///M3 Forum
Old 12-19-2012, 06:33 PM   #1
S.J.J.
My Ride: 2002 M3
Apparently I need a new ECU...
My dash recently lit up like a Christmas tree:
DSC, Handbrake, ABS, Tire pressure monitor, SMG cog.
I took it to my indie, and he said the error was with a rear wheel sensor, unfortunately he replaced it, tested all the other sensors as fine, and yet the problem persists. His conclusion: I need a new ECU (~1000?).
He wants to get an electrics expert to check, but he's not available till the new year, so I am hoping to do some research in the mean-time.
Has anyone else experienced this, knows how likely it is, or of any alternatives?
Thanks in advance,
Stu
2002 Euro E46 M3
S.J.J. is offline   Reply With Quote
Old 12-19-2012, 08:46 PM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
I would definitely get a second opinion from another shop. Definitely check traction control and DSC modules. The WSS is the usual problem. The SAS less so.... but possible.
Alan is offline   Reply With Quote
Old 12-22-2012, 09:00 AM   #3
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
If you do end up needing a new ECU, look into getting it repaired / remanufactured. I'm sure there are some other companies in the U.K. But here is some info on one in the states http://www.ecmoutlet.com/
itscoo2pyopants is offline   Reply With Quote
Old 12-22-2012, 09:24 AM   #4
goodtohave
My Ride: 325iT
I diagnsed a bad ECU for a shop using INPA. Shipped itto an ECU shop in British Columbia (canada)
They took it apart and traced it to a short on the O2 sensor circuit. Someone shorted it pulling the engine out.
The ECU's are tough. I doubt it is your problem. You can't replace an ECU without having it coded to the car (the ews and light control if I remember correctly.
I would bring your car to someone who specializes in BMW's and has the diagnostic tools.
goodtohave is offline   Reply With Quote
Old 12-23-2012, 12:59 AM   #5
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Check your steering angle sensor.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 12-24-2012, 12:07 AM   #6
illestminimike
My Ride: Project Drama
This. You don't need an ECU. When was your last alignment? Have the car hooked up to INPA or GT1 and get the codes. They will show.
Old 12-26-2012, 05:26 PM   #7
S.J.J.
My Ride: 2002 M3
Thanks guys for the responses, I will definately check out the steering angle sensor.
Old 01-10-2013, 11:41 AM   #8
S.J.J.
My Ride: 2002 M3
Thanks for all the responses guys, fortunately it turned out to just be a wiring fault near the wheel speed sensor. A fair old whack spent on labour, but at least I didn't need a new ECU!!!!
