ICE ICE POLO (ROBolop Design) - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Old 12-10-2012, 01:19 PM   #21
robolop
My Ride: 323ci
I grabbed the mill from out the cupboard and started making some sloths on the bottomside (for the cables from the subs)
Then I started making frames where the glass will rest on. This alu plate is about 3mm thick.
Then I sanded it down, and drew it out.
Then I cut away as much as possible with the jigsaw. Because it's impossible to saw straight with a jigsaw, I milled the last mm.
Pretty easy to do.
It's superimportant that the aluminium is taped to the table. I did it with dubbel sided tape.
You can also see that the plate is laying against some nails. I knock them qual to the top of the plate, so the mill doesn't flip when I go over them.
And a lath which functions as a glider for the mill.
This looks pretty smooth and easy, but when you look at the clock, hours pass by. But I don't care about the time.
robolop is offline   Reply With Quote
Old 12-17-2012, 11:33 AM   #22
robolop
My Ride: 323ci
Originally Posted by wdeerfield View Post
i really like this. You do great work. Are you going to put it on a hydraulic lift or something? That cant be light to lift up to access the spare.
No dude, itís the intention to keep it all a bit more simple. To get the box up in an easy way, Iíll have to use 2 heavier springs.
I can make the tension higher on those springs, so that you donít need that much strength to get it up.
Originally Posted by dedo View Post
You again.... I love your skill. As I said earlier, you are my HERO!!! I am really looking forward to see progress with this little VW.
Sorry dude, I canít help it.
But no worries, what Iíve got planned here will be more simple.
Originally Posted by RedBeamer View Post
Aah someone i know from Belgium
Nice to see you have started a new project for you wife
As many may have said here you are a real hero to the car modding !!!!
Looking forward to see more updates on the polo and to see your bimmer ^^
Thanks my fellow countryman. I do my best.
Originally Posted by hennep E46 View Post
Looking forward to see more updates on the install, hope to see you again next year
Thanks mate, hope to see you next year on the TWA meeting.
Originally Posted by Jesse M View Post
That is art my friend. Audio setups are my forte. I really admire this build so far. What are you other plans for an interface up front? I also like that you chose the four smaller woofers. That was actually a plan I had to use sometime in the future. But what I really love is the bus bar. Genius. What kind of power are you running through it; was copper not an option? Just curious because alum has a bit higher resistance. Shouldn't really notice much of a change though, it's a short run. You make it look so easy. Hats off to you sir, sub'd.
If you donít have much space, I personally think that little woofers are a perfect solution. I applied this for several times already, and every time I was satisfied with the sound.
I wanted to do something different with the connections of the woofersÖnot the copper connections I did in the bimmer. I donít like doing the same things twice you know.
But I just need to think what material Iíll use for this.
Originally Posted by ShadoWraceR View Post
just of curiousity, what leasing and vw main dealer says about mod of audio? insurance also. i ask it because some local dealers here dont accept any audio mod, even from profs. when they get to know about it, factory warranty end at this moment. how is things in belgium and in holland?
There no problem for the guarantee. And here in Belgium, I only have to go to technical inspection after four years.
There they will see that Iíve got an install, but wonít make a big deal about it. Just have to pay 6Ä extra for my green card.
Donít know how it is in HollandÖ Laws are different than in Belgium I guess
Old 12-17-2012, 11:35 AM   #23
robolop
My Ride: 323ci
Hey dudes, thanks for the comment. Honestly, I had some doubts about posting the Polo project here.
After all, itís a BMW forum.
But I like it that you guys have positive reactions on other cars as well.
Old 12-17-2012, 01:27 PM   #24
robolop
My Ride: 323ci
Cause of the cold this week, I didn't manage to do much. Where I'm working at the moment, there's no heating, and you can feel the cold comin' out of the ground. There are nicer days to work on an install.
The 2 alu frames (for the glas to rest on) are finished. On the back of the subbox, where the hinge is placed, I had to weld an extra iron.
After that I drilled a LOOOOOOOOOOOOOOT of holes in the aluminium, and also in the iron and alu bar. After that I made some screw-thread in there so I could tighten it all nicely. Remember, the subbox needs to be 100% closed.
Once the holes were good, I taped the glass onto the aluminium.
I chose 2x4mm laminated glass. This is the same as the glass that's in your front windshield of your car. I chose this because it's superstrong, be also, must it ever break, the shattered pieces won't fall apart, due to the special film that's in between.
You never know the glass will burst after my wife plants a bag of potatoes into the trunk, then it won't be the end of the world... just needs a new glass.
I glued the glass with black TEK7.
I left this to dry for more than four days, and it still wasn't dry. Probably because it's cold and moist in my garage for the moment.
Then I worked on the connections of the woofers.
