Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
Old 03-29-2009, 12:44 AM   #21
Alex323Ci
My Ride: M3 & 323Ci (sold)
I'm hesitant about doing that out of fear of a mod giving me points for duplicate threads.
I'll post the link for you..after this thread is older as it can be helpful for a much cleaner install. Thanks for the info and part numbers. I'm going to order the parts monday. Do you know what the difference is in the two covers? Are they different applications for different ballasts or is one just a superceeded part number?
Old 03-29-2009, 01:36 AM   #22
mkodama
mkodama's Avatar
Thanks!
There are two different types of ballast covers because there are two different types of ballast. After 9/2001 BMW changed the ballast design a little bit. The later model has holes for two wires since they are both removable, while the earlier version has just one hole for the removable socket and the thicker non removable wire is just routed out the bottom of the cover.
Here is what the later model ballast cover looks like, notice two wires coming out of the top:
And here is mine with an earlier version (a 1/2001 build date car), notice only one wire coming out the top:
Old 06-29-2012, 05:28 PM   #23
So Slow
My Ride: 2 doors
The wiring off of the headlight to the ballast is too short to reach up there, any one if there's anything I can do to get it mounted up there? Thanks in advance!
So Slow is offline   Reply With Quote
Old 12-05-2012, 02:25 AM   #24
TKC
My Ride: 330cic & R6
Send a message via AIM to TKC
Excellent thread, OP!
Has anyone had a good solution to doing this on a facelift where the wires going from the headlight housing to the ballast are too short and can't reach the area where the relocation bracket sits? I'm helping a friend with an install and just found out the facelift has a different type of ballast so we're trying to figure out the best way to do this.
Thanks for any info!
*Edit: Nevermind, OP. I guess I already told you that in March of 2009.
EUROPROJEKTZ - Director, NorCal Chapter
TKC is offline   Reply With Quote
Old 12-05-2012, 03:07 AM   #25
mkodama
mkodama's Avatar
lol, 3 years and 8 months later... We've been on this forum for that long?
Old 12-05-2012, 10:37 AM   #26
UTL1098
My Ride: DINAN 135i, T4R LE
I feel old.
UTL1098 is offline   Reply With Quote
Old 12-21-2012, 03:47 AM   #27
goblinsplace
My Ride: 330i ZHP
Anyone know if I can fit a morimoto ballast in that cool OEM bracket?
Any idea if I can fit 2 ballasts in that OEM bracket cover? (Any suggesyed modding?)
Oh and can I fit that on a 330 with stock intake?
Is there one for the passenger side? And ideas for a good place to for 3 ballasts on each side?
(Fog and quad xenon.)
Were not old!!!!!
goblinsplace is offline   Reply With Quote
Old 12-21-2012, 04:50 AM   #28
sillieidiot
My Ride: '06 AW 330ci
lol i was reading this thread and i was like wtf they aren't all the same. then i realized that it was from 09.
Old 11-17-2013, 06:36 PM   #29
s14realm3
My Ride: 03 ZHP, 95 M3, 91 M3
ZHP xenon ballast move DIY needed
so i have a 2003 ZHP with Bi xenon, how do I relocate the ballast with the short amount of wires thats inside the light? and what about the big rectangular hold opening where the ballast use to cover up? IS there a cover I can get to cover it?
thanks
Tim
s14realm3 is offline   Reply With Quote
Old 11-26-2013, 08:07 PM   #30
s14realm3
bump on how to relocate bi xenon ballast?
Old 11-26-2013, 08:20 PM   #31
goblinsplace
My Ride: 330i ZHP
I have an answer to this but can't post now! Will chime in soon.
Old 11-26-2013, 11:26 PM   #32
goblinsplace
My Ride: 330i ZHP
Ok, so what i did was cut out a piece of plastic from a plastic plate i had laying around. (dremel) then i used red silicone high temp caulk to seal the hole to the plastic plate i made. I put the plate on the inside and pressed it down i think. use a ventilated area as that silicone caused a skin reaction for me. It held very permanently.
For the ballast relocation, why are you relocating? I used moromito balasts and that gave me enough wire to velcro mount to the frame just below the light or to the inside fender, again with velcro.
I put pics of the 2nd placement locations, I have a quad xenon setup, so the other 2 are on the frame beam just below the light. I recommend mounting there.
What you could do is use 14 guage wire, and extend the ballasts to your needs, and twist them and pull them through a black techflex
ID:	536344   Click image for larger version
Old 11-27-2013, 10:40 AM   #33
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
OK, this is bordering on ricey. Good effort, though.
Old 11-27-2013, 11:00 AM   #34
HBizzo88
My Ride: 2002 bmw 330ci
The cool way to relocate your xenon ballast if you have a tube-style cold air i
Your engine is dusty as fuc!
HBizzo88 is offline   Reply With Quote
Old 11-27-2013, 12:10 PM   #35
Alex323Ci
how so? he's using oem parts and even all the M3s use this exact set-up. I had to do this on my coupe when I supercharged it as the compressor and piping hit that ballast. all you do is extend the wires and install. The holes are already there for the ballast bracket from the factory.
Nothing ricey about clean & tidy and oem fit and finish
Old 11-27-2013, 12:34 PM   #36
LeMansteve
Indeed, in some cases it is required. I'm saying it's bordering on ricey when it is done mainly just so you can say your car has a "CSL mod".
Old 11-27-2013, 12:41 PM   #37
Alex323Ci
Haha yeah now that would be.
Old 02-27-2014, 02:03 AM   #38
STREETFIGHTER50
My Ride: '04 Sil-Gry ZHP 6-Sp
Where's the cheapest place to order these parts online? I talked to AutohausAZ & OEMBimmerParts about ordering these parts. They don't stock these items.
STREETFIGHTER50 is offline   Reply With Quote
Old 02-27-2014, 01:11 PM   #39
Alex323Ci
any discounted dealer, Tischer BMW comes to mind at getbmwparts.com
Old 03-18-2014, 12:20 AM   #40
STREETFIGHTER50
Just an update/FYI about this mod. Not all our if OEM ballasts are the same. On cars with factory "ZKW" headlights the black plastic cover & screws listed here will not work. I was able to use just the bracket on my 2004 ZHP. I may order the earlier single hole cover to try to make it work somehow.
