Old 11-30-2012, 07:54 PM   #21
willsbma
My Ride: 99 323i
Originally Posted by topaz46 View Post
I had the same problem with a 330 at work, there is a valve that controls flow to the heater core located near the drivers side near the firewall, I forgettthe exact name of it but if I remember correctly theres 3 hoses that go to it, its kind of a pain to get but its there, if you follow the coolant hoses to the back of the drivers side of the engine bay you'll see it, that could very well be the problem
If that valve was stuck open or closed it wouldn't open/close while driving, it would always be stuck open or closed.
I think your water pump is failing, but that's just my .02 worth of experience with my cooling system. I would bleed properly and definitely keep an eye on the temp gauge and coolant level. The little hole just inside the ET fill neck should piss coolant when there is good flow. Maybe check that out while you're poking around.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 12-01-2012, 06:10 AM   #22
Neotate
My Ride: E46
Just bled the system and I'm still getting the same problem with only getting hotter air once the revs are higher, when idling the air starts to turn colder so it may sound like I have a problem with the heater core valve, does anyone know how much a heater core valve costs and how hard is it to replace?
Neotate is offline   Reply With Quote
Old 12-01-2012, 09:01 AM   #23
WDE46
My Ride: '13 128i, '04 330Ci
I posted this previously:
Originally Posted by WDE46 View Post
Sounds like your car is having a problem keeping water flowing through the heater core. It could be a stuck heater core valve (part #2 in this image):
Part Number: 64118369805 (at least for my 2004 330Ci)
Try bleeding the system before you take this part out to examine it.
TischerBMW actually has the best price I can find (getBMWparts.com). All vendors seem to have a very similar price ($70-75).
ECS has great pictures.
http://www.ecstuning.com/Search/64118369805/ES177235/
I'm not entirely sure that the valve is the problem. One person has suggested your water pump. I guess it's possible, but I feel it is unlikely since your car is not overheating and the waterpump doesn't fade out in terms of flow rates. It breaks the bearing and makes the belt jump off eventually but doesn't lose flow capacity. The problem would be with the valve assuming a valve can get stuck in a position b/w open or closed. If it's stuck partially open then it's just not letting enough water through at idle, but when you increase the RPM, the flow increases and gives you hot water to the core.
You need to inspect these parts above before you buy the valve. It could just be a hose with a kink in it.
Old 12-01-2012, 09:04 AM   #24
Big Geek
My Ride: 2001 325i
It's your water pump/thermostat. Listen to what everyone is telling you. The water pump is moving more water when your revs are high. Hence the warm air when moving. If it was the control valve you would not have hot air at all. But its your money. Piss it away as you see fit.
Big Geek is offline   Reply With Quote
Old 12-01-2012, 09:27 AM   #25
WDE46
I just don't see how it's the water pump or the thermostat. The water pump doesn't just fade out. The impeller always works. The thermostat doesn't control flow to the heater core at all. The heat works if the thermostat is closed or open. In my opinion it has to be the valve or something in that part diagram I posted.
OP, can you tell us your cars water temperatures while at idle warmed up and while driving (at say 60-70 mph) warmed up? This will tell us if your thermostat is broken.
Old 12-01-2012, 10:02 AM   #26
Brinkley
My Ride: 99 328i, 07 z4 3.0
Have you inspected your system, OP, as in getting under the car, making totally sure there are no coolant leaks, removing undertray, running car, making certain nothing is leaking? When I had this problem, it turned out to be a crack in the expansion tank, as I said earlier, that was very hard to find. I saw evidence of dried coolant nearby and after removing the tank I found the crack. I would think bleeding the system, without identifying the problem is pointless.
If you want to test the heater valve, then just bypass it temporarily, see if that fixes your problem. I'm still sticking with leak though. Air in the system will find its way to the heater core.
Brinkley is offline   Reply With Quote
Old 12-01-2012, 10:12 AM   #27
willsbma
My Ride: 99 323i
Sadly mistaken I'm afraid, and this will lead to an overheating situation. My water pump (only 2 years old) had this "fade" problem, where it would circulate and then not circulate coolant. I was finally annoyed and pulled it. Here is a pic of what happened:
The impeller was just sitting there while the shaft spun freely. And to reinforce this even more, the bearings in the pump were quieter than a mouse, so there wasn't any indication that the pump had failed! I found a cheap replacement at Pep Boys for I think $60 made by Bosch with a metal impeller. Good luck with your problem.
