Old 12-04-2012, 05:44 PM   #1
bigloser
My Ride: 2004 330i ZHP
At first I though I went deaf...
I was driving back home last night, and all the speakers on the left side of my car suddenly stopped working. I was driving in a straight line when they stopped working, I did not hit a bump or anything, additionally there was no strange noises from them, they just stopped. After double checking to make sure I just hadn't gone deaf in one ear, I played around with the balance and determined that when I set the balance to full left, I had nothing.
On my way into work today, while sitting at a red light, the speakers came back to life, then a short time later, while sitting at another red light, it went out. any ideas on what is causing this?
1984 318i - Dead
1998 328is - Sold
2004 330i ZHP - I think I'm in love
Last edited by bigloser; 12-05-2012 at 07:09 PM. Reason: I apparently forgot what left and right were
bigloser is offline   Reply With Quote
Old 12-04-2012, 06:02 PM   #2
Blind_Shooter
My Ride: is your sister
Aftermarket radio or stock? Aftermarket or stick speakers?
smells like crayons
Blind_Shooter is offline   Reply With Quote
Old 12-04-2012, 06:58 PM   #3
330iPilot
My Ride: Titanium Silver 330i
Amp is dying
330iPilot is offline   Reply With Quote
Old 12-04-2012, 07:00 PM   #4
atinybug
My Ride: e92 335i
Or maybe a loose connection somewhere?
atinybug is offline   Reply With Quote
Old 12-04-2012, 07:00 PM   #5
B_Cyrus
Banned User
My Ride: Malfouf
This all may be a dream. Did you watch inception?
B_Cyrus is offline   Reply With Quote
Old 12-04-2012, 07:55 PM   #6
bigloser
Stock HK sound system with stock speakers. It's every speaker on the left side of the car failing at the same time, so I'm pretty sure it's not a speaker failing.
1984 318i - Dead
1998 328is - Sold
Old 12-04-2012, 08:04 PM   #7
B_Cyrus
Banned User
My Ride: Malfouf
It was all a dream
I used to read Word Up magazine
Salt n' Peppa and Heavy D up in the limousine
Old 12-05-2012, 07:07 PM   #8
bigloser
So it appears to have settled into a regular pattern where, when the car is cold, both channels work for 15 seconds-3 minutes, then the left channel fails and doesn't come back. If the car is already warm on startup, the left channel never plays audio, only the right. Has anyone out there had something similar?
1984 318i - Dead
1998 328is - Sold
Old 12-13-2012, 03:09 AM   #9
dan19
My Ride: bmw e46
i have same problem but dont no how to fix.
dan19 is offline   Reply With Quote
Old 12-31-2012, 01:38 PM   #10
bigloser
So I replaced the amp last night, and the issue is persisting. It appears that songs with more bass trigger the failure, if I turn the radio on and its just some people talking, it seems to work for much longer compared to when I turn it on and there is music playing. The missing left channel occurs for both radio and CD playback.
1984 318i - Dead
1998 328is - Sold
Old 12-31-2012, 01:54 PM   #11
jdstrickland
My Ride: '94 325iC & '00 323i
It has to be the radio or the amp.
Old 07-24-2013, 10:16 AM   #12
bigloser
I finally got this fixed, it was the radio that had failed, not the amp. just updating so if someone looks this thread up in the future they know the resolution.
1984 318i - Dead
1998 328is - Sold
Old 07-24-2013, 01:13 PM   #13
McDonald
My Ride: 2002 330i
The actual radio or the receiver in the c pillar?
McDonald is offline   Reply With Quote
Old 07-24-2013, 01:38 PM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Thanks for updating us. Hopefully you got an '03 up radio for the aux input.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 07-24-2013, 01:53 PM   #15
bigloser
It was the radio module in the trunk, not the receiver in the c pillar.
1984 318i - Dead
1998 328is - Sold
Old 07-24-2013, 01:57 PM   #16
bigloser
Well I always hate it when someone doesn't update their thread with the resolution, so I'd be a rather large hypocrite if I didn't do it myself . The unit I got is whatever the most recent supersceeded part is, but I had already installed a media bridge on it, so I just use the Bluetooth connection.
1984 318i - Dead
1998 328is - Sold
Old 07-24-2013, 02:29 PM   #17
MercForHire
My Ride: M235i 6MT
Time for speakers and radio delete
Performance ftw
Old 07-24-2013, 04:33 PM   #18
markusmarkus
My Ride: 2001 330Ci
I had a similar problem a few years ago. Solution - BMW approved process as follows:
- disconnect ground connection at the battery
- disconnect the positive (+) connect at the battery
- connect the 2 battery cables for at least 10 minutes
- reconnect the positive (+) cable
- reconnect the ground cable
- reset the clock
Old 07-24-2013, 05:08 PM   #19
Asher454
My Ride: '04 TiAg 325xi
It was all a dream
234,XXX......... Factory M54
Asher454 is offline   Reply With Quote
