Old 12-01-2012, 11:24 AM   #21
Nerdy46
My Ride: 328i
Pretty sure the oil had nothing to do with this issue. Rod bearings wont go like that. Your code precat 02. Id look in to an exhaust leak causing your 02 code. this does not sound like a rod knock.
Daily: 1999 328i (202k)- Sport and winter package, 5speed, Jet Black, hellbeige, e60 Short throw, cross drilled rotors, koni, H&R, ASA AR1, Vibrant stealth, basslink
Track: 1995 Mustang GT (230k)- 306ci, 5 speed, MGW shifter, Trickflow Heads, Trickflow intake, street cam, shaved and tucked engine bay, slammed, 1 3/4'' long tubes, tuned with moates.
On the Water: 7' Boneyard Retro Quad Fish
Nerdy46 is offline   Reply With Quote
Old 12-01-2012, 11:31 AM   #22
chelseafcfan
My Ride: E46
Thank you, your Office clip made me laugh out loud and made my day.
chelseafcfan is offline   Reply With Quote
Old 12-01-2012, 11:49 AM   #23
ilkercatal
My Ride: 2001 325 i
than?
ilkercatal is offline   Reply With Quote
Old 12-01-2012, 11:51 AM   #24
warriorpluto
My Ride: 2000 323i
Yea what they said.clearly an exhaust leak somewhere
Sent from my SCH-I535 using Bimmer App
warriorpluto is offline   Reply With Quote
Old 12-01-2012, 12:13 PM   #25
Stinger9
My Ride: '04 330Ci
It's a rhythmical knocking sound. Have you taken off all the belts and run the engine BRIEFLY to see if the knocking remains?
Old 12-01-2012, 12:15 PM   #26
ilkercatal
My Ride: 2001 325 i
no i haven taken of the belts, i should and will try that
Old 12-01-2012, 09:00 PM   #27
ilkercatal
My Ride: 2001 325 i
Changed oil drove about 5 miles with mobil 93 gas and castrol oil in it. Car drives fine, but unfortunately clicking noise is still there.
Question guys:
Could it be:
a)Vanos
b)Disa
c)oil level sender
d)cam shaft
here is the latest short video(47s)
Old 12-01-2012, 09:56 PM   #28
99_323i_Steve
My Ride: 1999 BMW 323i
id say vanos or disa, try and locate area of noise.
I've learned some people think their a mechanic when they can do their own oil change. Don't always believe what you read.
99 323i. Factory:Harmon Kardon Hi-Fi, Winter Package w/ heated sport seats, and Sport package with Sport steering wheel and Sport suspension.
Aftermarket: 16" rims, LED Angel Eyes, LED license plate lights, LED tails, LED depos, Black kidney grill, and DICE Aux jack input, 20% tint.
99_323i_Steve is offline   Reply With Quote
Old 12-01-2012, 10:08 PM   #29
ilkercatal
My Ride: 2001 325 i
I know where it comes from
Noise is coming from right under the BMW logo, Should i continue driving it while finding out the problem or just let it sit.
So whats under that BMW logo, I am guessing pistons etc.
Old 12-01-2012, 10:14 PM   #30
ilkercatal
My Ride: 2001 325 i
I am doubting its VANOS. Because: I dont have any of the below symptoms====
Overall loss of torque and power, particularly in the lower RPM range, < 3k. Bogging then surging at 3k RPM. Uneven power distribution and RPM transition. Engine hesitations in the lower RPM range, < 3k. Louder idle and intermittent idle RPM hiccups. Difficult takeoffs. Loss of power and bogging when AC on. Increased fuel consumption.( link==http://www.beisansystems.com/procedures/vanos_procedure.htm)
Old 12-03-2012, 04:48 PM   #31
ilkercatal
My Ride: 2001 325 i
so
looks like an oxygen sensor code. could probably have a large vacuum leak as well. i've seen and heard a large vacuum leak cause a bunch of knocking noises and ruckus in an e46
Ive heard if you flush the oil or change the oil twice it would smooth out the knocking noise
Old 12-03-2012, 10:59 PM   #32
Stinger9
My Ride: '04 330Ci
This might be way down on my list of things I'd believe.
Old 12-03-2012, 11:38 PM   #33
330iPilot
My Ride: Titanium Silver 330i
LOL on all of those that think changing to regular oil had something to do with it. Car engines don't benefit from synthetic oil other than extended oil change intervals. Synthetic oil was originally developed for jet engines because regular oil couldn't withstand the temperatures and pressures that turbine engines produce. Conventional car engines won't produce temps or pressures high enough to break down the lubricative properties of conventional oil. There have been numerous studies done on this.
That being said, I still put synthetic in my BMW!
A little history on synthetic oil:
http://www.oil4kids.com/syn-hist.htm
330iPilot is offline   Reply With Quote
Old 12-04-2012, 12:31 AM   #34
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
I wouldn't completely discount the oil change as having something to do with this but it may have nothing to do with the oil itself, but different detergents within the oil may have broken some deposits loose.
The lifters in our m52/m54 engines are hydraulic. If any deposits lodged in the oil journal of one of the lifters it could prevent the lifter from fully pressurizing causing lifter tick. Hard to say from 2500 miles away... but a possiblity.
/// MODS
Old 12-04-2012, 12:45 AM   #35
warriorpluto
My Ride: 2000 323i
If it were me I would try to fix whatever it is and get rid of it asap. I'm sure you don't want to be swapping engines anytime soon
Old 12-04-2012, 09:23 AM   #36
TheRarp
My Ride: 02 - 325Ci
oil level sensor.
Add another oil bottle and see if there is any difference.
TheRarp is offline   Reply With Quote
Old 12-04-2012, 09:39 AM   #37
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by TheRarp View Post
oil level sensor.
Aumm what?
Old 12-04-2012, 03:05 PM   #38
ilkercatal
My Ride: 2001 325 i
whats oil level sensor got the do w the noise? conufed
really, i dont thnik so tough
Old 12-04-2012, 03:10 PM   #39
ilkercatal
My Ride: 2001 325 i
you are right on the money buddy
i WENT TO A BMW mechanic today here in brooklyn ( guy used to work at bmw factory in ermany, a russian guy)
He listened to the noise and he says 95 percent chance is the lifters. i told him will this sieze the engine, he goes i dont think so. I asked him also, how much to repair and he says 1000 to 2000 depends what is needed. So since my car is only worth like 3000$ i am just going to use it as it is and do all other maintence and live with this small noise. Or, if one of ya'll can give me a link on how to do this lifters change ( is it expensive to buy the parts, is it tedious job to do).
Old 12-04-2012, 03:11 PM   #40
ilkercatal
My Ride: 2001 325 i
also, other than the noise, car drives like 3 years old
e46 engine knock
