Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 12-02-2012, 10:23 PM   #1
Platinum Plus Quality
My Ride: M54B30
More on stock BMW struts/shocks and mounts (video)
From BMPdesign:
This will generally apply to our cars as well. Pay attention at 4 minutes onwards
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 12-02-2012, 10:31 PM   #2
HacksawMark
Golf Nut
HacksawMark's Avatar
My Ride: 06 Quartz Blue 325Ci
Very good post! Thanks!
HacksawMark is offline   Reply With Quote
Old 12-03-2012, 12:31 AM   #3
2003 325i
My Ride: '03 Orient Blue 325i
A couple small errors but all in all a good video.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 12-03-2012, 12:49 AM   #4
My Ride: M54B30
Yeah sometimes he might get certain terms mixed up or interpreted strangely. not much planning/scripting goes into his videos. but generally the idea he's trying to come across is change your shocks/struts and mounts regularly.
btw i know one of them you're referring to is "weight of the vehicle being supported" technically yes that's incorrect. but i think he was trying to say was that the weight of the car lowered down on the struts/shocks is what should be required to push them down into their natural position as opposed to gravity or light hand pressure.
ever try pushing a bilstein sport (or even a new OE strut/shock) down by hand? good luck! bilstein=probably not happening and oe=you'd need to invert it and push down with a lot (if not all) of your body weight.
Old 12-04-2012, 04:21 PM   #5
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Any videos/DIYs on straightening the sheet metal where the strut mount bolts to?
Originally Posted by Mango View Post
reputable name brand only. no non-name, made-up name ebay teen baggy pants stance meets sideways stickers baseball caps neon sunglasses coilovers
Old 12-09-2012, 01:26 PM   #6
SilverThreeTwoFive
My Ride: 2002 BMW 325i
I think I'm going to be replacing my front struts and mounts on my 325i in the coming weeks
SilverThreeTwoFive is offline   Reply With Quote
Old 01-01-2013, 11:22 PM   #7
ryannel2003
My Ride: 2000 BMW 323i
I just wanted to post my experiences with this as I just replaced the shocks/struts and mounts on my E46 this past Sunday. Mind you this car had 153k miles on a completely original suspension so it's mostly just with age. I had symptoms of the whole car having a "shifty" feeling when going over expansion joints, the rear end was sloppy and liked to kick out a little when going around corners at higher rates of speed, and on rough roads you could actually hear the struts rattling in the passenger floorboard.
Got the rear shocks out first because they were easiest to do and they were completely dead. As in there was absolutely no re-bound when you pushed it down into the shock. I was basically riding on springs back there, and that explains why the rear end was always so finicky feeling. The mounts didn't look bad and had no cracks but I replaced those and put the new shocks in. Moving to the front was more difficult and since this was my first suspension install I was very careful. The front struts didn't appear to be as bad with rebound as the rear shocks, but they were still used for sure. The strut mounts though, they were bad. Looking underneath the mount the whole area was cracked around the mount. On top of that, the rebounds were so harsh from the struts that both front bump stops were destroyed.
Got the springs mounted on the new struts and had the car aligned and the difference is insane. The car handles so much better now. The ride is smoother and much more responsive when going over bumps in the road. There aren't any funny noises coming from the car any longer. It tracks better down the road, though I still need to replace my RTAB and such and get an alignment at BMW because the car pulls to the right a little bit. I didn't pay for that alignment so no biggie there. My whole point here is if your car has any symptoms like my car did and you have over 100k on an original suspension, do yourself a favor and go ahead and get it replaced.
2000 323i | Orientblau | 160k miles
ryannel2003 is online now   Reply With Quote
Old 01-02-2013, 08:32 AM   #8
LeMansteve
Any issues compressing the front springs? Do you have the sport suspension?
Old 01-02-2013, 09:39 AM   #9
ryannel2003
The springs were annoying but we did this at a friends shop so he had a machine that compressed the springs for me. They went on easily enough, though one side of the car sits maybe 1 or 2 mm higher than the other. Not enough of a difference to bother me. As for the suspension, its a non-sport 323i. I put Bilstein Touring shocks/struts on the car.
