Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 12-05-2012, 11:43 PM   #1
nek0
My Ride: 335i
AA methanol question
Hello I'm new into the Force induction world just purchased a e46 with a AA supercharger kit... I have meth installed into it I just have a few questions I've searched but I haven't found a specific correct answer (Again sorry if I'm starting a thread that's unneascary)
1. What type of fluid do I use is there anything specific that I should know about?
2. Is it ok to drive the car with the meth off?
3. Is it ok to hit boost with the meth kit off?
4. Where's a good place to purchase the method the right price? What's the average cost of it?
5. Is there anything specific way to put the meth in the tank? Should I fill it to the tippy top? Keep it mid way? Keep the car on or off?
6. What Do I need to do to keep it running correctly do I wash the tank?
Sorry for being a newbie with this it's completely new to me thank you in advance, neko
nek0 is online now   Reply With Quote
Old 12-06-2012, 07:59 PM   #2
Active 2
My Ride: 02 E46 m3
AA uses a 50% water and 50% meth mixture
snow performance/ boost juice sell it already pre mixed
Just pour it through the opening in the tank. You can have the car on or off, doesnt make a difference. Just fill the tank to the top, you will be fine
No need to wash the tank, just keep fluid in there regularly that way the pump can cycle regularly
Hope this helps
02 ///M3 Jet Balck/ Imola
AA Headers | AA Exhaust | AA tune | Ground Control | AFE scoops | Apex EC-7
Active 2 is offline   Reply With Quote
Old 12-06-2012, 10:27 PM   #3
nek0
My Ride: 335i
Originally Posted by Active 2 View Post
Hope this helps
Super thanks!!! I was running low on it so I turned it off is that alright to drive the car with the meth off?
I couldn't find specific answers for my questions toward my specs I really appreciate it thanks!!!
Old 12-07-2012, 09:04 AM   #4
Active 2
My Ride: 02 E46 m3
As long as you're running 93 octane you should be fine, but if you plan on driving the car hard turn it on.
If you run anything less than 93 you should definitely run meth
Old 12-07-2012, 09:43 AM   #5
nek0
My Ride: 335i
Yeah I'm currently running 100 oct but I've got no meth so ill just try to stay out of boost, thanks again!
Old 12-07-2012, 10:44 AM   #6
mike@maximumpsi
boost junky
My Ride: 02M3T, 97M3T
Some AA kits are meth dependent. The E46 M3 HKS L2 kit is one of them. Check with them regarding your kit/calibration.
02 E46 M3 - Maximum PSI turbo kit - 10.81@131.39
97 turbo M3 - 9.54@158.24, first in the 9's
Maximum PSI - Home of the quickest BMW's in the US
Click for used E46M3 turbo parts FS
Email us at sales@maximumpsi.com!
Like us on facebook to follow our latest builds and upcoming events! - facebook.com/maximumpsi
mike@maximumpsi is offline   Reply With Quote
Old 12-08-2012, 12:57 AM   #7
AMG-ETR
AMG-ETR's Avatar
My Ride: The 332Ci
Send a message via MSN to AMG-ETR
Can you elaborate on this a little? Why is it meth dependent? I'm pretty sure Jean mentioned to me a while back that it was only used as a cooling feature and not an octane booster.
AMG-ETR is offline   Reply With Quote
Old 12-08-2012, 10:31 PM   #8
nek0
My Ride: 335i
Yeah I'd like to know, how can you tell if your kit is depended on meth?
Old 12-12-2012, 08:11 AM   #9
Viral@ActiveAutowerke
Viral@ActiveAutowerke's Avatar
My Ride: E82 135i N54
The Generation 6 & 7 Active Autowerke Stage 2 Supercharger Kits for the E46 M3 Require Methanol that is why they are provided with the System.
Viral Vahia
Active Autowerke | 9940 SW 168 Terrace Miami, Florida 33157
www.activeautowerke.com | viral@activeautowerke.com
Phone: 305.233.9300 Ext. 232 | Fax: 305-253-8921
Viral@ActiveAutowerke is offline   Reply With Quote
Old 12-12-2012, 09:04 AM   #10
AMG-ETR
AMG-ETR's Avatar
My Ride: The 332Ci
Thanks Viral! So we don't have the option of switching off meth?
Old 12-12-2012, 09:19 AM   #11
Stage 1 to 1.5 Yes, you can turn off the Meth. But in Stage 2 Meth. is required.
Viral Vahia
Old 12-12-2012, 10:01 AM   #12
nek0
My Ride: 335i
Ooo dear I've been short on meth so I shut it off is there any harm if I run it off?
Old 12-12-2012, 11:28 AM   #13
Sweed
My Ride: 07 6.0L / 04 M3
Meth on HPF kits are 100% meth and the octane boost from the meth alone allows for more timing = more power
On the stage 2 AA kit meth is also depended but in terms of cooling and stopping detonation from happening at max boost.
The on / off hobbs switch for meth is still there on the AA stage 2 kits for other reasons, say you went on a track and they didn't allow meth.
You would have to dump in some higher octane to not detonate and over heat with-out the meth.
Plain and simple, do not take a stage 2 AA kit to max boost with-out meth on or if it's off have high grade fuel.
I may have missed something as well for I'm not a pro or installer, just my 2 cents. Maybe all tracks allow meth, not sure
Note this is for the AA Stage 2 for the M3 S54 engine if wondering
AA HKS Stg 2 / Nitrous Express
Sweed is offline   Reply With Quote
Old 12-12-2012, 12:14 PM   #14
nek0
My Ride: 335i
Ok good I put 100 octane in it the other day when I turned it off
Old 12-12-2012, 02:15 PM   #15
Know it all .... Just Kidding but he is correct
That will suffice if you are using 94 Octane on a Stage 2 Methanol Injection is Required
Viral Vahia
