Struts - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 11-29-2012, 08:17 PM   #41
always-there
My Ride: 2002 BMW 330I
Springs are in..I'll take a pic as soon as it's done.
Old 11-30-2012, 04:52 AM   #42
always-there
I'm really tired guy, so sorry for the dark pic. I replaced a bunch of crap..but here she is with everything fixed..or so I think z
Old 11-30-2012, 06:46 AM   #43
always-there
No sleep.
Old 12-01-2012, 05:49 PM   #44
ryannel2003
My Ride: '04 Cadillac Deville
Car looks good. I went ahead and ordered the Bilstein Touring struts/shocks. We'll see how they turn out.
ryannel2003 is offline   Reply With Quote
Old 12-01-2012, 09:39 PM   #45
always-there
I went ahead and took the struts apart that night-- It turns out the strut wasn't in all the way. The struts have 2 pin looking guides that are supposed to sink in till the second pin goes in. I had to use a jack and hit the sides of the spindle for it to go in all the way..trial and error. I think you'll be fine. I love the way Bilstein struts perform ,haha. I also replaced the lcab's and the car is just so tight right now, love it.
Old 12-03-2012, 05:21 PM   #46
always-there
It appears the set up has settled a bit more; I love it !
Old 12-20-2012, 11:53 AM   #47
always-there
Have you installed your struts ?
Old 12-22-2012, 10:41 PM   #48
ryannel2003
I haven't yet. They are a christmas present so once I get them I will get them installed and see how they turn out
Old 12-23-2012, 10:32 PM   #49
always-there
How's that for a 4 by 4 ?
Old 12-23-2012, 10:39 PM   #50
always-there
Originally Posted by mrlatexxx View Post
I'm on bilstein sport/eibach pro kit spring .
My advice is, before new strut/shocks replace any other failed suspension bushing like FCAB, RTAB + transmission/engine bushings and also new sway bars due to the lower car setup with new sway bushings.
E46 costly on maintenance..
I'm still 2k into making it better and might even consider a 135i rather then add extra $ to my money lover e46.
GL
135i ? You have the option and you haven't picked one up yet? You're crazy!! Lol.
Old 12-28-2012, 09:24 AM   #51
ryannel2003
Alright so Sunday is the big day for my E46. Doing the strut install along with the tie rod assemblies and the steering guibo. Question on the struts though; do you push those two pins on the strut in the knuckle where the small gap is? Pretty sure that's the only way the strut would fit into the knuckle but wanted to make sure. Also, how did you get the strut to seat correctly after you realized it wasn't all the way in? I'm very excited for this to happen and my car should drive like brand new once I get my RTAB done as well.
Thanks!
Old 12-28-2012, 12:07 PM   #52
always-there
The 2 pins go exactly where you mentioned. Just make sure you push it in all the way and it'll seat naturally by itself.
Old 12-28-2012, 11:02 PM   #53
always-there
The 2 pins weren't seated in all the way, so that was the problem. Other than that, you're good to go! It's easy! Good luck.
Old 12-30-2012, 06:53 PM   #54
always-there
How's it going so far?
Old 12-30-2012, 06:53 PM   #55
always-there
I hope you have a spring compressor.
Old 12-30-2012, 07:03 PM   #56
ryannel2003
They went in great. Took all day pretty much with some friends but we got it done. Like idiots we forgot to tighten up the 22mm strut bolt so the car makes the worst racket going over any kind of bumps in the road. I'm gonna get that taken care of tomorrow and it will be much better. With stock springs car looks a little higher but not as bad as your original pictures showed.
Old 12-30-2012, 08:51 PM   #57
always-there
Awesome.
Old 12-30-2012, 08:55 PM   #58
always-there
Wait a second, you're driving around with a loose strut on the spindle? Not a good idea! If you hit a big bump and it rebounds enough to make it come off you're in for a lot of trouble. Fix it stat! It's fast and easy!
Old 12-31-2012, 01:49 AM   #59
ryannel2003
Yeah I've been going real easy on the car. Didn't discover that I had messed up until I drove a little bit down the road and heard the clunking noise... long day lol. Question, what did you use to tighten yours down?
Old 12-31-2012, 08:59 AM   #60
ryannel2003
I got them tightened up with a 22mm ratchet and a 7mm Allen key and it's great. The drivers side sits about 1/4" higher than the passenger but its not noticeable unless you stare at it. If it doesn't settle I will reseat the spring.
