#1 |
overheating
y is it overheating when i start it up it shoots to hot in a second any ideas guys
i replaced the thermostat but still dose it usually happens once in the morning first warm up i have to sit in the car whole time so it don't stay hot for but a second i usually just turn it off and then it goes back to cold it has only done it to me once when i am driving 3 times when i am sitting warming it up i live in cold ass Wyoming so maybe that has something to do with it ???? Last edited by majestic69; 12-12-2012 at 03:27 PM. |
#2 | |
Platinum Plus Quality
c sig. do it all.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#3 | |
for everyone else. This used to be my car, it was running great. A little background on the new owners location which is high altitude and cold weather. We are not sure if it affects the car. I think its probably the contacts on the sensors that maybe shrunk enough with the cold weather to cause a misread. Any input will be greatly appreciated.
![]() Pictures by boligrafo123 & ///OSS |
#4 |
I did, i replaced the whole cooling system just 2,000 miles before he purchased the car. He is posting because we have no idea what else it could be. Im thinking dirty contacts but I could be wrong.
![]() Pictures by boligrafo123 & ///OSS Last edited by gaby1088; 12-12-2012 at 03:11 PM. |
#5 | |
Weagle Weagle
Also, please use punctuation. It is hard enough to figure out what is wrong with a car. I don't want to have to hire a lunguist to translate your posts. You owe me $15 for his hourly rate. Last edited by WDE46; 12-12-2012 at 03:12 PM. |
#6 |
if you do these items a la carte, you will be revisiting the cooling system for repairs many times, and you will get discouraged with each additional time you have to get back in there. Do it right, do it once, do it all!
#7 | |
#8 |
Dude this was a cross post, it wasn't there to read when I responded.
You read read read specifically, the post times. You posted at 1:09 I posted at 1:10 OP bleed system again, properly.
#9 |
My bad. Didn't even notice lol. Lets help him out, he drove over 3400 miles. This started when he got to high altitude and cold weather. Do you think it could just be dirty contacts on a sensor?
#10 | |
I think it needs to be rebled Sent from my SAMSUNG-SGH-I727 using Bimmer App |
#11 |
haha well i appreciate Ur input i am a pro fighter not trying to win a spelling b and just looking to get tips on what it could be if its to much work for u to read then move to the next Ty
#12 |
Dang I though my English was bad
Ahha +1 on bleeding the system out completely through
![]() Need a bearing tool in Chicago-land ?http://forum.e46fanatics.com/showthread.php?t=964450 Find bmw wheel style here http://forum.e46fanatics.com/showthread.php?t=987999 |
#13 |
needs to be what???
#14 |
i did when i replaced the thermostat not the water pump sorry
#15 |
rebleed
#16 |
ok i just did that ?
#17 |
1) did you do it properly
2) are you sure? 3) does it overheat? ???
#18 |
Put it on a video because its hard to understand where you're coming from with this
#19 | |
You certainly wouldn't be the first to have to rebleed the cooling system. Try it again: When the engine is cold: Start the car and run it at 2k rpm for less than 30 sec. (This will allow enough pressure to build, and will help with the bleeding.) Then Engine off, but key on, position II Turn heat temp to highest ° Turn the analog dial between center vent to Red. Fan speed at least On. (I set it to Max on my third and successful attempt on my most recent cooling overhaul) Completely unscrew bleeder and pour, pour, and keep pouring into the ET, until the water comes out of the bleeder in a smooth bubble free stream. Close up bleeder syphon excess coolant (i use a turkey baster) and close ET, go for a drive, with your heater on, and stay close to home, and have your distilled water with you to be sure and safe. Check the level again when engine is completely cold, before the next time you set off. You may find that the level is a bit low, just top it off until the tip of the float is flush with the filler.
#20 |
The nature of the situation does not suggest it is a mechanical issue. From one second to the next it reads it's overheating. Then he turns off the car and it reads cold again. What sensors could it be?
