Old 12-27-2012, 12:08 PM   #1
jcallanan
My Ride: 2000 328Ci
Wiring Harness - Can Anyone ID this wire?
Did the CCV system / oil separator and in putting everything back together, I seem to have lost my way with one of the harness connectors. See the pic - it's the bottom wire of the three lower ones coming out of the harness. I can't figure out where it plugs into. Anyone know?
It's a 2000 328Ci.
Thanks in advance!
jcallanan is offline   Reply With Quote
Old 12-27-2012, 10:40 PM   #2
trentcdrums
My Ride: BMW 323i Sedan
Disa? Mas? Icv?
Old 12-28-2012, 11:36 AM   #3
jcallanan
My Ride: 2000 328Ci
Found it, I think, but still problems
I believe I foun d where it connects but after putting it all back together, it idles really rough and I'm getting 7 codes, including misfire on cyl 1 and throttle position sensor. Could it just be that I attached the connectors incorrectly? Again, this was after replacing CCV.
Old 12-28-2012, 04:18 PM   #4
trentcdrums
You can easily get those codes from having a sticking icv. Pull that out and try cleaning. Took me 30 minutes. There's a DIY by solidjake
Old 12-29-2012, 10:42 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
In my vid I stated to take some blue tape and match the wire to the connectors.
ccv valve, connector, harness, oil separator
