E46 Xi Forum
The E46 XI was produced from 01-05 in sedan and touring body styles. Powered by either a 2.5L inline 6 in the 325xi or a 3.0L inline 6 330xi. Discuss all thing about BMW AWD E46 'Xi' here. |
#1 |
Help with tranny fluid change
Hey guys I want to change my 02 330xi auto (steptronic) tranny fluid. I went and look under my car and I have a green sticker with part number 83220024359. I bought redline D4 auto trams fluid. Did a bough the right one?
Thanks |
#2 |
You should use dextron VI. You may call your local dealer or insert that part number into a dealer parts site and you will told the same.
Sent from my Nexus 7 using Bimmer App |
#3 |
My Ride: 2003 325xi
D4 was a preferred choice for many XI owners with the GM trans. I've read several posts where it has been stated - D4 is VERY close to the original factory (Texaco) spec. It has been in more recent years that BMW recommended Dex VI as a replacement. D4 is known to blend well with the remaining fluid and be chemically compatible. User tested - user approved.
You're fine and D4 is going in my ride (74 K mi.) next spring.
Anything made can be made Better ![]() |
#4 | |
#5 |
My Ride: 2005 325xi
Yup you're golden, many folks have used it with great results.
I used Liqui Moly top tec 1200 with good results so far (3k miles) It's spec'd on their tech sheet as a replacement for the Texaco 8072-b fluid we have. ZF lifeguard fluid is also spec'd a replacement fluid, but at around $17 a quart, not worth it. |
#6 |
I'm running d4
Royal Elite Club of 6 Speed Tourings - founder
#7 |
My Ride: 03 325xi, 03 330xi
The Redline D4 should work just fine as long as there are no other internal issues. I would not recommend pressure changing the fluid.
