Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 05-25-2011, 09:07 AM   #21
miyata
My Ride: 2005 330 XI
Fabulous job. I'm annoyed the squeaking from the steering, dealer told me a coupler replacement would help. I cannot believe you've completed it like a easy job. Can I follow it on a XI? XI has a much higher part price $170, comparing $40 on other models.
miyata is offline   Reply With Quote
Old 05-25-2011, 12:34 PM   #22
snowborder142190
My Ride: 08 335i coupe '09 m6
I am not quite sure if the xi are the same but I can check it out when we do your vanos seals
Sent from my iPhone 4 using BimmerApp
snowborder142190 is offline   Reply With Quote
Old 05-25-2011, 10:12 PM   #23
miyata
Thanks 1K times
Old 06-07-2011, 11:03 PM   #24
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Put this DIY in my todo-list, thanks, OP! BTW, www.bmwmercedesparts.com sells part 32306752957 just for $35! And I'd get two new torx bolts as well (32306778609) - $0.47 ea
Nervous is offline   Reply With Quote
Old 06-10-2011, 06:21 AM   #25
snowborder142190
Thanks for the link!!
Old 06-13-2011, 02:27 PM   #26
Kubs
My Ride: 2003 330 Ci
My steering wheel "shakes" back and forth a little bit between 60-70MPH. I have replaced control arms, bushings, inner and outer tie rods, wheel bearings, and sway bar end links with no change. Would this coupler be my problem?
Kubs is offline   Reply With Quote
Old 06-14-2011, 02:31 PM   #27
snowborder142190
It could be the problem but Likely it is a bent or out of balance rim.
Old 06-14-2011, 02:41 PM   #28
Custom3
My Ride: HellRot 330CI
hmmmm....wondering now if mines need to be replaced. So the symptoms of a bad coupler is car drifting to the left or right? anything else.
Great DIY!
Old 06-14-2011, 06:52 PM   #29
snowborder142190
Great DIY!
It just seems like you have a lot of play in your steering that is how I can best describe it. If it is the original and it has gone 80k miles it's a safe bet it needed to be replaced. Very easy diy and only costs 40 dollars.
Old 06-15-2011, 11:25 AM   #30
Custom3
thanks! I got 90k...will replace then
It just seems like you have a lot of play in your steering that is how I can beat describe it. If it is the original and it has gone 80k miles it's a safe bet it needed to be replaced. Very easy diy and only costs 40 dollars.
Old 10-14-2011, 07:54 PM   #31
yamhill
My Ride: 2000 328i
ahh! much better
I replaced the steering coupler 32306752957 on my 2000 328i at 134,000 miles, and I'm very happy with the improvement. I've had the car for about a year. I replaced the control arms, control arm bushings, and tie rod ends, but the steering still felt vague. With the new coupler in place it feels much better.
I compared the feel of the new and old couplers side by side. The old one was much easier to flex. The additional stiffness in the new coupler helps the steering feel.
The install was fairly easy. It helps if your car is cold. You have to work right next to the oil pan.
yamhill is offline   Reply With Quote
Old 10-16-2011, 05:57 PM   #32
yetieater
My Ride: '03 330i
Just did this one over the weekend. The bolts were initially quite difficult to access - I removed the aggregate protector plate at the bottom of my car to give myself more working room. Used Loctite Threadlocker Blue when bolting everything back together. The car definitely feels more confident through curves, and there's less annoying feedback from the road. I'm looking forward to my next roadtrip!
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 07-03-2012, 08:58 AM   #33
cs01ws
My Ride: 330ci m sport
Hey guys, just thought I would add some information I just got. I went to the dealers for the part as described by the OP. If your car has the euro m-sport package your car will not have the guibo numbered 2 on the diagram installed on your vehicle. Instead you have the Universal Joint numbered 4 on the diagram. In fact the m-sport version is apparently less likely to fail. Although having changed mine I noticed a great improvement.
Also it seemed much easier to install than some of the problems other guys have been having
cs01ws is offline   Reply With Quote
Old 08-06-2012, 10:41 PM   #34
Brobby87
My Ride: 2003 325i, 1986 535i
I hope to do this DIY this weekend with a little help from this thread. Thanks in advance for the pictorial DIY. I couldn't find anything like this over at bimmerfest.com.
Brobby87 is offline   Reply With Quote
Old 12-15-2012, 08:38 PM   #35
2003silver330i
My Ride: 03 BMW 330i
Can this job be done using jack stands since I don't have any ramps?
2003silver330i is offline   Reply With Quote
Old 12-16-2012, 01:44 PM   #37
2003silver330i
Totally, it is even better on jack stands: more space to work.
Thanks. I wasn't sure how the suspension hanging would affect the install.
Old 12-21-2012, 11:05 PM   #38
2003silver330i
Just did this DIY and I have to say it was one of the easiest things I have attempted on this car. Took longer to get the car up on jack stands and remove the covers underneath then it did to replace the coupler.
Old 03-31-2013, 02:28 PM   #39
blitzyj
My Ride: 318i e46
first of all thanks for sharing this DIY! One question: Is it normal i could slide nr 1(coupled to the steering shaft) in the next picture out of the rubber?
This happened to me when i was pulling nr 1(next picture) towards the coupler.
I pushed it back inwards and heared a click, so i guess it's ok?
blitzyj is offline   Reply With Quote
