Health & Fitness
Discuss any topics related to heath and fitness here. |
#21 |
#22 |
#23 |
Chest
Incline DB Press - 3 set of 60lbs X 6 BB Bench Press - 1 set of 150lbs X 5 and 2 sets of 140lbs X 7 Circuit: Incline DB flies 3 sets 60lbs x 10 Dips 3 x 15 reps Pushups 3 x 8 Tris: Press machine 3 sets 100lbs x 10 |
#24 |
Shoulders:
Seated military presses 1 x 110lbs 6 reps, 2 x 100lbs 7 reps Behind the neck presses 1 x 85lbs 6 reps, 2 x 80lbs 7 reps rear delts 3 x 20lbs 10 reps side delts 3 x 25 lbs 8 reps reverse wide cable pull downs 3 x 25lbs 10 reps close grip cable traps pull 3 x 60 8 reps Tri: pull-downs 3 x 60lbs 10 reps reverse pull downs 3 x 80lbs 8 reps Abs: leg ups 2 x 15 reps full crunches 2 x 10 reps with 25lbs |
#25 |
Back
Deadlifts (smith machine): 1 x 5 295lbs 2 x 7 275lbs Behind behnch head pull: 3 x 10 55lbs Weighted pull-ups: 3 x 6 with 30lbs plus 4 reps assisted with 3 sec pause on way down chin-ups 3 x 10 |
#26 |
wtf is a smith machine deadlift
#27 |
#28 |
Deadlifting on a smith machine is awful
#29 |
Any alternatives? I tried with DB DLs, smith machine felt better.
I do put a matt with holders to raise me off the ground by 10" so the BB is a bit below half way on my shins. Last edited by z00; 12-29-2012 at 12:59 PM. |
#30 |
That's probably your best bet really. The form will never be identical and dumbbell deads feel a lot different.
#31 |
I would stick with other back exercises until you are able to deadlift again imo
#32 | |
I actually don't notice a lot of difference between smith machine and BB deadlift. I still get sore in the same exact spots between the two.
Deadlifts are awesome. They made such a difference for me, I don't know why I rarely see anyone at the gym doing them. ![]() Quote:
#33 |
Chest
Incline DB Press - 1 x 5 65lbs, 2 x 7 60lbs BB Bench Press - 1 set of 160lbs X 5 and 2 sets of 150lbs X 7 Dips 3 x 12 reps with 30lbs Pushups 3 x 6 with 30lbs Pec machine: 2 x 10 reps 90lbs 1 x 10 reps 110lbs Tris: bench dips 3 x 10 reps with 30lbs Last edited by z00; 12-29-2012 at 03:57 PM. |
#34 |
I just don't see the logistics of it. The fixed nature of the smith machine wouldn't allow you to power through your hips, let alone follow the natural path if a floor free weight deadlift. The bar should be "touching" your body at all times, and with the weight being fixed this is impossible. If you can't see a difference, I suggest you seriously evaluate your deadlift form as you are going to injure yourself when you go heavy.
#35 | |
There is a slight difference, but my point is that I still get a good deadlift from the smith machine. I have been going heavy. So far so good.
Here is exactly my setup and pretty similar form. If you guys see something wrong let me know. I don't use a belt. Quote:
#36 |
Forgot to post legs day from last time. It's same as below except 10lbs lower on all lifts.
Legs: Front squats: 2 x 5 120lbs 2 x 7 110lbs Back squats: 1 x 5 160lbs 1 x 6 160lbs 2 x 8 140lbs Stiff-legged deadlifts: 3 x 10 100lbs Ham extentions: 3 x 8 160lbs |
#37 |
Back
Deadlifts (smith machine): 1 x 6 250lbs 2 x 8 230lbs Behind bench head pull: 3 x 10 55lbs Weighted pull-ups: 1 x 8 with 30lbs plus 4 reps assisted with 3 sec pause on way down 2 x 6 with 30lbs with 3 sec pause chin-ups 2 x 6 with 30lbs 1 x 10 with body weight only |
#38 |
Shoulders:
Seated military presses 1 x 110lbs 6 reps, 2 x 100lbs 7 reps Behind the neck presses 1 x 85lbs 6 reps, 2 x 80lbs 7 reps rear delts 3 x 20lbs 10 reps side delts 3 x 25 lbs 8 reps close grip cable traps pull 3 x 60 8 reps Tri: pull-downs 3 x 60lbs 10 reps reverse pull downs 3 x 80lbs 8 reps Abs: leg ups 2 x 15 reps full crunches 2 x 10 reps with 25lbs |
#39 |
Chest
DB Bench Press - 1 set of 70lbs X 5 and 2 sets of 65lbs X 6 Incline DB Press - 3 set of 60lbs X 6 Dips 1 x 12 reps, 2 x 10 reps with 35lbs Pushups 3 x 6 with 30lbs high Cable flies 1 x 10 20lbs, 2 x 10 25lbs low cable flies 2 x 8 25lbs, 1 x 8 20lbs 2 x 10 of abs machine. |
#40 |
Legs:
Front squats: 2 x 4 140lbs 2 x 4 130lbs Back squats: 1 x 5 180lbs 3 x 6 160lbs Stiff-legged deadlifts: 3 x 10 100lbs Ham extentions: 3 x 8 160lbs |
