The Showroom
Old 12-03-2012, 10:46 AM   #1441
smg330
My Ride: 3 series
Took some pictures with my Iphone this morning. You can really see how different the metallic in the wheels changes with different light. Over all im pleased with the way they turned out
DFWeuros.com
smg330 is offline   Reply With Quote
Old 12-03-2012, 03:18 PM   #1442
777eThOd*
/// Power
777eThOd*'s Avatar
My Ride: spins to much
Okay dude you gotta tell me the specs on the rear!! lol. I'm looking at getting some Adjustable control arms for the back but it only gives me from +1 - -3 camber. Is that good enough?? Cause I'm rubbing pretty bad, I got some spring boosters helping it not rub that much lol.
777eThOd* is offline   Reply With Quote
Old 12-03-2012, 03:22 PM   #1443
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
mean as fuq, can u roll at that height?
Old 12-03-2012, 04:10 PM   #1444
smg330
My Ride: 3 series
well I dont know the exact camber adjustment off the top of my head...i will have to dig that up from the alignment sheet. But it is only the factory camber adjuster that is adjusted to the maximum setting. I have my rear fender cut and rolled if that has anything to do with it?
If I bump up the air on all four corners once i can. The rear on all down sits in the stretch of the wheel/ tire so it would damage if i tried to roll all down.
DFWeuros.com
Old 12-03-2012, 04:21 PM   #1445
777eThOd*
/// Power
777eThOd*'s Avatar
Wow thats crazy, someone told me that my fenders were to thick to roll lol..
Old 12-03-2012, 04:50 PM   #1446
w0w
My Ride: 00 323i
looks good dude! makes me miss my gold square setup
daron
w0w is offline   Reply With Quote
Old 12-03-2012, 04:57 PM   #1447
smg330
My Ride: 3 series
they are very thick, you need to have someone cut the two parts where the fender joins and then roll it smooth.
DFWeuros.com
Old 12-04-2012, 08:47 AM   #1448
The Chosen One
My Ride: E46
air is for pussy's dude
The Chosen One is offline   Reply With Quote
Old 12-04-2012, 09:05 AM   #1449
23dilbert
My Ride: 2000 BMW 323I (RHD)
I put in my rokkor suspension this weekend and now when i turn my wheel i can hear a knocking/popping noise from the 2 front suspension. Has anyone had this problem? if so how did you fix it? i have my helpers out. Also how do I post pictures?
23dilbert is offline   Reply With Quote
Old 12-04-2012, 09:23 AM   #1450
murac14
My Ride: 2001 325i
You might be to low and tires are moving the fenders as you turn or your rims are to close to the coils aka mayb spacers. Or something else that I can't think of
Sent from my PC36100 using Bimmer App
murac14 is offline   Reply With Quote
Old 12-04-2012, 09:39 AM   #1451
23dilbert
My tires are not hitting the fenders. It almost sounds like the spring itself.
Old 12-04-2012, 10:11 AM   #1452
Dibaltic
My Ride: 325ci
The spring is popping because of not having any preload, my coils did that same noise once I had put in shorter springs up front. If you're not very low you could put the helper spring back in to help with this noise if it bothers you that much.
Dibaltic is offline   Reply With Quote
Old 12-04-2012, 10:15 AM   #1453
23dilbert
I have a photo of the car attached, I dont wanna raise the car up anymore is there another solution to this problem?
Old 12-04-2012, 10:31 AM   #1454
Dibaltic
My Ride: 325ci
Judging from the picture you posted, if you put the helper spring back in you'd still be able to sit at that height, and probably even still be able to go down some.
Old 12-04-2012, 04:45 PM   #1455
Press22
My Ride: 01 325ci
he probably needs spacers cause the wheel is hitting the strut/spring
EUROSQUAD
My Build Thread
Press22 is offline   Reply With Quote
Old 12-04-2012, 06:01 PM   #1456
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Oops. Wrong thread.
Stuff for sale!!!!!
Do you ride a sportbike?
Old 12-04-2012, 10:21 PM   #1457
Dibaltic
My Ride: 325ci
He said it sounds like a popping or knock sound, which is how mine sounded when I'd turn the wheel because of having no preload on spring.
When my wheel ground on the coils it was more of a grinding noise.
But his wheels are sunk a lot so that could also be a possibility, maybe even a combination of the two
Old 12-05-2012, 12:21 AM   #1458
dinan19
My Ride: 2004 Imola ZHP
Here's mine, I would say its slammed for being on 19's. The car is barely driveable in these few pics. I have raised it a little since them lol.
Photobucket
Photobucket
Photobucket
Photobucket
Old 12-05-2012, 02:47 AM   #1459
Skaper
My Ride: '85 535i & '00 323iT
Well done sir, very clean.
Skaper is offline   Reply With Quote
Old 12-05-2012, 03:09 AM   #1460
SVTJimmy
My Ride: 2002 - 330i
Originally Posted by AudiEtr View Post
No rub, just scrapes the splitters when I apex!! lol
You gotta tell me what spacers you are running. I got the same
Wheels but my car is alpine white. My coils will be here soon.
SVTJimmy is offline   Reply With Quote
Rate This Thread
