Old 12-19-2012, 04:04 PM   #1
Zach330ci
My Ride: 2002 330ci
Clutch question!
I'm wanting to replace my clutch for something stuffer, I'm thinking about a spec stage 1. Does anyone know if I can use a stock fly wheel with this clutch set up? I haven't heard good things about lightweight fly wheels so I want to stay away from them, any knowledge is helpful!
Zach330ci is offline   Reply With Quote
Old 12-19-2012, 08:23 PM   #2
E46330iguy
My Ride: Supercharged 330i
Why do you want a stiffer clutch? Do you race often? If you just want a stiffer pedal you can buy stiffer pressure plates
Winter Authority When Hell freezes over,we'll play Hockey there too
Its fundamental to our nature, man must explore.
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/ Bimmerbrake / MTechII/AA Stage one (for now)
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 12-19-2012, 08:24 PM   #3
Zach330ci
My Ride: 2002 330ci
Well I was planning on auto crossing eventually once my car is built enough for it
Old 12-19-2012, 08:50 PM   #4
lcoleman
My Ride: '79 Massey Ferguson
Lightweight flywheel is the best performance bang for the buck. Not much negative, unless it's too light (<10 lbs).
I'd go for the Valeo single mass flywheel and non-SAC clutch, though.
Old 12-19-2012, 08:53 PM   #5
E46330iguy
If your putting down normal power i wouldnt bother getting a differnt clutch unless you want to go once a week . Light weight is good for Auto X but horrible for Drag racing
Old 12-19-2012, 11:20 PM   #6
Zach330ci
My Ride: 2002 330ci
I have liked the spec clutches in every car I drove
If I wanted a stage 1 I would need to get a new fly wheel? And would a stock/non lightweight fly wheel work with that clutch?
clutch, fly wheel, spec, transmission
