Steering Wheel Vibration! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 12-03-2012, 04:58 AM   #1
mojako
My Ride: bmw
I have a problem.
My steering wheel vibrates when i hit 70km/h - goes away when i reach 80km/h, but comes back aroung 90km/h. Very weird.
It also vibrates when i hit the brakes! No vibration when im going 40km/h or less.
What have i done so far?
I have new front rotors (Lemforder) and pads.
New tie-rods/rack ends. New front hub bearings. I just had my front suspension inspected and my FCABs and control arms are still ok.
Front tires are BALANCED. Checked them twice at 2 different tire shops to make sure. Didn't have the rears balanced.
I am lowered on Eibach Sportlines. Stock struts/shocks. I have a .5mm rubber lifter installed right on top of my front springs. I have 18" Original AC Schnizter Type 3s with 225/40/18 tires.
What else should I check?
mojako is offline   Reply With Quote
Old 12-05-2012, 03:32 AM   #2
mojako
My Ride: bmw
No one??
Old 12-05-2012, 08:15 AM   #3
subieworx
My Ride: ZHP, 335, E53, E30
How old are those wheels? Is the hub bore sizing correct for your car? Are the wheels bent at all?
subieworx is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-05-2012, 09:28 AM   #4
lucky_doggg7
My Ride: 2005 M3
Find a shop that has a Hunter Road Force 9700 wheel balance machine that can detect the roundness of the tire and the rim. This machine is able to measure the runout of both the rim's inner barrel, and the roundness of the tire. The Hunter machine will reveal your problem. You have the classic symptom of an out of round wheel assembly, meaning the tire is out of round, or the rim is out of round, or perhaps both.
Old 12-11-2012, 07:44 AM   #5
mojako
My Ride: bmw
@lucky,
that may be hard to find where I am from. But i will consider that. I will switch rims over the weekend to find out if my rims/tires are not round.
@subie,
I think the AC Type3s are hubcentric to the 3 series... not sure though. Bent? Maybe!
Old 01-01-2013, 05:33 PM   #6
daveion2002
My Ride: 2001 330i
When I had this problem a while ago i replaced my front control arms and it went away if that helps
daveion2002 is offline   Reply With Quote
Old 01-01-2013, 05:46 PM   #7
Vincent_m3
My Ride: 04 M3
If you say it vibrate when you brake you might want to check your brake rotor.
Vincent_m3 is offline   Reply With Quote
Old 01-02-2013, 04:37 PM   #8
mojako
My Ride: bmw
@dave,
sent you a PM
@vincent,
i have virtually new rotors... less than 6 mos old. Replaced the front pads as well.
So i had my tires checked, and they are A-OK. No problems. My mechanic said that my rack and pinion could be the culprit. What do you guys think?
I had it rebuilt a couple of months ago. Had all the rubber seals replaced.
Old 01-03-2013, 03:08 AM   #9
boyguan
My Ride: 02 330i
Check play in tie rods and check control arms. Mine was the arms
boyguan is offline   Reply With Quote
Old 01-03-2013, 03:40 AM   #10
mojako
My Ride: bmw
@boyguan,
the mechanic checked the control arms - they are good. I bought new arms already but the mechanic said not to replace because they were still good.
Tie-rods were replaced maybe a month ago.
Old 01-03-2013, 04:09 PM   #11
daveion2002
My Ride: 2001 330i
Did he check the bushings? Do you know how old your frnt control arms are? Some times i just dont trust mechanics i like mine, but he lets things break before replacing them because thats how he is. As for me i like to replace things that are getting old
Old 01-08-2013, 01:36 PM   #12
mojako
My Ride: bmw
You have a point there. Will replace the fcabs 1st and see what happens.
