///M3 Forum
Old 12-21-2012, 03:54 PM   #1
Ballstowalls
My Ride: 05 e46 m3 vert
Launching
How do use guys Launch a SMG M3 with out launch control. Kind scared to use launch control lol.
Ballstowalls is offline   Reply With Quote
Old 12-21-2012, 04:30 PM   #2
danwilz
My Ride: E46 M3 Vert 2012 X5
Obviously your not balls to the walls.
danwilz is offline   Reply With Quote
Old 12-21-2012, 05:14 PM   #3
joeysm3
My Ride: ///M3 02
joeysm3 is offline   Reply With Quote
Old 12-21-2012, 07:09 PM   #4
Ballstowalls
Lmao I'm just asking how u guys do it
I put my foot on brake rev to 2 let go of brake and hold on lol
Tracking off, S6 , and sometimes sport on doesn't do much.
But launch control scares the **** out of me not trying to brake my pump agin..
Old 12-21-2012, 07:27 PM   #5
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
So you are pretty much executing launch control except for the fact that you are not holding the sequential shifter back.... Not really sure what the difference is.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 12-21-2012, 07:42 PM   #6
Ballstowalls
Im sure there's a difference launch control puts the whole tranny under tremendous stress and pressure. I don't think I'm putting as much stress with the way I launch please correct me if I'm wrong.
Old 12-21-2012, 08:02 PM   #7
scca_ziptie
When you use launch control the car has the clutch disengaged - the way you are doing it the clutch is engaged, car trying to move forward and you are "holding" it back with the brakes. If anything, the way you are 'launching' the car is harder on it compared to using the 'real' launch control as you are putting a load on the transmission..
Old 12-21-2012, 08:15 PM   #8
NICKBRUM
My Ride: 2004 M3
When you use launch control the car is at least in neutral - the way you are doing it the car is in gear trying to move and you are "holding" it back with the brakes. If anything, the way you are 'launching' the car is harder on it compared to using the 'real' launch control as you are putting a load on the transmission..
What he said! US spec LC maxes out at about 1900-2000 rpm with your foot held to the floor which is low when speaking in regards to launching a car. You can also apply even less throttle and get the rpms to bounce around 1000-1200. I say launch the car! The subframe mounts are likely to crack regardless, and that is really the only part of the car that you should worry about when doing this.
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 12-21-2012, 08:20 PM   #9
Ballstowalls
Ok cool that makes sense thanks. But when I do it I don't hold the RPMs for long max 2 seconds
And I have a convertible Aren't the subframes reinforced?? So will I be fine
Old 12-21-2012, 08:42 PM   #10
NICKBRUM
My Ride: 2004 M3
What your currently doing is putting a stress on the whole drive train. Are any of them enough to hurt the car? My opinion is no. With that being said its a real inefficient way to launch. LC is exactly the same as dropping the clutch in a normal manual car. There is nothing magical going on when you do this. Since the clutch is controlled by electronics that drive hydraulics, LC allows you to have the car in 1st gear and drop the clutch at your demand.Euro spec software is upwards of 4k rpm when it lets go, now that is a effing launch!!
Current:
Previous: Totaled
Old 12-21-2012, 08:45 PM   #11
Ballstowalls
Wow 4K!!! That sounds good to me. Ill look into better software then thanks .
Old 12-21-2012, 08:49 PM   #12
scca_ziptie
this
Old 12-21-2012, 08:55 PM   #13
danwilz
And you have a vert too so don't worry too much about the subframe.
Old 12-21-2012, 09:21 PM   #14
NICKBRUM
My Ride: 2004 M3
Hmm if your scared of a 2k launch, why go to 4k? Unless you have great tires you will burn out with US spec LC anyway. I have Hankook V12's which came with the car. These tires will not hook up even with a 2k launch. I have to feather out of the throttle to hook up. With my rubber a quick 1/2 stab of the peddle gets me off the line the best. if you mash 100% throttle that is burnout mode, which is exactly that.
Current:
Previous: Totaled
Old 12-21-2012, 10:04 PM   #15
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
LC and Burnout mode are initiated the same way with a small difference. For LC mode, you press the accelerator pedal slowly to the floor. For Burnout mode, you stab the pedal to the floor.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 12-21-2012, 10:14 PM   #16
NICKBRUM
My Ride: 2004 M3
From one SMG guy to another, what am I missing?? For LC you must hold the shifter forward in S6. I have not noticed a quick or slow pedal mash to make a difference while doing this. I have done both holding the stick keeps the clutch engaged, so no difference IMO. Burn out is just S6 and a full pedal mash from a stop. Im just trying to clear it up for those less informed.
Current:
Previous: Totaled
Old 12-21-2012, 10:28 PM   #17
Ballstowalls
Not scared to launch lol I'm scared to brake it...
Old 12-22-2012, 12:12 AM   #18
turbo_f22_pilot
For either mode,
DSC off
S6
Shifter forwar
d
** for Launch Control **
just slowly roll the pedal to the floor.
OR
** for BurnOut Mode **
mash the pedal to the floor
Launch Control will attempt to not so harshly engage the clutch to reduce wheelspin. (Tires and suspension greatly affects one's sucess)
Burnout Mode will fully lock the clutch enabling burnouts
NOTE: There are a number of other tricks that you can employ depending on which program your vehicle has (NA or EU) I have the EU3/CSL program.
Also, the LC usage is stored in the DME
Joy is future proof
CAR:
MODS:
BMWCCA NCC
Old 12-22-2012, 01:36 AM   #19
Ballstowalls
Thanks for all the info guys
Old 12-22-2012, 11:35 AM   #20
m3e46freak
My Ride: m Twee lol
I would not launch my SMG ever. To much to pay for a massive SMG failure, I do track the balls off it though....
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
