Australia
Check out other E46Fanatics members rides in the Enthusist Directory! If you don't have your garage setup, sign up today HERE |
#1 |
Vanos seals replacement
Posted in main forum as well.
It's been long overdue so, following the Beisan guide, started earlier. When I removed valve cover this is what I found. ![]() ![]() ![]() It's a lot of old grease and crap. Is that normal? What's the best way to clean it all up. Thanx. Sent from my GT-I9300 using Bimmer App
![]() German Engineering at its best |
#2 |
Not normal.
IMO, you're going to have to button the whole thing back up again, drain the oil and run some clean oil and an engine flush through and drain again. You'd need to do this until you get all that sludge out.
#3 | |
#4 |
Fill it with cheap oil and about half a can of sea foam. Drive 50 miles or so, then drain it while its still warm.
I swear by that stuff. Works great IMO.
#5 |
I would not use degreaser.
#6 | |
no worries, thanx Sent from my GT-I9300 using Bimmer App
#7 |
Welcome, let me know how it goes!
#8 |
#9 |
I don't know about seafoam, Auto RX is probably a more suitable product.
Don't know about the availability in Australia, I think Sprintman used to be/have a connection to the distributor. You've got me scared to take mine apart to do the seals now.... :/
#10 | |
If it needs to be done then it must be done!! I might even tackle the OFH gasket....
#11 |
Concur with the above - engine flush + cheap oil until it starts looking clean again. I haven't used seafoam or Auto RX so I can't comment.
As for the VANOS, I'm tackling this early next year, time permitting. I would say that you should leave the OFHG for another time. Focus on getting this DIY right first without adding to potential complications. If you were any closer I'd come in and give you a hand (more so to get a first hand sticky beak for myself! )Good luck and keep us posted
![]() I can help with * Reading Codes / Coding your car * R&R FCAs, Tie Rods, Sway links.... * RTABs Need an RTAB tool? Or clutch fan and water pump tools? PM me. |
#12 | |
Yip i am canning the OFHG change for now. That sludgy engine just broke my steam a bit. I will do a flush with the current oil in, then change to the cheapie oil and then do another flush. Thanx.
#13 |
Glad you got it done. Man, I've never seen that much sludge in an engine...ever.
#14 | |
#15 |
What oil were you using and at what intervals?
#16 |
I've owned the car for just over 2 yrs now. This is my second service as i service every 5000 km. I have been using this oil.
![]() From what i discovered, maintenance by the previous owners was just shite!!
#17 |
Try this
or this ![]() Both meet BMW LL-01
#18 |
Castrol Edge Titanium 0W-40 and Mobil 1 0W-40 are considered to be the best oils by general consensus.
#19 |
My Ride: Ex 325CI owner
#20 |
Not a big fan of the Shell. Am doing a run of the Penrite to see results...
How are you doing, Rod?
