Old 12-29-2012, 10:38 PM   #21
Alex323Ci
My Ride: M3 & 323Ci (sold)
would this work also on ccfl versions?
Old 12-30-2012, 04:58 AM   #22
sharkey62
My Ride: 320i
This sounds a brilliant way to control brightness of Angel Eyes. Am currently saving up for P46's with Orion V2 Angel Eyes.
I know nothing about wiring so please forgive me if this is a really stupid question but I was wondering where I could put the control switch and then wondered whether there was any way to wire the Rheostat into the wire that controls the brightness of the instrument cluster dimmer. So therefore you could dim the instrument cluster which would also dim the angel eyes and consequently make it brighter by using the little wheel on the headlight control panel. I hope this makes sense.
Any ideas if this can be done or am I way off.
Thanks.
sharkey62 is offline   Reply With Quote
Old 01-02-2013, 12:59 PM   #23
Rudy540
My Ride: E46
Which ones have u guys found are extremely bright? I have hid top and bottom so it only makes sense if I install bright halo lights
Rudy540 is offline   Reply With Quote
Old 01-02-2013, 01:03 PM   #24
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
The Orion V2 and V4 are the brightest angel eyes you can buy. For them being too bright, most people do not consider them to be so.
Some do, so you can always dim them down using a rheostat.
You can do this with CCFL, but it's pointless since CCFL aren't very bright.
Old 01-08-2013, 04:38 PM   #25
Rudy540
My Ride: E46
Does anyone one know how I can wire my v2 angel eyes with my parking lights
Old 01-13-2013, 11:38 PM   #26
morningisbad
My Ride: E46 M3 Vert
Are you looking for them to come on with the parking lights? Or dim them when they come on?
"When makin' a questionable decision, sometimes the only way to find the answer is to shut your eyes & mash the pedal to the metal, you guys."
-Karl Welzein
morningisbad is offline   Reply With Quote
Old 01-14-2013, 01:27 AM   #27
Rudy540
My Ride: E46
That was my primary way of doing it but too late now I just did it the regular way
Old 01-15-2013, 09:13 PM   #28
JokerElite
My Ride: 95 M3, 04 M3, 09 328
This method worked for me: http://www.m3forum.net/m3forum/showthread.php?t=58127
I tapped into the gray wire with the brown stripe (license plate wire) in the bundle, make sure it's the thicker one because there's two.
1995 BMW M3 - Avus Blue | 2004 BMW M3 - Jet Black | 2009 328xi - Alpine White
JokerElite is offline   Reply With Quote
Old 01-16-2013, 01:06 AM   #29
Rudy540
My Ride: E46
Thanx man but a little too late, I won't be creeping up on anyone now haha
Old 04-14-2013, 09:58 PM   #30
JokerElite
So if you have the dimming with interior lights option, you need 2 rheostats? Anyway they can be combined into one?
Old 08-28-2014, 01:04 PM   #31
Toki46
My Ride: '00 E46 20d Touring
Bump. I have the same question.
Installed LED SMD today, they're so bright I didn't even have to use xenon when I put the car into the garage in the dark. Crazy 7000k. I'm a bit afraid using them at night, I don't really want to burn people's eyes out.
Toki46 is offline   Reply With Quote
Old 08-01-2015, 07:16 AM   #32
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
Originally Posted by UncleDon View Post
You're wrong again Nick. The trigger wire from the ECU switchs the main angel eye power relay on or off. Putting the rheostat on that trigger wire will not work.
The rheostat needs to be spliced into the red main power wire between the relay and the main power source as shown in the pictures below.
If you use the option that switches and fades the angel eyes on and off with the interior lights, you will need a second rheostat on the wire that goes to the interior footwell light. Without the second rheostat, the angel eyes will be at full brightness whenever the interior lights are on.
I installed an adjustable dimmer on my EAS Auroras to tone them down so they would look good at dusk and at night.
I don't use them during the day. (BTW, these are the new, 15% brighter v1.1 Auroras.)
To install the dimmer, I spliced into the main power wire between the relay and the main power source. I wired them to come on with the fog lights and I do not use the wire that fades them on and off with the interior lights.
The rheostat, plastic "project box", and the knob are all from Radio Shack. The cost of all three parts was less than $10.
25-Ohm 3-Watt Rheostat
Model: 271-265 | Catalog #: 271-265
Project Enclosure (3x2x1")
Model: 270-1801 | Catalog #: 270-1801
Communications Style Control Knob
Model: 274-402 | Catalog #: 274-402
Installing the dimmer was easy...
- Just drill three holes in the project box.
- Solder the wires to the rheostat.
-Assemble the project box and attach it to the firewall. ( I attached it with HD velcro. )
this is the cat's ass right here, gonna ditch my ccfl rings and get 120 led , i've read they are too bright, ty for solving the prob
i have mine wired into rear parking lights , should work same
gonna try the ijdmtoy ones first, for $60 , f it, if they don't last , then i'll jump up to bimmian, khoalty or eas , which are all twice as much ...............i wouldn't buy a pencil from umnitza
http://www.ebay.com/itm/BMW-E46-3-Se...-/380369244535
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 08-04-2015, 11:20 AM   #33
Dean | KHOALTY, Inc
Dean | KHOALTY, Inc's Avatar
My Ride: BMWs
If you do buy the ijdm ones, be sure to solder the board's connection at the bottom of the rings as they're known to go bad randomly, which is why we stopped carrying that specific set of rings. We replaced so many under warranty that eventually we decided we were selling a sub-par product and dropped it for our own custom rings!
Dean | KHOALTY, Inc is offline   Reply With Quote
Old 08-04-2015, 03:28 PM   #34
wasp9166
eh, figured i'd see how long i can get out of em , they told me they give 90 day warranty , i said how long they typically last?
his answer was, depends on use, no ball park, nothing,lol
60 bucks , i dunno why but i gota exp for myself b4 i say don't buy em, they are junk
you've sold some that have been fine ?
what's your warranty ?
Old 08-27-2015, 11:33 AM   #35
wasp9166
welp, installed khoalty today , dunno how my harness is set up, i used the old one, i always do,i have it wired to come on with driving lights, so wired to rears
i tried to install the rheostat like above , but when i cut the red wire the fuse is on, they still work,lol....................how the f is this possible?
