would take a different non-M designed bar. Swaybars you may have to mix. SLO_Town has a write up/thread on oem swaybars that may give options/answers.
#8 |
Front swaybar will fit both M and non M. Rear swaybar M swaybar fits M only, and non M fits non M only due to differential clearance.
#9 |
I would stick with the non M stuff with M3 rear swaybar (or M3 f/r swaybar set). You can go M but it might jack up your ride height. The sprung weight on a M3 subframe is not a whole lot different than a Non M.
