///M3 Forum
Old 06-02-2012, 03:14 PM   #1
YGOSLO
My Ride: 03 CarbonSchwartz M3
Dead Horn?
I was out driving last weekend and honked at another M3, or at least I thought I did. Loud music, car noises, etc. I figured they drowned out the sound. Then this morning I pulled into the parking lot at work and honk at a co-worker and I get an abbreviated honk and then nothing. I hit the horn a few morn times, nothing. So I check fuses 5 and 55, they're good. I try the horn again and it honks but cuts out again. Then nothing, again. Any ideas?
Full Black Interior For Sale
2003.5 Carbon Black/Imola Red ///M3 Coupe: Stock
2003 SVT Ford Mustang Cobra: Not Stock
YGOSLO is offline   Reply With Quote
Old 06-03-2012, 04:09 AM   #2
YGOSLO
Ok, so it's not completely gone this evening I was driving around and tried it and it sounded like someone was stabbing a lamb. It was a pathetic wailing of a horn. Either way, it's not very safe so, any ideas?
Old 06-03-2012, 09:06 AM   #3
E46NYBMW
My Ride: E46
Do you still have all steering wheel functions? My horn with all steering wheel functions and light went out when my clock spring went bad.
E46NYBMW is offline   Reply With Quote
Old 06-03-2012, 11:17 AM   #4
YGOSLO
Yes, steering wheel functions are still there. On occasion when I turn the volume down the track/station forward button activates, but it's been like that since I've owned the car.
Old 06-04-2012, 11:15 AM   #5
scottjoh
My Ride: '99 323i & '02 540i
If the clock spring is good then that leaves the horn relay and the horn itself. Try swapping the horn relay with one of the other relays as a test. Here is a map of the relays located behind the glove box www.bmwgm5.com/E46_relays.htm.
scottjoh is offline   Reply With Quote
Old 06-04-2012, 12:28 PM   #6
YGOSLO
How do I determine if the clock spring is functional? Or is it safe to assume that if I still have my steering wheel functions that it is good?
Old 06-04-2012, 02:40 PM   #7
scottjoh
If the other steering wheel buttons are good then the horn is probably good, but, not a 100% sure thing. Taking the assembly apart to check is not easy and you risk damaging the flex cable. Try putting your hand on the horn relay while tapping the horn button. Make sure the relay clicks or just swap it with the A/C relay. Use the web page I posted earlier to determine which relay is the horn and A/C.
Old 12-28-2012, 03:23 PM   #8
YGOSLO
Ok, I finally got around to doing this. The horn relay clicks when I press the horn button. So now what? Is it the clock spring? I really do not feel like disassembling the steering wheel.
Old 12-29-2012, 12:17 AM   #9
NICKBRUM
My Ride: 2004 M3
Before you tear into the steering wheel, check the connections at the horn its self.
Current:
2006 E46 M3 ZCP silver gray on black SMG
|Stoptech BBK ST40 X 355mm| Style 219 wheels|
|Ceramic coated euro headers| Custom 200 cell section 1|
|TTFS Motor & SMG tune, 315 whp| GC coil overs |
Previous: Totaled
|Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's|CSL/SMG Flash|
|Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters|PFC DD Front Rotors|
NICKBRUM is offline   Reply With Quote
Old 12-29-2012, 10:10 AM   #10
YGOSLO
Will do. You would think if I press the horn in the steering wheel and the relay in the glove box clicks and everything in the steering wheel is working. But, I don't engineer anything for a living so.... Thanks.
Old 12-29-2012, 12:46 PM   #11
NICKBRUM
My Ride: 2004 M3
I'm right there with ya, I would look from the relay on.
Current:
Previous: Totaled
Old 06-21-2014, 07:44 PM   #12
YGOSLO
Update: it turned out to be the horns themselves. Bought new horns and replaced them, good to go. And for the record, horns on the e46 M3 are behind the bumper on the driver side. No need to remove the bumper. Take of wheel arch liner on driver side and get it from underneath. And yes, it has been two years.....
Old 06-23-2014, 03:35 PM   #13
lennon31987
lennon31987's Avatar
My Ride: imolarot II M
Send a message via AIM to lennon31987
i think we have 2 horns, a high and a low, one of yours may need to be replaced. no big deal.
Last of the best-
ILLm3 hates me cause im GGGOOODLOOKIIINN
seeking detailing perfection?
lennon31987 is offline   Reply With Quote
Old 06-23-2014, 10:03 PM   #14
YGOSLO
You are absolutely correct. Both were dead. See post above yours.
