Health & Fitness
Discuss any topics related to heath and fitness here. |
#1 |
Weighted dips/pull-ups/chin-ups
How many pounds do you guys add to your body weight when doing weighted dips/pull-ups/chin-ups and how many reps?
From leangains site, if you can do +40lbs 5 reps of chin-ups then you're in the very fit/strong scale. I find dips/pull-ups/chin-ups as a good measure of strength. |
#2 |
I'm adding 30-40lbs depending on which it is and doing 3x8-10
I never have posted much on this thread and sold my BMW but have gained quite an interested in the H&F part
#3 |
I can do 10 chins with 45lb. 5 with 90 lbs. ill try a pr next week. Did pull ups x5 today with 45lbs for 3 sets and it wasn't THAT hard
#4 |
#5 |
Damn, every one is so strong around here.
Do you use weighted dips/chin-ups/pull-ups as primary exercises or secondary? Would make it easy if you just post your workout plan on days when you do them. Last edited by z00; 12-06-2012 at 01:31 AM. |
#6 | |
Chest/Tris on Mon/Thu Back/Bis on Tues/Fri Legs on Wed/Sat On lifts such as bench, incline, EZ bar curls, skull crushers, over head extensions, squats, dead lifts, lat pull downs, low pulley row, etc I've been trying to do 5 sets of 5 reps. Dips and pull-ups I do more as a secondary lift. Maybe once a week if that. Usually on my secondary lifts tho I try and do 3-4 sets of 8-12 reps depending on the workout I have also noticed I don't have **** on a few of these guys hahaha I might can lift a significant amount of weight compared to my friends tho the physiques of a few E46ers is crazy!!
![]() Last edited by ATU2010; 12-06-2012 at 01:46 AM. |
#7 |
My workouts consist of:
Explosive Upper body push Superset Lower body pull Lower body push Superset Upper body pull Core finisher Pull/chins go on my upper body pull. I've integrated them a lot the last few years Also do density and interval circuits.
#8 |
You can see most of my workouts in the "post a workout" thread. Along with videos
#9 | |
Do you recover with your program? Twice a week per muscle group is a bit excessive. No? I read mixed opinions but most splits I have seen involve one muscle group per week. If it's working out for you it's great.
#10 |
I tried the one group a week thing fooooor about a week. I felt sluggish idk just didn't feel like I was pushing enough. But anyways. With my current routine I've been moving up in weight 5 to 10 lbs every day and see size gains prettyyyy damn fast. Don't plan to change a thing except eat a little cleaner. But twice a week with Sunday off I'm never sore except leg days and never feel weak on second days. Always moving up so far
#11 |
Today I lifted at 8:30 tho. Huge no no for me. Never can fall asleep till after 2:00 am which equals maybe 5 hours of sleep tops
![]() Last edited by ATU2010; 12-06-2012 at 02:07 AM. |
#12 |
45lbs for both chin and dip.
#13 | |
![]() Gives you something to strive for at least
#14 |
I know, was thinking the same thing. Maybe it's time to switch to a six-day split. Many of prof body builders workout 6 days a week. But we ain't no prof builders.
#15 | |
Interesting. Can you post a full workout sample of a week? I'm sure you change it. I wanna get an idea of sets/reps and type of exercises.
#16 | |
6 day splits... remember that working out is HURTING your body, where as rest days + proper nutrition are HEALING and GROWING... if you workout 6 days, when do you have time to heal? Going to these extremes are only necessary for those who have 5+ (more likely 10+) years of lifting, where gains only come to the seriously dedicated.
#17 |
I'm at 3x6 reps with 40lbs in my weight vest on ring dips. I'm assuming that's harder than regular dips. I got 9 the first set last week. Tomorrow I attempt 45lbs. I don't foresee a problem.
On chinups I'm at 25lbs for 3x5 pull ups, never tried yet. |
#18 |
I've done a pullup with 88lbs, a set of 3 chins with 88 and a set of 2 dips with 135. That was many lbs ago though. I'm a lot heavier now and dont work them exclusively....
#19 |
Chillin'.....Killin'
My Ride: M3/848/128i
Right now I'm regularly using 50 lbs. for my pull/chin-ups and dips, but I do heavier, low rep sets with 60 lbs. in an attempt to break a plateau. I regularly can muster 4 sets of 8-10 pull-ups/chin-ups - depending on how taxing my workout was - using 50 lbs. on a weight belt. I do them at the end of my workout, so some days I feel stronger and more capable than others. I've never attempted anything higher than 60 lbs.
#20 | |||
I was prod of myself for doing chins 5 reps with 30lbs. Then I come to read this. I'm only 163lbs.
We should call you guys El Diablos. Quote:
