E46 Xi Forum
Old 12-26-2012, 12:54 AM   #1
Twin_Turbo_S54
My Ride: M3
IX on E46 M3
Can we install the IX system on a E46 M3?
First of all, the main carrier has to be installed.
Main carrier of the M3 is much different, where the IX carrier is a rectengular part.
Is it possible to install the IX carrier on a E46 M3?
If I can install IX carrier, the rest will follow, I can build the system on the carrier. But the carrier must be installed very precise as the rack & pinion is attached onto the carrier as well.
I wonder if IX chasis has unique carrier mounting points which the E46 M3 does not have.
8 seconds 1/4 mile & sub 3 seconds 60-130 mph AWD M3X coming soon
4,23 s 60-130 mph E46 M3 TT
4,49 s 60-130 mph E36 M3 TT, 3,49 s coming soon RWD mode
8,45 s 60-130 mph 997 Turbo
Twin_Turbo_S54 is online now   Reply With Quote
Old 12-26-2012, 03:13 PM   #2
e46alfonso
My Ride: AW 330xi manuel
You can't make the m3 awd but you can swap an m3 motor in an xi. The transfer case and diffs can handle the s54, no problem.
Old 12-26-2012, 03:51 PM   #3
rcsummers
Mister TechnoMeister
rcsummers's Avatar
My Ride: M3
not worth it.
only way to do it would be as alfonso said. Drop an S54 into an XI.
"RICH"
EURO.TECHNIKS
My Build Thread
rcsummers is online now   Reply With Quote
Old 12-26-2012, 03:54 PM   #4
Twin_Turbo_S54
My Ride: M3
Originally Posted by rcsummers View Post
not worth it.
thank you.
do you have any photos of the underside?
Old 12-26-2012, 05:02 PM   #5
rcsummers
rcsummers's Avatar
My Ride: M3
Originally Posted by Twin_Turbo_S54 View Post
thank you.
I dont, but im sure Google Images does.
"RICH"
EURO.TECHNIKS
My Build Thread
Old 12-27-2012, 02:56 AM   #6
Asher454
My Ride: '04 325xi
How would the tranny hold up to the S54? In an xi?
Asher454 is offline   Reply With Quote
Old 12-28-2012, 08:32 AM   #7
Visor328i
My Ride: rolls on VS-XX
Didn't think this was possible, anybody done it recently?
Visor328i is offline   Reply With Quote
Old 12-28-2012, 10:20 AM   #8
Dirty Mike
My Ride: Fern Green 330ci
I didn't think that the XI tranny's could handle the power, although this would be awesome.
Dirty Mike is offline   Reply With Quote
Old 12-28-2012, 10:20 AM   #9
SamDoe1
My Ride: 2004 330xi, 3 pedals
You would need the trans from the S54 so it doesn't matter. The biggest risk would be the front diff and transfer case. Also, the adapter from the trans to the TC would have to be fabricated as I'm not sure it mates to the M3 trans.
It's been done on one car by some shop out east. It wasn't cheap and probably wasn't worth it. Adding a supercharger to a 330xi will get you nearly the same output of the S54 for much cheaper so I fail to see the point...
Old 12-28-2012, 08:46 PM   #10
SLVRXI
My Ride: 2001 325xi
It has been done an finished by Impressive Auto Center, I called an asked them about the swap. In this case it would be cheeper just to buy A M3. All said an don he told me the swap all together ran about $15,000. He had to have the transfer case, an axles rebuilt to hold the torque. An thats just the beginning of the list of custom parts he had made. There's a video on YouTube about it.
SLVRXI is offline   Reply With Quote
Old 12-31-2012, 10:06 AM   #11
hassmaschine
My Ride: '91 325ix
the S54 isn't really a high torque motor. I've taken apart an E46 front diff and it's really not that weak either - the E30 ix's front diff is much weaker, and it'll take 300-400hp. And isn't the TC gear driven? there seem to be a lot of xi front CV shaft problems though.
the biggest weak point is the xi AWD system being based completely on the brakes adjusting the torque vector. It probably works fine but your brakes are going to be working extra hard.
the ZF trans from a 6-speed xi should very easily be able to handle the S54's ~260ft/lbs of torque. Hell, you can build an M20 that makes that much torque. it's not like it's a twin turbo V8 or something. I don't think I'd want to do it with the M3 trans, there are drivetrain alignment issues to consider - the Getrag needs to be the exact same length with the adapter or the mounts for the TC and driveshafts will no longer fit. It makes more sense to use the ZF 6 speed. The ratios are almost identical anyway.
Usually BMW drivetrain parts can handle at least 50% more torque than they see in service, if not more. the M54B30 doesn't really make much less torque than an S54 either - about 20ft/lbs.
hassmaschine is offline   Reply With Quote
Old 12-31-2012, 02:13 PM   #12
Twin_Turbo_S54
My Ride: M3
thank you very much. Very useful info.
