Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 11-30-2012, 05:41 PM   #14181
Mr.Makeveli
My Ride: 2001 325i(sedan)
Had to put her back in the damn shop for a new alternator and an oil leak,bmws just look good,thats all!!!
Sent from my PC36100 using Bimmer App
Mr.Makeveli is offline   Reply With Quote
Old 11-30-2012, 08:25 PM   #14182
WDE46
My Ride: '13 128i, '04 330Ci
You'd be less mad if you paid half price for the part and put it in yourself. Alternator takes less than an hour.
Old 12-01-2012, 11:53 AM   #14183
TalinBolen
My Ride: E46 325ci
Plasti dipping my window trim, 1st coat just went on
TalinBolen is offline   Reply With Quote
Old 12-01-2012, 12:18 PM   #14184
My Ride: Lexus
might want to clay bar your car after. looks like you didn't cover enough of the fender might have overspray! be sure to post pics of the trim curious how it turns out.
Old 12-01-2012, 12:26 PM   #14185
E46Moonlight
My Ride: 2000 323i
Had some bubbles on my tires thanks to NYC potholes! Lucky I got warranty on my tires and I got two new tires for FREE!
E46Moonlight is offline   Reply With Quote
Old 12-01-2012, 12:43 PM   #14186
wildirish317
My Ride: 2004 325Ci vert
Got my car back from the body shop after they removed a sickening scratch I put in the hood during a cooling system overhaul a couple of weeks ago.
This was then.
This is now.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 12-01-2012, 12:49 PM   #14187
TalinBolen
My Ride: E46 325ci
I plan to, there's a great DIY on here about doing this it's what I'm going by it says any over spray you can basically peel off, just finished coat 4 and it's looking great tomorrow the wheels are coming off to be sprayed as well
Old 12-01-2012, 12:49 PM   #14188
tock172
My Ride: '12 135i Dinan S2
ECS tuning has spacers on sale, 15% off. I'm tempted to pick up a set of 12.5 and 15mm.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 12-01-2012, 01:09 PM   #14189
ELCID86
My Ride: 2004 330i (ZHP) x2
Automatic garage door? I have a smaller one from when I did mine a few months back! I guess we should add to the DIY...
What'd they charge to get it out?
ELCID86 is offline   Reply With Quote
Old 12-01-2012, 01:11 PM   #14190
ELCID86
I plan to do this when my son brings the car back from college in a week or so. Let us know how it goes!
Old 12-01-2012, 01:13 PM   #14191
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Installed LED tails. Inspected subframe and diff.
Do you ride a sportbike?
Old 12-01-2012, 02:17 PM   #14192
TalinBolen
My Ride: E46 325ci
Passenger sides done! Now onto the driver side
Let me know what you think
Old 12-01-2012, 02:28 PM   #14193
wildirish317
Yeah, auto garage door. I had the front end jacked up and the hood open. I noticed that the hood was close to the door, and made a mental note to close the hood before closing the door. My mental notes aren't as good as the once were.
The fix cost $522. They had to repaint the entire hood since the scratch went to the metal. Bright side: Took care of a few cat scratches and dings in the hood by PO while they were at it.
I bought a new kidney (it got scratched too) from bmwpartstore.com and installed it myself.
Old 12-01-2012, 04:28 PM   #14194
sjacoby112
My Ride: 2002 325ci
painted my window trim matte black the other day (not plasti dip).
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 12-01-2012, 04:52 PM   #14195
Zchild
My Ride: 2000 BMW 3XXi ZSP
Today I replaced all four tires with Toyo Proxes 4 +, replaced the brittle cracked vacuum line between the fuel pressure regulator and the motor, replaced the thirteen year old fuel pressure regulator, reconnected the the hazard switch that one of the locals Indy shops forgot to connect after adjusting my e-brake and using double-sided tape I re-attached the plastic rear door paneling to both rear doors.
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 12-01-2012, 09:52 PM   #14196
E46Moonlight
My Ride: 2000 323i
Techno violet?
Old 12-01-2012, 10:05 PM   #14197
WDE46
Originally Posted by E46Moonlight View Post
Techno violet?
Instagram
Old 12-01-2012, 11:00 PM   #14198
jrosario23
My Ride: 325i 2002
changed the tensioner pulley,idle pulley,belts and radiator
jrosario23 is offline   Reply With Quote
Old 12-02-2012, 09:30 AM   #14199
Robaidh
My Ride: e46 318 2.0 coupe
kidney grills and refurb of handles
i took my kidney grills out and pained them, hope they last and dont get stone chipped :S and refurbed my interiour handles
Name:	primed grills.jpg
ID:	480446   Click image for larger version
ID:	480447   Click image for larger version
Name:	primed handle.jpg
ID:	480448   Click image for larger version
Name:	handle finished.jpg
Robaidh is offline   Reply With Quote
Old 12-02-2012, 10:21 AM   #14200
trentcdrums
My Ride: BMW 323i Sedan
Installed Eagle Eye tails now waiting for my Orion v2's.
Rate This Thread
