Australia
Old 12-28-2012, 02:05 AM   #21
f4n4tik
My Ride: M-Sport 320Ci e46
Originally Posted by ating View Post
Possibly...depends how much it's rubbing. You can either raise it, run more negative camber, stretch tyres or a combination of these things.
Ahh I think it just rubs when I go over a deepish or sudden dip in the road, when iv got 1 or more passengers in the car or when the side wall rubs a bit when I turn corners a little bit faster then I should
f4n4tik is offline   Reply With Quote
Old 12-29-2012, 12:11 AM   #22
f4n4tik
If anyone could tell me what tyre would suit a19x9 et45 wheel that would be great. I called a large tyre store and they couldn't tell me ****...
Old 12-29-2012, 06:25 AM   #23
Jall
My Ride: 328Ci
What size are you running on the front? I would run a 255/30.
You should also work out where you're rubbing, most of my rubbing was coming from the clip where the fender meets the rear bumper which won't necessarily be cured by a skinnier tyre. Tape up your fender with masking tape, go for a drive and see where the rub marks are.
Jall is offline   Reply With Quote
Old 12-29-2012, 10:52 PM   #24
f4n4tik
245/35/r19 on the front