Old 12-01-2012, 11:10 AM   #28
WDE46
Good insight. I've never seen that before. I guess it could be OP's problem, but he's not over heating.
Old 12-01-2012, 01:52 PM   #29
willsbma
My Ride: 99 323i
Could be enough flow to keep it cool at idle, but not enough to push into heater core?
Sent from my DROIDX using Bimmer App
Old 12-01-2012, 01:53 PM   #30
tks
My Ride: slower than yours
Coolant flush
/thread.
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 12-01-2012, 02:20 PM   #31
Neotate
My Ride: E46
Had a new water pump put in last year so unless I'm really unlucky I don't believe that has broken down, going to try to replace the heater control valve tomorrow and see how that goes, if anyone has any tips on replacing the heater control valve please let me know
Old 12-01-2012, 06:28 PM   #32
willsbma
My Ride: 99 323i
Dont replace it just yet. Pop the hoses off and keep the electric connected. Have someone turn the heat on and off while looking through the valve to see if the plunger is moving up and down. It only moves a little so keep a close watch
Old 12-01-2012, 08:18 PM   #33
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
There is probably air in the system, bleed the cooling system before you do anything else.
Sent from my ADR6400L using Bimmer App
rizwan1377 is offline   Reply With Quote
Old 12-01-2012, 11:26 PM   #34
EmFiftyFour
My Ride: 03' 330xi auto
How does a bad water pump sound? Im getting a high pitched whistle sometimes when I give it some throttle.. I know I replaced my water pump with a metal impeller (Graf) about 2 years ago.. Im also only getting heat when I rev to about 4k RPM its gonna be a cold winter.. no its not air. as a side note, due to a hole in between my head and block that shoots coolant out, i was forced to resort to a stop leak product. i was fine for about 2 years like this. looks like that crap has caught up and clogged all types of stuff up.
EmFiftyFour is offline   Reply With Quote
Old 12-02-2012, 10:30 AM   #35
WDE46
I thought that a whistle is usually made by a torn intake boot. It varies with RPM (airflow).
Old 01-31-2013, 01:45 PM   #36
nicoled985
My Ride: BMW 325i 2003
I believe you are right! I have a torn intake boot and I get the whistle and I also have the same problem as the threadstarter. Cool air when stationary and hot air when moving. I just had my water pump replaced with a metal one about lesd than a year ago! Im gonna replace my intake boot within the next week. I included a pic down below. Sorry if you guys get offended by the dusty engine. I definitely want to clean it but im new to this!
Sent from my SAMSUNG-SGH-I317 using Bimmer App
nicoled985 is offline   Reply With Quote
Old 01-31-2013, 03:14 PM   #37
sgoetz628
My Ride: 2002 330 CiC
Your last comment was two months ago. What's happened since then and is the problem solved? As you know, other people may have your same problem, so please let us all know the outcome.
I love my car as much today as the day I bought it
sgoetz628 is offline   Reply With Quote
Old 01-31-2013, 03:52 PM   #38
Neotate
My Ride: E46
Sorry haven't posted, went on vacation then came back to reassess the problem. I removed both pipes going into the passenger side of the engine bayland flushed it all out with a hose.. a load of brown gunk came out, put it all back together and still no heat but it cleared out the system. Replaced the heater control valve and flushed the whole system. refilled it and bled it and now i get heat, i also had a minor leak somewhere so i dropped in some leak repairer which stopped the leaking so it was probably a combination of things which caused the issue. All fun and games now i got a whirling noise from the rear offside wheel so it looks like I got bearing to replace when it gets warmer.
Old 01-31-2013, 03:59 PM   #39
WDE46
Holy **** OP delivers!
Old 02-08-2013, 02:52 PM   #40
EmFiftyFour
Why on earth would you use a stop leak product unless you were planning on trashing the motor? In my situation I had a hole in the block.. I didnt have much choice. But to use stop leak when you can just fix it, is beyond retarded, sorry.. That crap clogged my heater core as well.
