Old 12-01-2012, 04:43 PM   #1
YOLO89
My Ride: Hooptie
Help with this issue please
So I was making a turn through a shopping plaza when my car just shut off completely, but when put it back into park n crank it to start it starts right up...?
Anyone else have/had this issue?
YOLO89 is offline   Reply With Quote
Old 12-01-2012, 04:56 PM   #2
always-there
My Ride: 2002 BMW 330I
It's going to be the camshaft position sensor. I'll be replacing mine soooon.
Old 12-01-2012, 05:04 PM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
Pull codes. Report back.
Old 12-04-2012, 08:45 PM   #4
always-there
Any update?
Old 12-05-2012, 08:46 AM   #5
YOLO89
My Ride: Hooptie
Getting the car checked out tomorrow so I will report back with the issue then.
I'm thinking that's its my fuel pump since my car has 126k miles.
Old 12-05-2012, 08:53 AM   #6
RayPooley
My Ride: 320i SE Coupe
Crankshaft position sensor.
Old 12-08-2012, 05:24 PM   #7
YOLO89
My Ride: Hooptie
Soooo I had a buddy of mine who worked at bmw try n pull codes off of the car and nothing came up. We ordered a new sensor and will install once it gets in to see if the issue is resolved. Hopefully this issue doesn't lead to any other further issues
Old 12-09-2012, 05:14 AM   #8
RayPooley
What sensor?
Old 12-09-2012, 08:37 AM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Not to wise to change a part like a cam/crankshaft sensor if the code is not present at all, but I hope that it will solve the issue.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 12-09-2012, 09:34 AM   #10
RayPooley
Crank ps can cause stalling without throwing a code. Mine did. A couple of times before it eventually threw a code. Cam sensors are more likely to produce rough performance issues and misfires. Nothing works if the crank ps misses a beat. That's why I would replace the crank sensor rather than the cam sensors if the problem is a cut out problem rather than a rough performance problem. Its not a costly job and I would rather just chnage it than risk stalling on a motorway and another unsuspecting car backending me.
Old 12-09-2012, 09:56 AM   #11
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You noticing other symptoms, OP? Rough idle, idle surging, anything?
Facebook.com/DMAXstandup
Mangofy your E46!
