Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
Display Modes |
#501 |
My Ride: 04' 330ci & 99' 540i
No problem. If you want one done for your sedan let me know. I can do any color/material
#502 |
Jesus, after the next upgrades this is gonna be a whole new beast
Coming Soon...? |
#503 |
If you don't have one already get an ATI damper especially with a light flywheel.
John V
'03 330i ZHP 6sp street car '02 330Ci 5sp race car |
#504 |
Will do. I just hate the fact that it takes three to make.
#505 |
Coupe, and what did you use, plywood?
![]() Want a handmade shift knob or custom vinyl stickers? PM me I'm sixteen and like cars with three pedals. My ever small company... www.facebook.com/StgFabricationAndMolds |
#506 |
Plywood for the bottom part (a certain type of wood to retain the weight loss) and styrofoam for the top part.
#507 |
Nice I just put in the Bimmer world and rogue tranny mounts great combo not a lot of vibration and deff noticeable .. Your going to love the cams man they are awesome. I think your out doing me with that clutch though
![]() Last edited by Steven747; 12-23-2012 at 01:15 AM. |
#508 |
Yea they seem to be the best mounts for a street driven car. Everyone who has them, love them. I kept debating on whether to get those or the AKG ones, but I think poly would be too harsh, especially since I already have the poly subframe bushings. I can't remember, did you install the cams yourself? If so, how hard was it?
I might have the clutch but you still have the damper!
#509 |
i have vorschlag poly motor and trans mounts with powerflex poly subframe mounts its not that bad
little bit of rattle every once and a while to go along with the lightweight flywheel why not go with the 4 bolt oil pump its just future proofing yourself/car
#510 |
I want to, but I might have to hold off for a few months. Gotta save up some money first. I should be fine with the safety wire until then.
#511 | |
#512 |
It's a lot better to fix the cause of the oil pump problem (harmonics) than try to band-aid a solution (safety wire, welding, etc the OPN).
John V
#513 |
I fully understand what's going on with the oil pump nut I just don't feel the need at the moment even with my mods as well to do p.m. On it ..maybe a good thread of someone's engine blowing because of it ill do it
#514 | |
#515 |
engine mounts take less than 20 minuets lol so do tranny
#516 |
#517 |
Lol if my diff bushing fails again I'm selling the car before I do that job again.. Epic epic pita.. Get the oem tool or trying to get it out will eat you alive. I've never touched my subframe or bushings though and I don't Plan on it really
#518 | ||
Yes. I don't see the reason for them now since I won't be touching the head or block. The motor and tranny mounts yes, the subframe and diff (including the LSD) no. Maximum PSI will be doing the work for me. It's not a matter of difficulty, but more so that I don't have a lift at home. I'm certainly not attempting it on jack stands lol.
#519 |
Mister TechnoMeister
Stav, do you still have the templates for the rear seat delete. im planning on doing this soon.
#520 | |
i took out the whole rear end and burnt/pressed out the old ones and installed new powerflex subframe bushings as well as M3 rtab's + limiters +alignment in 10.5 hours with a lift first time doing it i didnt think that was to bad
