Sponsored by BimmerWorld
Old 12-02-2012, 02:17 AM   #1
Bimmer_Addict
My Ride: E46 323i
CAB's failure after 10k miles ECS
Hello fellow fanatics, I purchased these control arm bushings from ECS along with other parts, however these ones as I looked at them when the car was lifted I found the red part sticking out of the bracket. I also hear cracking noises at turns as if I had a messed up axle on a FWD car. Has any one experience this before with this kind of CABS, do I need to buy new ones now or just replace the internal parts with new set from tuner motor sports, is it risky like it would totally come out and I loose control of my car. Any help would be appreciated guys. ECS I would like to hear from you on what's the warranty on this product. I'd ont track my car and I don't drive aggressively.
00 E46 323I current
08 Jeep Grand Cherokee Laredo current
08 E60 535I LEASE OVER
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Bimmer_Addict is offline   Reply With Quote
Old 12-02-2012, 02:48 AM   #2
Bimmer_Addict
My Ride: E46 323i
If I buy this set http://store.bimmerworld.com/powerfl...hing-p281.aspx, can I press it in the stock housing I took off when I replaced by the above mentioned CABS.
00 E46 323I current
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Old 12-02-2012, 05:21 PM   #3
Bimmer_Addict
My Ride: E46 323i
Can any one shed some light on a fellow fanatic?
00 E46 323I current
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Old 12-02-2012, 05:24 PM   #4
WDE46
My Ride: '13 128i, '04 330Ci
You can press out the old bushings and reuse the housing. It is very difficult though and you'll need a press or special tool. You can get powerflex prepressed into the housings for $150. I bought mine from Bimmerworld too and I have no problems. (Powerflex).
You know it is possible to install the bushing too far onto the control arm. There is a certain distance you are supposed to slide them on (at least for the OEM rubber ones). I simply slid mine on so that only a small bit of the control arm stuck out the back.
Old 12-02-2012, 05:25 PM   #5
auto180sx
My Ride: '02 Steel Blue 330Ci
Simmer down man, its a Sunday, give it time and people will respond.
To answer your question; yes and you'll need a hydraulic press to do it. I went with the Rogue Engineering bushings for my FCABs and love them but anything is better then broken ones. I hear good things about Powerflex too.
Good luck and get them replaced ASAP
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 12-02-2012, 09:04 PM   #6
Megalocnus
My Ride: 05 330i ZHP/MT
Just to clarify since you have a 323i, which type of control arms have you got? #5 or #6?
The bushings you bought look like they are made for the new type of control arms (#6)
Megalocnus is offline   Reply With Quote
Old 12-02-2012, 11:44 PM   #7
My Ride: 2016 Lexus
hopefully you didn't stick 66mm bushings on 60mm arms. i dont think the fitment is the same. either way, i'd probably not trust generic poly stuff. if you must go poly, choose a name brand. though honesty id recommend meyle hd
Old 12-03-2012, 12:36 AM   #8
yonmoor
My Ride: Handbasket
Just get the Meyle HDs.
yonmoor is offline   Reply With Quote
Old 12-03-2012, 12:59 AM   #9
Bimmer_Addict
My Ride: E46 323i
I don't know which one i have , and when I changed them I took the old cabs completely out n replaced them with the on in the first post, red n black, I guess I'll do the power flex ones since I have a stock housing, ill measure before I order. Thanks for all who replied though with their inputs, I appreciate it
00 E46 323I current
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Old 12-03-2012, 01:01 AM   #10
silyb0y
My Ride: E46 330
Meyle parts are the worst car parts Ive seen in my life. Their hydrobearings dont even have fluid inside. Therefor -> no hydrobearings. Just buy the original parts made by Lemförder. They are the best you can get.
silyb0y is offline   Reply With Quote
Old 12-03-2012, 02:59 AM   #11
DHK
My Ride: 2002 BMW 325Ci
I have heard about lots of problems with the poly ones. I have also heard a lot of people who swear by them.
The Meyle ones are sort of similar, lot of people swear by them but you also hear a lot of people complaining about defective ones.
I rarely if ever have seen anyone complain about the Lemforder ones though, they may not be the best but they are certainly the most consistent.
DHK is offline   Reply With Quote
Old 12-03-2012, 07:08 AM   #12
WDE46
If Lemforder is OEM, then everyone complains about Lemforder. They are destroyed after less than 50,000 miles.
I think most people complaining about the Meyle HD ones do not install them properly. They must be slid on the control arm a certain distance. If you put them on too far, they will get ripped out. You also have to wait for your lube to dry up (used to slide them on) before driving.
Poly bushings are pretty much fool proof. I have Powerflex and they have been great so far after several thousand miles.
Old 12-03-2012, 08:57 AM   #13
vandyboy
My Ride: 2001 325i
Poly bushings are pretty much fool proof. I have Powerflex and they have been great so far after several thousand miles.[/QUOTE]
I think you are right. It is possible to make mistakes installing any CAB, poly or conventional. I put some Meyle HD CAB on my car and absolutely love them. The front end is tight again. Best $79.00 I've spent in a long time.
vandyboy is offline   Reply With Quote
Old 12-03-2012, 09:47 AM   #14
yonmoor
My Ride: Handbasket
They are pieces of ****.
If by consistent you mean guaranteed to fail in <45,000 miles, then yes, they are consistent.
Old 12-03-2012, 10:15 AM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Just get Meyle or Lemforder and call it a day.
Old 12-04-2012, 12:08 PM   #16
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Those are the MTC Polyurethane Front Control Arm bushings (LINK), they carry a one year warranty from time of purchase. Shoot an email to customerservice@ecstuning.com and they'll get you taken care of.
Did you grease the poly bushings prior to install? If not they do have tendency to make noise under all driving conditions.
Old 12-05-2012, 08:41 AM   #17
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Yup - 45k miles still doing great in mine
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 12-05-2012, 09:01 AM   #18
daves325in2012
My Ride: 2004 330cic
Another Meyle HD supporter here. Very tight, I order the whole control arm with new ball joints and FCAB and outer joint, and I absolutely love them
w/ 15k on them they still feel new!
Meyle or OE are your only choices here unless you want to do Powerflex, but unless you have the budget for a better set of everything else, why splurge for a high-end part when you just ordered MTC brand? Cheap performance and longevity = Meyle HD IMO
daves325in2012 is offline   Reply With Quote
Old 12-05-2012, 09:08 AM   #19
subieworx
My Ride: ZHP, 335, E53, E30
I refuse to install or sell that kind of bushing anymore. Seen way too many failures of that type from many different brands.
Whiteline has some that are awesome. They are stiff and made from polyurethane, but are incredibly long lasting. They require at least a vise for installation, but not a press (although they go in easier with a press).
subieworx is offline   Reply With Quote
Old 12-05-2012, 12:19 PM   #20
Bimmer_Addict
My Ride: E46 323i
Did you grease the poly bushings prior to install? If not they do have attendance to make noise under all driving conditions.
Thanks for chiming in, I did grease them and they were fine when first installed until recently they start doing that cracking noise like I mentioned a broken FWD axle noise and sticking out from the black part. too bad I’m past the year but I will post a pic of how they look now may be someone will tell me what should be done, as of now I ordered some powerflex and I will press them in the old OEM housing I got..
00 E46 323I current
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
