E46 M3 Rally Road porsche brembo M3 kit complete-Kit is sold - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 12-18-2012, 12:53 PM   #1
jimmione
My Ride: 03 BMW m3
Up for sale is a Rally Road Brembo Porsche BBK conversion kit! This is a complete kit, was installed on my car for over a year. The kit includes the following:
Front brakes:
Boxster S front calipers (machined by Rally Road to accept their bracket)
Rally Road bracket
Rally Road extended SS brake lines
Porsche Textar brake pads
OEM ZCP 345mm BMW brake rotors
Calipers were purchased used, no leaks or other issues; bracket/lines purchased new; pads in good shape. ZCP rotors purchased new, have about 30k miles and at least a dozen track days. Just turned, still in spec
Rear brakes
Boxster S rear calipers
Rally Road bracket
Power Slot brand, slotted and cryo treated oem sized/vented 328 mm rotors
All calipers off same low mileage donor car, one rear caliper dust boot is torn, should replace all dust boots on pistons; easy and cheap; bracket/lines purchased new same as fronts. Pads are recent. Rotors have about 5k miles, only a couple of track days.
Best reason to convert to this kit is if you want to track your car, even occasionally! Street brake pads can't cope with the track, except maybe your first day. With the Brembo calipers, switching from street to track pads is super easy, takes about a minute if you have a (reasonably cheap) pad spreading tool.
For the fronts, I have a set of Porterfield R4 pads (used once) and a half used up set of Performance Friction 06 pads (awesome track pads!).
For the rear, I have a just purchased (used one day) set of Performance Friction 06 pads.
Finally, I obtained a set of p0lar titanium backing plates that will keep your calipers and fluid cooler on track days. These are brand new!
If you were going to buy all this stuff on your own:
Porsche Boxster S/Carrera 996 calipers-700ish for a used set, another 75 to machine the fronts to work with the bracket, plus shipping it back and forth to RR to do the job
Rally Road brackets front and rear 350
Rally Road lines 130
Textar pads F/R 150 new
ZCP rotors 430 new from Tischer, maybe 200-250 for a used set
Power Slot rear rotors were 200 new, maybe 100-150 for a used set
Porterfield pads were 200+ new, used one day
PF pads are 250-275 an axle new; rears are used one day, fronts 1/2 used
p0lar plates were 65 new, unused
plus shipping, tax, paypal...
About 2700+ so far...
This is a great looking kit for street and track! A great entry level BBK for someone who is been bit by the track bug without going bonkers for a full Brembo/Stoptech BBK that will cost 5-7+k! The best part is this kit is that it uses or can use OEM rotors which are dirt cheap compared to the 2 piece compound rotors on the big boy kits. You can get OEM rotors cheap and if you hunt around, find killer deals on aftermarket 2 pc or Euro rotors used. There are a couple of those killer deals on this forum right now! There is a PowerBrake ZCP group buy going on for ZCP front rotors and a set of Performance Friction rear 2pc rotors used going for a song...
jimmione is offline   Reply With Quote
Old 12-18-2012, 02:14 PM   #2
Pete_repete
My Ride: 98 Civic, 02 M3
Do these fit with the stock 18" wheels? I see they do in one of your pictures but do you need any spacers for the car?
Pete_repete is offline   Reply With Quote
Old 12-18-2012, 05:06 PM   #3
jimmione
My Ride: 03 BMW m3
I'm using oem 19's actually, but I've been using a square set of oem 18's on the track with no issues. It uses ZCP front discs, so it shouldn't be an issue. I just sent a message to Rally Road to confirm that you don't need spacers
Old 12-19-2012, 10:07 AM   #4
wshgrntd
My Ride: 2007 335i m-sport
Would this fit on a sedan?
wshgrntd is offline   Reply With Quote
Old 12-19-2012, 10:19 AM   #5
jimmione
My Ride: 03 BMW m3
I'm assuming you have a non M3 e46, since they didn't make a e46 M3 sedan. According to Eric at Rally road, you can use the calipers/pads, the SS brake lines and the rear rotors from my kit, but you'll have to get new non M3 front brackets, new e36 M3 rear brackets (also work with non m3 e46) and oem sized 325mm front rotors. Also, you'll have to machine an add't 6.5mm off the front calipers, which rally road also does. If somebody wants those parts from me and I can find buyers for my brackets and front ZCP rotors, I'll part the kit out!
Old 12-19-2012, 10:26 AM   #6
jimmione
My Ride: 03 BMW m3
Eric at Rally Road says you "may" need spacers with oem 18's. Has anyone else out there ran this set up with oem 18's?
Old 12-19-2012, 12:48 PM   #7
Pete_repete
I have 15mm spacers in the front but none in the rear
Old 12-19-2012, 01:46 PM   #8
jimmione
My Ride: 03 BMW m3
That would probably be more than enough!
Old 12-21-2012, 12:11 AM   #9
jimmione
My Ride: 03 BMW m3
I'm withdrawing the p0lar rear brake brackets from this deal as I have a local buyer for those. The rest of the kit is still available!
Old 12-26-2012, 12:04 PM   #10
jimmione
My Ride: 03 BMW m3
Deal on rear brackets fell through, entire package is still available. Super cheap front and rear Brembo BBK anyone?
Old 12-27-2012, 06:01 PM   #11
jimmione
My Ride: 03 BMW m3
let's get this sold before the end of the year!
Old 12-28-2012, 11:41 PM   #12
jimmione
My Ride: 03 BMW m3
bump it time
Old 01-01-2013, 11:30 AM   #13
alpine325coupe
My Ride: 2004 M3 SG/IR
Free bump. I have these calipers on my M3. Great budget BBK
2004 Silver Grey / Imola Red - 146k Daily Driver
ENGINE: Scoop, Filter, Elbow, Pulleys, Tune, fan delete+SAP delete
EXHAUST: Headers, Rasp sec. 1, res. x-pipe, TopSpeed muffler
SUSPENSION: BC, subframe reinforcement
WHEELS/TIRES: Hamann PG1, 19x9.5 +25, 19x10.5 +25
DRIVETRAIN: 4.10 gear ratio
LIGHTING: Orion V2, 3000k fogs
INTERIOR: Recaro SPG reps, Cobywheel, CF trim, Dynavin clone, Stealthboxes
alpine325coupe is offline   Reply With Quote
Old 01-01-2013, 02:08 PM   #14
jimmione
My Ride: 03 BMW m3
Are you running stock wheels and if so, did you need spacers? I'm getting questions about that, I've never ran oem front wheels with the kit so I really don't know. Even Eric at Rally Road didn't know for sure...
Old 01-02-2013, 09:26 AM   #15
alpine325coupe
I'm running OEM 18s. Spacers are needed in the front. I have 12mm right now but you can get away with 10mm or maybe a little less. Rears do not need spacers.
Old 01-03-2013, 09:28 PM   #16
jimmione
My Ride: 03 BMW m3
Kit is sold!