Here you can see the 8 alu tubes where the cable gets through. You can also see LED holders, and little O-rings.
First of all, I glued the led holders into the alu tubes with 2 components-glue
Because my cable didn't got through anymore, I had to abrade the LED holders one by one till the cables got through again.
F*CKN JOB...
Another shitty job was that I had to sand down the inside of the holes, where the tubes glide through.
Once all this was done, I could place the tubes through the holes without scratching it.
You can also see the O-rings I slipped over it, to get a nice finishing touch.
With these connections I want to prove that it doesn't always have to be copper, and you can make nice things with normal stuff.
Here you see how the glass rests on the subbox, and how it's screwed. Offcourse I'm going to place rubber in between to get a more perfect seal.
The glass on the amplifier part: This will be tightened with a couple of screws, so if I have to turn the EQ, it's just a matter of screwing some screws loose.
Another cool shot
Old 12-17-2012, 04:29 PM   #25
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
E46 Coupe is offline   Reply With Quote
Old 12-17-2012, 11:45 PM   #26
328iBMW
My Ride: C320
Thank you for posting this. I love reading your threads.
What makes you come alive?.........Go do it.
328iBMW is offline   Reply With Quote
Old 12-18-2012, 03:19 AM   #27
hennep E46
My Ride: BMW e46 318i 1998
Always amazing, i just love reading your threads. It gives me ideas once i start with the audio setup. It deffinatly won't be as allaborate as yours
hennep E46 is offline   Reply With Quote
Old 12-18-2012, 04:03 PM   #28
robolop
My Ride: 323ci
Originally Posted by E46 Coupe View Post
Thx dude's
Old 12-19-2012, 05:01 AM   #29
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
new project awesomeness
/_________\
O==[][]==O
Old 12-19-2012, 05:18 AM   #30
robolop
My Ride: 323ci
Exiting day today.
I mounted the box into the trunk. I used every inch possible in there, but I had a good feeling when I let the thing go up and down.
I had to do a minor adjustment with the hammer. The box didn't go (only for a couple of mm) by the eyes on the back of the trunk
STOP- Hammertime! lol
You can see how close it all is.
I also changed something on the hinge and now I need to finish it off.
When the trunk is up to gain access to the spare wheel, I need to flatten out the back seat
I think the spare wheel is easy accessible, no?
Old 12-29-2012, 03:56 PM   #31
robolop
My Ride: 323ci
I managed to lift the box in the trunk, without using much force.
It lifts easy with only using a couple of fingers.
You can see how easy I managed to solve this.
I welded 2 springs together. I had to do this cause 1 long one, wasn't strong enough.
I also used a steel cable of 3mm.
To tighten these, I used some ordinary luster-clamps.
You can also see I mounted the springs on top of each other, otherwise there was no room.
You can see on the length of the cable, I can still add more tension on it.
That I will do once it's all mounted, then I can do the fine tuning of it.
Here you can see how tight it all is next to the box, and what I mean with putting the springs on each other.
The springs and the hinge, there's also some fine-tuning necessary. I have to sanded down, and spray it.
Around the springs I'm going to pull a tyre of a kidsbicycle, so that it can't vibrate.
The box is placed on 4 rubbers, also for the vibration. But I also had to make something to tighten the box on once it's closed.
I had to do this in a simple way, so that my wife didn't need to go throught a procedure of 10 things before getting to the spare wheel.
I've managed to solve this with only 1 inbus-screw
The shackle I made, is screwed in the trunk. You can also see a rubber cap on it.
Underneath I tapped some screwthread.
Then I made a little aluminium plate, and screwed it to the box.
So when the box is closed, the plate comes directly on the shackle.
I tuned this with another inbus-screw (M10).
And so you can screw it loose or tight with only 1 screw.
Sometimes I wonder what the hell I'm doing with the bimmer.
When I was working on this thing, I ask myself why I'm not doing things more simple. No head-aches, and in a much faster pace.
Old 12-29-2012, 04:20 PM   #32
robolop
My Ride: 323ci
Yup, this is something of an 'inbetweener'.
But if this would take as long as the bimmer project, than my wife would buy another one I think.
Old 12-29-2012, 08:50 PM   #33
djnekkon
My Ride: MB3ci & z33 HR
me like it very much my friend..
Old 12-30-2012, 04:01 AM   #34
hennep E46
Great work my friend
Old 01-02-2013, 02:50 PM   #35
robolop
My Ride: 323ci
I started making the panels for the sides. A work that shouldn't be underestimated.
When I used to go and check out the cars in competitions, this was the first thing I looked at.
And yes, I checked out MANY installs, and I've seen many, many side panels that don't fit at all.
There are many people that put so much effort in creating a nice box for the woofers, the placing of their amplifiers, ... But when it comes to the side panels...they forget.
