#61 |
Hey what shop did this install for you and the custom drive shaft?
#62 |
Do you have any details about how the drive shaft had to be modified in order to fit with your transmission?
I'm considering doing this on my 325i since I have a bad drive shaft U-joint and I also happen to have access to a wrecked M3 that has a good rear-end.
#63 |
Bumping an old thread here.
So my car is a 6MT...If I were to get an M3 rear end assembly, my drive shaft *should* bolt correctly onto the M3 LSD right? (assuming that I'd swap out the input flanges so the bolt pattern matches of course) |
#64 |
subscribed.
Don't say my car is topless, say the t!tties is out - FZ696 |
#65 |
#66 |
Yes, 6spd cars won't need custom work as far as I know
#67 |
Looking on real OEM...
M3 driveshaft is 1404mm long 330 6SP driveshaft if 1403mm long. So the 330 6SP driveshaft is 1mm shorter..is that an issue or good to go? |
#68 |
^That's what I was told, but don;t take my word for it. Ask knowledgeable techs if a 1mm difference is negligible.
#69 |
My Ride: '03 Orient Blue 325i
i would say it's negligible. The driveshaft plunges and I can't possibly see how 1mm would be something to get worked up over. Don't sweat it.
