///M3 Forum
Old 12-23-2012, 03:39 AM   #1
greenhel
My Ride: e46 m3
car pulls to the right when accelarating
Can anyone tell me what the cause is of the following:
when I accelerate the car pulls to the right.
Personally I think something with the drive shafts or differential.
it does not happen when braking.
greenhel is offline   Reply With Quote
Old 12-23-2012, 03:54 AM   #2
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
First thing is to check your tire pressures. You should write down what you have checked at least so we can narrow it down.
Old 12-23-2012, 02:01 PM   #3
taylor192
My Ride: 2003.5 M3
Put the rear up in the air and grab each wheel at 6 and 12 and 3 and 9. Shake the wheel, if it moves then you have a bad bushing/ball joint or a loose bolt.
Old 12-24-2012, 02:52 AM   #4
greenhel
My Ride: e46 m3
Ok Taylor.
The car goes back to the shop.
The placet wheel nuts in sted of bolds for easy placing
other wheels whith spacers on it.
Maby something wrong?
Old 12-24-2012, 10:05 AM   #5
taylor192
My Ride: 2003.5 M3
Ok Taylor.
Shop? The test I described you could do yourself with a jack and a stand - although a shop will hopefully be able to provide a better diagnosis.
I'm assuming you did a bolt to stud conversion with spacers - yet I doubt this would cause the issue you're experiencing. You'd get wheel hop or vibrations.
Old 12-24-2012, 01:32 PM   #6
djantlive
My Ride: E46 M3
i would get it looked at asap
it could be alignment. does your tire wear evenly fron edge to edge? it could be bad bushng, loose suspension, or wheel bearing.
the self diagnosis to pull on the wheel is a good way to see if bearing or suspension is bad. but i guess you need to fix it professionally anyways so why not take it to a shop to have it looked at. i suggest a specialist or a wheel shop if it's an alignment only.
djantlive is offline   Reply With Quote
Old 12-27-2012, 03:06 AM   #7
E46DrEaMeR
My Ride: 2002 320Cic
it could also be a sticking brake caliper causing it to pull on one side
It's a ragtop thing....you would'nt understand
E46DrEaMeR is offline   Reply With Quote
Old 12-27-2012, 10:03 AM   #8
M3SMG!
My Ride: 2002 M3
rcab if there torn or soft.
M3SMG! is offline   Reply With Quote
Old 12-28-2012, 09:22 AM   #9
greenhel
My Ride: e46 m3
thanks for all the thinking guys.
the M is back too the garage finding out whats wrong.
let you all now what the find.
Old 12-28-2012, 10:53 AM   #10
Verooom
My Ride: 2005 M3 Cabrio
I had the same issue before. What they found out was the RTAB (Rear Tail Arm Bushings) were torn. Had it replaced and it stopped pulling.
2005 Carbon Black M3 Convertible
2005 Mercedes-Benz SL55 AMG (SOLD)
2007 Ferrari F430 F1
2012 Nissan GT-R Black Edition
Verooom is offline   Reply With Quote
Old 12-29-2012, 12:28 AM   #11
NICKBRUM
My Ride: 2004 M3
This is going to be your problem 99%. If you have any other questions let me know, I'm happy to help.
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|
NICKBRUM is offline   Reply With Quote
Old 12-29-2012, 08:05 AM   #12
greenhel
My Ride: e46 m3
Ok Nickbrum thanks for the offer.
Old 12-29-2012, 12:43 PM   #13
NICKBRUM
My Ride: 2004 M3
You bet! So if it turns out to be bad Rtabs you should consider OEM bushings with Polly limiters, or Powerflex red Polly bushings. Everyone one running either seem very happy with the handeling and bushing longevity. Powerflex are easier to install so it may reduce the labor cost a bit if you paying an Indie.
