Sponsored by BimmerWorld
Old 12-29-2012, 01:18 PM   #1
thecarguy
My Ride: ZHP Sedan
Strut tower reinforcement plates - does mine already have them??
I'm not sure if the previous owner installed strut tower reinforcement plates on the 05 330i zhp I purchased about 2 years ago. I bought the plates from a dealer several months back and have just put off installing them. I then started wondering if there is a way of "seeing" the plates from the top?
Last thing I would want to have happen is go to the effort of dropping the strut down to discover it already has them.
thecarguy is offline   Reply With Quote
Old 12-30-2012, 01:15 PM   #2
Guest021715
Account closed.
It just a black disc that goes between the top of the strut and body of the car.
Looks like this:
Old 12-30-2012, 01:19 PM   #3
rcsummers
My Ride: M3
looks like you do.
if you didnt, above the strut would be that same grey color.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 12-30-2012, 01:24 PM   #4
Guest021715
Account closed.
I'm not the OP
Old 12-30-2012, 01:41 PM   #5
rcsummers
My Ride: M3
Hahahah totally read that all as one post
"RICH"
My Build Thread
EURO.TECHNIKS
Old 12-30-2012, 01:49 PM   #6
Guest021715
Account closed.
Lol
I like the camber in your sig
Old 12-30-2012, 01:52 PM   #7
thecarguy
My Ride: ZHP Sedan
Looks like this:
Perfect, thanks for the pic. I'll check her out!
Old 12-30-2012, 05:06 PM   #8
rcsummers
My Ride: M3
Lol
Hah thanks. It's about -4.2 there
"RICH"
My Build Thread
EURO.TECHNIKS
Old 01-29-2013, 05:55 PM   #9
yannis4ny
My Ride: 2004 325ci vert
would you consider selling them? I need a pair
yannis4ny is offline   Reply With Quote
Old 01-29-2013, 10:39 PM   #10
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
does anyone know if these raise the car at all?
i'm wanting to raise my front maybe 2 mm and this would be a nice and easy way to get a little lift.
i don't want to take the springs out and put different spring pads on.
Old 01-29-2013, 10:52 PM   #11
yannis4ny
take a 2mm aluminum sheet, machine it and make holes on it. then install it in the place of this reinforcement. you can get it from:
http://www.mcmaster.com/#standard-al...sheets/=l95ty1
Old 02-01-2013, 11:53 AM   #12
Guest021715
Account closed.
Do not do this.
The reinforcement plates are shaped specifically for the strut towers. Using a flat piece of aluminum creates stress points, and mushrooms your towers even quicker.
If by “machining” you imply that you’ll be shaping them, why go to all that effort?
BMW sells the plates for around $10 each, and yes they’ll add about 2mm to the ride height.
Old 02-04-2013, 12:08 PM   #13
yannis4ny
Do not do this.
Thanks for the info, I was planning on doing this actually.
Old 02-06-2013, 11:56 PM   #14
Guest021715
Account closed.
No problem, I hope that saves you some trouble