On the other hand, in some cars it's just not that easy to make side panels for, and the Polo was one of them in my opinion
After thinking for a while, I knew what I wanted, and then I made this.
First I cut out a model out of cardboard and tape, and made this mold out of wood (6mm).
Because I didn't want to have a fat big side to look on, I added aluminium of 2mm thick?
Glued it on with Tec7 and put on some screws on the back
So this will be the side panels I'll put into the trunk. And because I wanted them to be as thin as possible, so I made it with wood of 6mm thick.
The sides are made of 2mm aluminium.
I first cut out a mold in cardboard, and sew it out.
Once you have one, turn it around, and you've got number 2.
Because I want to make use for every inch in the trunk, I made holes L and R, so you can put something in there.
By doing this, I also break a rather rag surface that doesn't look good.
The model of the holes won't be equal L and R, that's because I can't go bigger on the right, cause the supply of the gas-tank is there.
I also made a thickening of 1cm around the hole, as you can see clearly on this piece.
What you have to look out for is when you work with wood and aluminium, is that your filler you use is appropriate for these 2 materials.
Because I also wanted a nice rounding at the bottom, I screwed and aluminium L on there, and finished it off.
Creating a rounding is pretty simple.
Here I used a spraycan of deodorant, where I put my sanding paper on. But there are several things you can use as sanding blocks.
Then I taped the sides of the plastic where the come against.
Then I put some filled on the back of the panels , and mounted them.
Once it's dry, you can take it out carefully, and it looks like this.
After some sanding work, it looks like this
It looks quite simple, but it isn't. I've made this a couple of times now, but in the beginning it didn't go that well.
I wasted a lot on these things to make them look good.
Because the glass plate (EQ) must go open smoothly, I screwed another alu plate on there. So I don't have to walk around with a sucker.
Here a picture with the sides in it.
What I personally love is that the separation between the sub-box and the amplifier is made out of glass. It gives the impression it's one piece, but it has 2 compartiments.
OOOOooo yeah, the PPI Deq 230 EQ just got a bit smaller.
Cause I haven't got that much space, I put the disc in that thing.
Robolop Design hť, lol
Old 01-03-2013, 01:48 AM   #36
hennep E46
Amazing work as always
Old 01-04-2013, 06:30 PM   #37
robolop
My Ride: 323ci
Old 01-05-2013, 02:04 AM   #38
robolop
My Ride: 323ci
I let someone make me a set of alu little busses, to go in between the amp and the EQ.
I'm planning of polishing these, so they shine like a mirror. Like that I'll get a nice contrast with the matt alu plate on the bottom.
The 4 who are a bit longer, holds everything that's on the amplifier, in place.
This will be the coverplate which will rest on the glass.
I made this one in 8mm thick MDF wood.
Off-course I made the 2 holes as big as possible, so you can see as much as possible of the install.
Because the middle of the coverplate is quite wide, I was afraid that I'd loose the effect to see from the front, to the back. But it's really ok, it's still looks fine.
Off-course I'm going to add some lighting in there too.
Here are a couple of things I picked up from the motorhos in Essen (DE)...
Old 01-05-2013, 03:04 AM   #39
ShadoWraceR
Location: Estonia - Tallinn, sometimes Holland and Germany
My Ride: Audi V8 3.6
nice work as always
ShadoWraceR is offline   Reply With Quote
Old 01-07-2013, 06:04 AM   #40
robolop
My Ride: 323ci
Everything I made for in the back of this Polo thus far, is removed from the trunk now. So I can give the trunk a good clean now.
The meaning now is to rebuild everything the install, outside of the trunk. But there's a lot of work to be done first.
Some of the iron, aluminium I used, will be sanded off, and sprayed black.
The wooden box, which holds all of the components, will be glued together. The aluminium on the bottom will be glued tight with TEC7.
I was planning on making a carbon plate for it, but where I'm working now, it's too moist, and I'm afraid it won't be perfect...So I'll have to come up with something else.
I also need to mill some other sloths in the bottom of the box, where the cables are.
These sloths go towards the sides, but if I look at it now, I just haven't got space to place my cables there. Pretty stupid of me, I should have known.
Everything is ready to be covered in skai-leather, but I just can't. Because it's a daily car, we'll have to use the trunk to place all our purchases in.
This means, when I buy some wood (or whatever), I have to put it there. It's not possible to always put a blanket in there, being scared of scratchin' it a little.
The best thing I can do is to cover it in to find the same piece of cloth the trunk is made of, and cover it in that.
Offcourse, that will look like SHIIIIIIIIIIIIIIT, but then again, maybe I should have left it like it was.
Sometimes women are right...SOMETIMES I said
I'll sleep another night on it, before I open a bottle of glue.
