Old 12-12-2012, 09:02 AM   #1
Posh
My Ride: 320Ci (2004)
Noise under the bonnet (Hood)
Having switched the ignition on without starting the engine there is a sound under the bonnet (rather like a Computer cooling fan). Is this normal? I've had the car from new (2004) and never noticed it before.
Any suggestions?
Posh is offline   Reply With Quote
Old 12-12-2012, 12:12 PM   #2
Ruthlessone3k
My Ride: 323i
Any suggestions?
I just asked this same question a couple days ago and didn't get a firm answer. Seems like others have it as well. Does it turn off after a while or keep going? Does it continue for a bit after you remove the key? If so this is the same sound I have on my 323i, It seems to be comming from the throttle body area.
Ruthlessone3k is offline   Reply With Quote
Old 12-12-2012, 12:20 PM   #3
zhenkaaaM3
My Ride: Fst'r then your e46
are you asking whats the sound coming from the engine for the first 30 seconds of startup when the car is cold?
If yes, its your secondary air pump doing its work.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 12-12-2012, 12:36 PM   #4
Ruthlessone3k
My Ride: 323i
If it is the same noise I have it is not the SAP, it starts when the key is turned to the on position without the engine running. It comes from the opposite side of the engine as the SAP as well.
Old 12-12-2012, 12:50 PM   #5
zhenkaaaM3
Videos would help. Otherwise, we dunnnnnnnnnoooooooo
Eugene
Old 12-12-2012, 01:03 PM   #6
pleiades
My Ride: M52TU
If you have your heater set to on when you turn on the ignition (but not the engine), there's a small electric pump that might be running. Either under the heater valve or near the bottom corner of the rad (on e39s, not sure where it is on the e46 but assuming somewhere similar).
Also, the air conditioning system has blower fans as well as a small fan to sample cabin air. These might be running as well.
pleiades is offline   Reply With Quote
Old 12-12-2012, 03:40 PM   #7
lcoleman
My Ride: '79 Massey Ferguson
^the secondary water pump is e39 only.
ICV? It's more of a buzz, though.
Old 12-12-2012, 05:12 PM   #8
zhenkaaaM3
Secondary water pump?
Eugene
Old 12-12-2012, 05:20 PM   #9
lcoleman
You can see it in the middle bottom of the pic ^ ture. I think it's mostly to circulate warm coolant through the heater core so you can get a little extra heat after the engine is off. It also makes bleeding them much easier, as you can get 90% of the air out with the engine off.
Old 12-12-2012, 05:36 PM   #10
330iPilot
My Ride: Titanium Silver 330i
Fuel pump?
330iPilot is offline   Reply With Quote
Old 12-13-2012, 04:21 AM   #11
Posh
Thanks for the suggestions. Applying a process of elimination: It's not the A/C and it doesn't go off after 30 seconds so not secondary air pump.
Looking at Icoleman's diagram it's coming from an area slightly further back in the engine compartment than the number "8".
Regards
P
Old 12-13-2012, 11:53 AM   #12
Ruthlessone3k
My Ride: 323i
Sure seems to be the same sound I am getting. I am planning on taking parts off one be one this weekend till I get to the bottom of this. I'll let you know what I find.
Old 12-13-2012, 11:55 AM   #13
Zell
Zell's Avatar
My Ride: so turbo wow
I think it's the ECU fan. If you put the key in acc, you'll hear a distinct "whirr" noise of a fan coming right from the box.
Old 12-13-2012, 12:02 PM   #14
lcoleman
ICV, like I said. Reach your hand down there and feel it. It should be vibrating.
Old 12-13-2012, 01:02 PM   #15
Ruthlessone3k
My Ride: 323i
Where is the ICV at? I'm lost on these BMW engines
Old 12-13-2012, 01:05 PM   #16
lcoleman
Old 12-22-2012, 04:40 PM   #17
Ruthlessone3k
My Ride: 323i
Sure enough, the ICV was the culprit. Thanks a lot
Now, I would like to know if this constant buzzing sound is normal???
noise
